HMS Ontario 1:48 by Maris Stella
These are nuts to tie, I've made 3, lost 1 on my bench somewhere. Think I'll only make them for the 6 guns on the upper deck and 6 or 8 on the gun deck. It seems a lot of finished models I see only use the thicker recoil lines.?
Thanks
Neil
Hi very impressed with your model. I was wondering the approximate age of this vessel and would the bilge pump tubes pass through the decks into the bottom of the bilge itself.
Has any one read this book and will it have any recommendations of a bilge pumps c1830 English Packet Ship?
Ships' Bilge Pumps: A History of Their Development, 1500-1900
Thanks for the nice comments. It's a 1780 snow class.
And yes the bilge pumps go through both decks but not much past the gun deck.
Thank
Neil
If you look at contemporary models at RMG, Preble Hall, and other nautical museums, the guns are rigged in different amounts of completion. I think the choice is really up to you and you would be in great company regardless of your choice. In general it seems that fully rigged model tend to have the guns, but the amount of rigging varied. Admiralty style models, that is with no rigging, rarely, if ever, seem to have any guns on the models.
Guns but no rigging at Preble Hall
Running out tackle and breech but no train tackle at Preble Hall
22 Gun sixth rate with no guns at RMG
28 gun sixth rate with no guns at RMG
Thanks Allan, I think I'll just put the breech lines on the visible 6 or 8 on the gun deck, and fully rig the 6 on the top deck.
I bought the Enterprise 1:160 and have put the Ontario off to the side for now.
Thank Neil
Hello, I started back on this build. I find the instructions ( for me ) hard to follow so i took a break and did another kit.
I've mounted the canons on the gun deck with just recoil rigging. Next is to finish the bow head rails, bowsprit and figure out the mounting of the snow mast then I can instal the upper deck.
Neil
Moving right along I've finished the bow and bowsprit and installed the upper deck.
There are some issues with the height of the bullworks as the port side is higher than the starboard. And I'll have to make sure the bullworks at the bow and stern are the right height for the canons.
I've had this new and updated kit for about 2 weeks now and have started assembly.
It came with the 3D parts, upgraded blocks and canons and I purchased the sails as well.
One thing you really need to do especially for me is read the 293 page manual, which seems
to start half way through. I assembled all of the bulkheads then realized my mistake later.
Had to take them all apart. There are also 4 large blueprint sheets to use.
So far I've laid the keel, built a stand, installed the bulkheads and planked the lower deck.View attachment 531015View attachment 531016View attachment 531017View attachment 531018
View attachment 531020View attachment 531021View attachment 531022View attachment 531023View attachment 531024
Where did you buy this kit? and what was the cost? Thanks, Paul
