HMS Victory [1805] 1:79 by serikoff. Started with Mantua -> Upgraded with John McKay's Anatomy.
So, the final chord - and the skin will be completely finished.
Rudder feather.
Before I started to skin the steering wheel, I glued the pins of the curtains, and then pasted the end with strips of self-adhesive copper tape. Due to the complex geometry of this area, it would be problematic to use a regular shoal, so the choice was obvious.
I polished the copper to remove the oxide.
Then I cut off all the excess and isolated with tape the area where the glue should not get.
At the same time, I left 1.5 mm of exposed copper in order to glue standard copper plates on top of it. This will prevent the self-adhesive tape from peeling off in the future.
Then I made imitation nail heads on self-adhesive tape...
... and with that the copper cladding work is OFFICIALLY COMPLETED!!
In the end:
2630 copper plates were used to cover the entire underwater part of the ship in my 1:79 scale!
The plates were in 1:72 scale and had the following dimensions: 4.5 x 17 x 0.1 mm (naturally, most of the glued plates were rectangular, but they also turned into trapezoid and triangular shapes in the narrowing areas).
One thing, those who were following the process, noticed that I glued them in groups, i.e. not only individually, but also in two, 3, 4 and even 5 plates in one strip. In the end, this saved me 2 times more time. Since in total I glued exactly half of the total number, or more precisely 1310 fragments.
Next up are the steering wheel covers... cleaning off the tape, polishing off the glue and opening up the patina... but for now I need a little break from copper. For now I'll number the parts on Alert.
Ship-1
Congratulations Sergey
Impressive work
Good morning Sergey. Bravo.....That was a massive job and wonderfully executed. I'm with Paul though and have no desire to copper plate a hull. Cheers Grant
Ahah, I wouldn’t have covered it myself if I had done the correct bottom lining, but as it was I had no choice))
Impressive work
Thanks for your rating! )
Good morning Sergey,
wonderful work on the copper plates. Congratulations on completing this very complex project.
Thank you very much!! Yes, this was really the most difficult for me. I decided to take a break, switched to Alert, although I still plan to make steering wheel loops to finally cover the copper with patina.
Hi Sergey, a great job on that copper plating. It seems like an endless monotonous job at the time but the result is worth it, yours especially.
Thank you very much. I'm glad you liked it. I agree that it's worth it, but I'll think twice about doing it all again or not)))
I haven't been here in 100 years.
For those who don't know, this project is on hold because I'm currently building Alert 1777 .
You can check it out; I think it'll be interesting. I'm building two hulls at once (one from a PoF skeleton kit and one fully planned with masts, spars, and sails. So, welcome.
And here I want to share an improvement to my "glass coffin for Cinderella" display case for Victory.
I bought these legs (unfortunately they turned out to be different lengths and had to be calibrated) before that I covered them with Danish oil, and screwed them to the base.
Our robot vacuum cleaner, named "Korzhyk" (which translates as a round baked product that is hard as a cracker and more like a gingerbread cookie), was conveniently placed under this improvised table. :p
I've been wanting to do this for a long time, because this whole setup was sitting on a coffee table, which the manufacturer said could support up to 8 kilograms, even though it weighs 2.5 kilograms more...
...and I was always worried that the legs wouldn't hold up and it would fall over with a bang. But now these legs can easily withstand the weight.
And this is what all 3 models look like... compact (for now) and most importantly reliable and sooooo beautiful (in my opinion) ROTF.
P.S. Just in case, I'll clarify that this is a temporary option (it's naturally for a long time))) but eventually I'll come up with something more attractive for the future.
Peace to all!
Ship-1
Peace to all!
Ship-1
I love this display in the display case, aquarium style, refined, tasteful and so original. This ship is absolutely beautiful, congratulations. I will therefore take inspiration from it for my HMS Victory that I am building but only with the primary masts, limited version from Occre. Thank you.
Thank you very much. I'm glad you liked it. I'll be back with this project someday. And good luck with yours! By the way, I ordered this glass case from a company that makes aquariums, so technically it's an aquarium, just upside down.:p
Hello to all my colleagues in the best hobby in the world!
My name is Sergey, but in the world of ships, I go by the name serikoff.
And here’s my story. (Without this introduction, it might be hard to understand me).
I’m from Ukraine and I am the creator of a website and forum dedicated to wooden shipbuilding. My forum is one of the largest in Ukraine. It began functioning fully in 2012. There are more than 150 build logs, just as many threads featuring completed models, and 250 threads discussing techniques and other topics. Some of the modelers who have published their work include prominent names such as: Evgeny Epur, Dmitry Shevelev, and Vladislav Zhdan. These names are well-known in our region. (By the way, Olga, who is known here under the nickname shipphotographer.com, also regularly published her work. It’s not surprising, since we’re from the same area). But! The situation started to deteriorate after 2014, when we began having issues with the website’s domain and hosting. That was the first phase of the war, as our countries were closely intertwined, and cross-sanctions began to destroy joint services. And after the full-scale Russian invasion of Ukraine, the website essentially died. To be more precise, it still exists, but all the images uploaded by modelers have disappeared. The reason for this is a conflict between the image storage resources and the website’s platform. Right now, I don’t have the resources or time to restore it. But I’m sure that after our victory, someone will be able to create a forum as large and wonderful as yours.
Now, about me...
I started building my second model in 2009 (the first one was experimental, and I didn’t see the point in finishing it). At that time, there weren’t as many resources available as there are today. I made many mistakes and learned how to correct them. I shared this knowledge on my website and forum. However, due to being busy in 2013, I had to put my project on hold. But as the saying goes, "Every cloud has a silver lining." The war started, borders were closed, and I could no longer travel—something that took up all my free time. I’m a dentist, in case anyone’s curious. And under constant shelling, explosions, and air raid sirens, to keep from losing my mind, I decided to return to my hobby. Exactly 10 years later.
What am I doing here...
First of all, I’d like to say that I found your forum by accident. But! I fell in love with it right away! There’s a warm atmosphere, lots of information, and I’ve really been missing all of this. In my journal, I want to share my build, all the knowledge I have, and, of course, ask the questions that interest me. I will be happy to help anyone if you have questions, feel free to reach out. I’m deliberately not posting a link to my website so as not to spoil the build. I want my journal to progress in real time, reaching the current state of the build. Please excuse my English—I will be using Chat GPT for translations to avoid any difficulties.
What I’m building...
As you can see from the title, it’s HMS Victory. I created the framework of the model using plans from a Mantua kit. I didn’t buy the kit itself. I printed the plans in A0 format and built the frame (the skeleton) based on them. That was the end of my work with the Mantua kit. All further work was based on John McKay’s anatomy of the ship. In this journal, I want to take you through the whole process, from the kit plans to the anatomical upgrade.
I would also like to share my experiments: Working with blueprints. Aging and painting wood. Aging copper. Making and painting ropes and rigging. 3D modeling and integrating 3D printing into wooden shipbuilding. And much more. It will be fun, and I hope it will be informative for you. I’m sure I will learn a lot from you as well. Thanks in advance for that!
Let’s get started!
P.S. Рідною.
Хочу звернутися до всіх українців, що виїхали до, чи під час війни. Не слухайте нікого. Кожна людина прагне щастя та безпеки собі та своїм близким. І я щиро сподіваюся, що у вас все добре і ви у безпеці. А всім, хто залишилися, хочу побажати перемоги, мирного неба, сил та здоров'я все це пережити. Бережіть себе, все буде Україна! Слава ЗСУ!
Також ваша думка, choo Pin Yoo (on Youtube)
Now, about me...
Let’s get started!
P.S. Рідною.
First my last video... ♥
with all my sympathy for the sacred music . Secondly my new interrogation : https://studio.youtube.com/video/D6uNHarn_a4/edit I than you and I beleive in... Have a weekend with some happiness, Philippe (BE)
Yes, Victory is a highly hyped project, but there's still something special about this ship. I started mine in 2009 and there was a 10-year hiatus, and after filming, it's on hiatus again, but that makes it all the more interesting because it's the project of my life... maybe it's good that it's not ending
ROTF
You are doing well too, it is working out, I see in you my motivation, which is connected with Victory.
ROTF
So says the youngest guy on the website.
ROTF
Is it possible to get the link of your web site ? Thank you ♥
I remember 15 years ago I was younger than everyone on my site. Here I am again, younger than everyone. What's going on? ROTF ROTF
My site used to be under the domain: Serikoff Ship Models, but after the war, I had to revert to the original name I created the site under back in 2009. I already told the story of how, due to a conflict between the site's hosting and images, all the images on my forum disappeared. So, that site is currently dormant, but my forum used to be no less valuable in terms of information than this one, maybe not as large, but still filled with valuable information. But those days are in the past; with the war, no one has time for that. As for myself, I communicate here and share my experiences and what I hope I know.
