I think they look pretty darn good! The paint should take care of any minor imperfections.I’m Still not getting the edges nice and pointy but a big improvement. I will paint my wales black so maybe these will come out ok.
Thank you very much Russ and Allan. It has been a steep learning curve and loads of fun cutting these from a big plank. Hopefully it uwill all look good when all is done - I still have a long climb ahead before we pop that champagne or whiskey. I will have a single malt Dalwhinnie once doneAbsolutely! Much better Grant.
Thanks Paul. I will do now that you have made me aware of it. At the moment I am doing the midship strakes. A question - those strakes at the bow. Clearly I have to notch these to fit the rabbet. I have read that these need to be thinned as well. At what point does this occur and do I make these a top and butt pattern or do I use straight strakes around the bend?Looks like you are heading in the right direction, Grant. Again, beware the curving hull effect near the bow when forming these guys...
As far as I can tell the wales are thinned to fully seat in the rabbet. That is, on English ships they are not notched at all. At the point the wales enter the rabbet they are the same thickness as the surrounding planking. I have not observed this on ships of French origin, however, so this may not be universally true.A question - those strakes at the bow. Clearly I have to notch these to fit the rabbet. I have read that these need to be thinned as well.
Well, I have seen the top and butt pattern run all the way to the stem and I have seen the top and butt pattern drop off earlier. Here is the problem you face: you either have to edge bend or spile the top and butt planks to get around the bow. I can't seem to make edge bending a reliable solution so I always spile these curved planks. BUT...to preserve the top and butt pattern via spiling requires suitable stock (your walnut) and cardstock patterns carefully prepared and then transferred to your walnut planking panel...At what point does this occur and do I make these a top and butt pattern or do I use straight strakes around the bend?
.Look at the two of us...talking about ships like we know what the $%^&* we are talking about
. I think I will adopt the easiest (if such a thing exists) of the options but I have plenty to think about. Thank you kindly. Cheers Grant
. Some more unfinished business……..
.Grant,Walnut paneling will look great though not sure about paneling being used during that time period.
And worse; I fell for it...Look at the two of us...talking about ships like we know what the $%^&* we are talking about.
Still, it sure does look nice.Walnut paneling will look great though not sure about paneling being used during that time period.
Thanks Gunther. Let’s hope it continues to do so.Hey Grant,
Please make three walnut panels for me too...
That looks really great. Brilliant. Very nice photos...![]()
Thanks Daniel and John. You guys are correct. The bulwark planks extended into the cabin with just the stern and the screen bulkhead being paneled. The Enterprise was painted white .Grant,
Daniel certainly has a good point. Why don't you try etching some lines into those panels??
“ into my cabin. I will include some inner panels once I have worked out where my hanging knees will go. The kit hanging knees are too short so will have to make these. Thank you kindly. I agree it makes for better coals on the braaiIt's a success!
Adding hardwood to model increases its calorific value!
Keep it up, better fuel- longer burns![]()
As they say Johan….fake it till you make it…And worse; I fell for it...![]()
I hope it will come out good in the end- a little poetic license makes for fun times.Still, it sure does look nice.
You are absolutely right about this. It is so simple, yet most, if not all, kits fail to show or explain it.As far as I can tell the wales are thinned to fully seat in the rabbet.
