- Aug 8, 2019
Less body, more wing. Other wise you got a goose and can serve it at Christmas for dinner.Unfortunately I have to kill her again as I have to sand half of her body to fit it to the ship![]()
Don't mix us up with the FrenchYour national chicken is beautiful![]()
Maarten, That is a very clean cut for the cargo hatch. Which tool did you use to achieve such detail? Magic MikeToday I cut a big hole in the stern.
As the ship was a woodhauler sailing towards the baltic for getting pine and spruce from the Northern parts and oak from the Baltic states.
To load all these logs into the hold there is a door in the stern just above the waterline. This was not a simple port with a lid but a port which was closed with planks and caulking after it was closed.
It is located at the red square below on the wreck pictures.
You can see the door on pictures of the wreck.
The size of the door I determined at 2,5 x 2,5 Amsterdam foot. Which is 70 x 70 cm. This is determined by a size comparison between this door and the sternport in the cabin.
I have placed the lower sill of the port 1 foot above the load water line.
The port in the ship is still work in progress.
View attachment 550820View attachment 550821
As a HCSA member is this cut for you ‘a piece of cake’. Nicely done, Maarten.Today I cut a big hole in the stern.
Hi Mike.Maarten, That is a very clean cut for the cargo hatch. Which tool did you use to achieve such detail? Magic Mike
Some remarkably fine miniature joinery!Today the cargo door was finished.
After fitting an additional hull plank the complete outside of the door/port was squared and also the top sil fitted on the inside.
A hatch was made of cross nailed planks.
To fit into the door.
The nails to the door still have to be made.
At sea this door was nailed in place and caulked.
To give you an idea about the real ship as at the sea bottom and mine, see below.
Small hatches are often looking great. For sure yours does, Maarten.Today the cargo door was finished.
Outstanding!
Ditto and ditto. Maarten this is "off the charts" good. Cheers GrantSuperb!
