HMAV Bounty 1:48 (based on) Artesania Latina Kit
The Netherlands
Hello!
Some fellow Dutch shipbuilders encouraged me to join SOS. I did so last week.
After being a silent follower of the wonderful projects here for a while, I'll share my own building activities with you.
I've been building historical ship models for several years. After completing Corel's HMS Bellona, I started working on Artesania Latina's Bounty in 2021. In this build log, I'll show you how I got to the stage the project is now (Picture below). I'll do this by describing the various stages of the model's construction separately. (Please keep in mind that English isn't my native language!)
I used the Artesania Latina kit as the basis for this project. As the build progressed, I added more and more my own scratch-build parts.
I hope you enjoy it and that I will find some helpful advice here and there! Thanks in advance!
Erik B
Hello!
Erik B
Good morning Eric. It is good to see another Bounty log. You have made wonderful progress so far. Welcome to SOS. Cheers Grant
Part 1: The Hull
(May to December 2021)
I started construction in May 2021, naturally with the assembly of the hull. Unfortunately, there are no photos available from the earliest stages.
Although the Artesania kit provides a complete interior, I chose to plank the hull on both sides.
Initially, I had difficulty with planking the bow of this type of vessel. The first two attempts failed. In both cases, I removed the planks.
After studying the photo below, I realized that with this type of hull shape, not all planks can extend all the way to the bow.
Before starting the third planking attempt, I used very thin slats (of the same width) to follow the natural curves of the wood. This also allowed me to determine where planks needed to be shortened.
Using this method, I more or less succeeded in planking the bow properly. In total, I had to drop 5 planks on the starboard and port side.
Part 1: The Hull
View attachment 551856View attachment 551855
View attachment 551857View attachment 551859
Good morning Eric. That planking is awesome. I remember when I did mine I tapered each plank more so I avoided the "dropper" planks however they look very impressive. Cheers Hrant
Part 2 Deck Fittings
April - July 2022
Most of the deck fittings come from the kit. However, I did apply my own colors and weathering. I fitted out the deck from bow to stern. As you will see in later photos, I changed colors and details at a later stage (such as the pumps, for example).
1904 1.png1904 5.pngB3F46D3F-FE91-4464-AE99-1ECD3E88B5BE.jpgC13BE57C-0055-4AC6-AFA1-54AD99CF6F6D.jpg
One part of the kit that was absolutely unsuitable for installation was the steering wheel. Artesania supplies this kit with a very ugly metal steering wheel. I decided to make my own out of pear wood. The first attempt immediately yielded a much better result.
8A607953-5EE1-4A6F-AEAD-03A0D9FB0C73.jpg53E4F784-1FF5-4141-8994-0CA213B62B1C.jpgAF9F5579-451D-4A31-A19F-4A5603714690.jpg
Many would agree with you. There are many things that the old time kit makers still supply that are unsuitable from the wheel to the gratings so it is great to see you put in all the extra work to make a very nicely done wheel.
View attachment 552863View attachment 552866
View attachment 552859View attachment 552860View attachment 552864
View attachment 552858View attachment 552861
That is the "model building spirit". Nice work Erik. Thumbsup
