Duco is nitrocellulose dissolved in acetone. Nitrocellulose is gun cotton. There is no chemical reaction involved with its bond. Apply wet- in solution - when the solvent evaporates, the dry nitrocellulose is the bond. Acetone will reverse the bond.
Thank you for the primer on glues.Not true in my experience. The vehicle for PVA is water. If a particular version is too thick, dilute with water. But not as much as might be imagined - Think in the range of 10% more water. PVA is acidic. The more water resistant is the final bond, the more acidic is the product. Titebond II is pH 3. Off the shelf vinegar is pH 2.4. The solvent that reverses a PVA bond is an alcohol. The most effective one is 2-propanol - isopropyl. Pharmacies here have 70% and 91%. The 91% is the better choice. Amazon has 99% Swan for $7/pt. if you wish to dissolve Shellac flakes in a solvent with a slightly longer wet time than 95% ethanol - Shellac thinner.
A PVA bond involves a chemical reaction - forming long chains. Alcohol untangles the chains but the reaction product stays the same new larger compounds.
There is white PVA - polymerizes water clear - yellow PVA - carpenters glue - polymerizes amber clear. It is more acidic and produces a stronger bond - Titebond II is a yellow PVA with additives for a water resistant bond - LA may not know from humidity, but over here on the southern Atlantic coast we do. Titebond III is forms a "waterproof" bond - It polymerizes brown. It is pH 2.5. (If it was something that is made of wood and I would float in it - I would still use resorcinol glue - something that would set your political nannies hair on fire.) There is a pH 7 white PVA (bookbinders). This is for rigging that is plant fibers twisted up.
Do they allow rubber cement? The solvent - thinner is n-heptane. (7) gasoline has octane (8) - Are you allowed gasoline? Jibes aside - quality rubber cement like True Test is excellent for fixing patterns to wood. Coat both surfaces - a significant and through coat - let dry - stick together - no adjustment - instant bond. Your thumb can completely remove dry rubber cement from a wood surface. Rolls into rod.
This is also the same process with contact cement - DAP Weldwood contact cement - which is a really poor choice as a model component adhesive, a really really poor choice. In construction, it is good for any bonds that you do not mind coming apart after 20 years - it probably oxidizes to become so brittle.
I would not touch CA with a ten foot pole. It uses water as its reaction catalyst. I am having the thought that the more water the wood has at its surface, the quicker is the CA reaction. It has volatile components that are decidedly unhealthy. You cannot get acetone but can you get CA? If yes - there is a strange sort of logic involved. CA has a strong vertical bond (pull apart). The lateral (sheer force) bond strength is not so good. Acetone will reverse its bond. Perhaps the humidity in LA is low enough that a bottle of CA will not start reacting in it container as soon as it is exposed to the atmosphere?
Denatured alcohol is 95% ethanol with an added emetic chemical to make ingestion an unpleasant experience. It is exempt from the moonshine tax. Your local liquor store sells the same 95% ethanol without the emetic but with the tax. Everclear? When I was a pup it was Pharmco grain - involved in tall frat tales about what purple passion could do.I can't but denatured alcohol in los Angeles county
I only checked online at Ace Hardware and Home Depot.As a fellow Californian, I share your frustration with the unavailability of many once-common products, primarily due to air quality control ordinances limiting the sale of high-VOC content solvents in "The Land of Fruits and Nuts." (In the spirit of full disclosure, we do have serious air quality issues that we have to stay on top of.) Nevertheless, I'm surprised by your report that you cannot purchase denatured alcohol in Los Angeles County. A google search indicates there are no prohibitions on denatured alcohol in California or locally in Los Angeles County. It is not at all restricted in the San Francisco Bay Area where I live and we've got the some of the strictest restrictions in the nation up here. "Denatured alcohol" is also sold labeled as "alcohol stove fuel" and fuel for chafing dishes and the like. I keep pretty close tabs on what's available in the solvent department of local hardware and paint stores. I'd urge you to take another look in the paint department for denatured alcohol which is usually sold in quart, gallon, and five gallon cans in most every place where paint thinner, acetone, and other solvents are sold. The methamphetamine chefs are still buying acetone in five gallon cans at the local Ace Hardware stores, so I expect alcohol is still available.If not, grab a gallon can at any paint or hardware store the next time you're out of LA County. It's a workshop staple.
Curious- Can one buy fingernail polish removed in LAC? That has Acetone in it, granted a bit diluted, but it will dissolve CA, just not quite as fast as straight Acetone. Someone mentioned vinegar. Stores like Home Depot and Lowe's, and maybe TrueValue and Ace as well, sell 30% for weed control (1gal. jug). I also use vinegar (white, distilled) instead of MicroSet for setting decals. Much cheaper.Do you desolve the glue with acetone.
I can't but denatured alcohol in los Angeles county. We're being "protected" by our mayor and governor.
We can buy finger polish remover. That's what I have been using.Curious- Can one buy fingernail polish removed in LAC? That has Acetone in it, granted a bit diluted, but it will dissolve CA, just not quite as fast as straight Acetone. Someone mentioned vinegar. Stores like Home Depot and Lowe's, and maybe TrueValue and Ace as well, sell 30% for weed control (1gal. jug). I also use vinegar (white, distilled) instead of MicroSet for setting decals. Much cheaper.
Assuming you haven't started planking I would bin it and buy decent timber. I rarely use supplied materials for that reason.I don't know what wood is used for the ZHL San Felipe kit. It is extremely porous.
When testing stain colors and building a deck planking sample i found the stain bleeds through to the underside of the plank. When building the deck planking sample I found that both the PVA and CA glues bleed through to the surface.
I don't want the shiny surface created by the CA bleedthrough. I'm afraid of the splotchy finish created by the PVA bleedthrough.
I'm also afraid to prefinish the deck planks prior to installation because I won't be able to glue subsequent deck furniture.
See prestained deck plank below. It was stained with Minwax Golden Pecan oil based.
Any advice is sincerely appreciated.
Ted
hiI don't know what wood is used for the ZHL San Felipe kit. It is extremely porous.
Ted
remember ships where holystoned so remained very lightAssuming you haven't started planking I would bin it and buy decent timber. I rarely use supplied materials for that reason.
Royal Navy ships were holystoned! Indeed. But French and Spanish!!?? They were considered disgusting by our tars! Even a woodstain would be too uniform to be realistic. If I were to build one as a diorama I'd treat it like an old fishing boat.remember ships where holystoned so remained very light
Your mode.l is really nicehi
Decking should be Smooth which your is but it needs but the planks should never end in points anywhare
They cannot be fixed onto the hull
If you have a second layer of planking cut into equal lengths of about 5" 8cm
A main plank (Garboard Strake) should run along from the Stern STAIGHT along the keel and end up cut into the keel before it starts lifting beforn the stem I would then start at the lower level of GunPorts and fill in as much as you can down the side of the ship with no trimming of ends
Dont forget to do both sides
Then fil in towards the stem with solid planks
Then use steelers to fill in the gaps
The Dutch use A DIFFERENT method to the English
Illustrations are from Historic Ship Models by zu Mondfeld The One Book every modeller should have
If you use the right wood it should not need staining
My San Felpipe showing the best Planking i ever did
built in when wood was really goodYour mode.l is really nice
If you're referring to Artisiana Latina I've built two of their kits and found the wood to be garbage.built in when wood was really good
Panart
JUst a bit disappointed that others arnt as good
Given up on my L Victory Wood is farv too thick
But thansk
I have been using Titebond II since I began all this. It has served me well. PVA bonds by building chains that grab an irregular wood surface and penetrate pores. The closer are the two wood surfaces, the stronger is the bond. PVA does not bond to a smooth surface - like metal - or a wood surface sanded much finer than 220-240 grit. 120 is probably better but 220 is a compulsion of mine. A shellac primed surface offers no tooth.
might be for wood but not for stained wood and if not cleaned of propely stops a decent stain and varnishIf people are unaware, Titebond manufactures a superglue specifically for wood.
