Good morning all, I began placing the deck support beams after making adjustments to the clamp strake layout fore and aft. The ones you see so far, I call the set-up beams, they add rigidity to the longitudinal support beam. Once I finish the set-ups, I will fall back and fill in all the rest.
The cross beams are always longer than they need to be giving you a chance to trim them down to fit. If they fall between 2 ribs, it's a simple matter of marking on the beam next to a rib where to make your cuts. If they hit a rib, I found making a copy of the beam onto a thin piece of basswood, cut out the shape then you can place it between the ribs and mark your reference cuts and transfer that to the actual beam for final trimming. The trimmed piece has to conform to the slope of the ribs and the slope of the hull exactly at the top of the clamp strake.
View attachment 546376View attachment 546377
Unfortunately, the mast step does not line up with the opening provided between the two laminated deck beams. I will need to sand down as much as possible on the mast faceted pieces and relocate slightly on the longitudinal beam the notch for the cross beam to accommodate the mast opening through the deck. The first picture below comes from the plans which shows the cross beam slightly covering the mast step below. Now I may be seeing some parallax in their picture but in my build, there is a conflict.
View attachment 546375View attachment 546374View attachment 546378
So, the challenges never end on this build. Ha! In today's PC mindset, I must be model building challenged!
Thanks for checking in on me, have a great day.
