HMS Agamemnon by Caldercraft
:)Not at all
The belts were not supposed to be repeated, and they were not mirrored, and the joints were not supposed to match...
Do you only use one template for every porthole?
The port holes edges (surrounds) should be covered to their edge by the planking
Too late now but for next time
uIf ats a double planked model Plank straight under the Gun Port And then fill the gap above and below with 2 timbers
ie use the gunport surround to act as template to cut too
Mosr ports are the same size - look on the plan
Looking good otherwise
Not sure exactly what you are referring to. :( The photos above do show the planking ending at the edges of the ports. The planking covers the sill on top and sill on the bottom as well as the frame on each side that make up the port. It does not cover the stops which are recessed and were about 1.5 inches thick. On Marc's model I believe the red pieces are the stops as they are recessed. These were found on the top of the lower sill and on the two sides, but there was no stop on the bottom of the upper sill. The internal planking covers the sills and frames as well as the stops as they extend to the edge of the sills and frames. rather than being recessed on the inboard side.
Hi Richard,
Looking at the contemporary contract for HMS Nassau, a sister of HMS Agamemnon, the sizes of the gun ports on a given deck are different than the others as the caliber of the guns is different. In addition, while the sides and top and bottom on a given deck are the same, the shape changes as they are parallelograms. Each is a slightly different shape as the angle of the top and bottom of the port changes so they are pretty much parallel to the sheer of the deck.
From the contract you can see the sizes vary in both depth and fore and aft.
Gun deck 2 feet 8 inches deep and 3 feet 4 inches fore and aft
Upper deck 2 feet 8 inches deep and 2 feet 10 inches fore and aft
Quarter deck 2 feet 4 inches deep and 2 feet 6 inches fore and aft.
Another oddity: For some reason, the gun ports have two eyebolts each. There should actually be four!
The lower eye bolt must have a ring.
The fife rail for the belaying pin should be installed much lower. The top edge of the gun port serves as a reference point.
Fife-rails is not a typo, the fife-rails is so named because of its resemblance to a shepherd's pipe, that is, a pipe with a row of holes, this pipe was called a fife.
The number of belaying pins should be 12-13 per quarterdeck bulwark. See Longridge for details.
The belaying pins that came with the kit are no good; they should be thrown out. Many companies now sell high-quality replica belaying pins, and I'm sure they're easy to find in Belgium, too. It's best to get bronze ones, then paint them to look like wood—they won't break under the rigging.
Let's return to the forward quarterdeck beam. The railing installed on it is called a breast rail. Breast rails have either 8 or 10 pillars. Different drawings show this differently. HMS Augusta has 10 pillars. A museum model of an unknown 64-gun ship and a drawing of HMS Nassau show 8 pillars.
The bottom backing (item 90) needs to be removed. At this point there should be a bare forward quarterdeck beam.
Each pillar (item 404+149) has a different shape than the one in the set. At that time, all decorative pillars were shaped like antique lamps.
Thx Iutar!
Mark, that's good. So, you've set the prototype's time period to the battle with two French frigates on June 1, 1796.
I'm concerned about whether you've done the fitting and calculations as described in post 281. You might need to raise the cutwater (knee of the head) higher, but I hope this problem can be solved without major modifications...
gallery_10197_918_3658.jpg gallery_10197_918_10419 (1).jpg gallery_10197_918_32311.jpg gallery_10197_918_38437 (1).jpg gallery_10197_918_62528.jpg gallery_10197_918_84507 (1).jpg gallery_10197_918_79180.jpg gallery_10197_918_78230 (2).jpg gallery_10197_918_62014 (1).jpg 001 5.jpg 001 8.jpg 001 9.jpg
I'm concerned about whether you've done the fitting and calculations as described in post 281. You might need to raise the cutwater higher, but I hope this problem can be solved without major modifications...
View attachment 549180 View attachment 549181 View attachment 549182 View attachment 549183 View attachment 549185 View attachment 549188 View attachment 549187 View attachment 549186 View attachment 549184 View attachment 549189 View attachment 549190 View attachment 549191
Hey Iutar,
Yes I've got a look on this item.
Either way, it will require some tinkering...but that's for later... :)
I think everything will work out, everything will rise quietly, and there will be no need to break the water cutter (knee of the head).
Next step : installation of the decorative strips.
But again a Caldercraft story ... Sick
Caldercraft delivered " Casted strips"....each strip +- 80 mm long....
Not only poorly finished, but no... for such an expensive kit, I find this unacceptable (just my opinion, of course).
So, the solution: 1 x 3 mm walnut strip and make the moldings myself. Much nicer and more finished...
For this, I used Micro Shapers from Artesania Latina...
Mark, why didn't you fix those holes? Did you forget? If you don't fix them, what's the point of improving the model if it's already incorrect?
