Just as an FYI a culverin is not a type or pattern, it is the English name of a size/caliber of cannon that shot balls that weighed about 17 to 18 pounds. It was lighter in construction than later 18 pounders, a trend started by the French navy at that time. There was a small percentage of culebrinas on Spanish ships but again, they were mounted on four truck carriages and looked like barrel #7 and carriage in #1 in your post.the Chinese meant this type of culverin
After all, we're just building a fantasy about a Spanish sailboat, not a museum model, so we're enjoying the process without delving too deeply into the subject.Just as an FYI a culverin is not a type or pattern, it is the English name of a size/caliber of cannon that shot balls that weighed about 17 to 18 pounds. It was lighter in construction than later 18 pounders, a trend started by the French navy at that time. There was a small percentage of culebrinas on Spanish ships but again, they were mounted on four truck carriages and looked like barrel #7 and carriage in #1 in your post.
This is absolutely phenomenal. The view of the stern cements what I’m looking at to get started again. I’m doubly determined to get out of the hospital and get back to buildingsI've finished sheathing the sides below the quarterdeck. I still haven't decided what to finish the forecastle and quarterdeck with. The blue hornbeam issue is still unsolved. I'm leaning toward mahogany, which I used for the lower hull. But I still have work to do on the forecastle and head, and I've also thought about using padauk (a solid red material) to frame the gunports. I'll also use it later to make the inside of the gunport covers, so I don't have to paint them.
View attachment 558250View attachment 558252
View attachment 558259View attachment 558253View attachment 558254View attachment 558255View attachment 558257View attachment 558258
Were getting what you are saying. Nice workSome preliminary work on the bow. I glued and screwed the base tightly to the basswood boss and keel frame. I think this is more secure and without gaps. I covered the bottom with mahogany veneer, and the deck with the same pear wood planks as the rest of the deck. I also extended the valance so it runs smoothly to the knyadiged. I glued it in place and nailed it with brass nails. The vertical board in the forward bulkhead is made of 1.5-gauge mahogany plywood. For now, work on the bow is put on hold; first, I need to finish the stern, so I can plank the quarterdeck and finally get to the gunwale railings.
View attachment 560169View attachment 560167View attachment 560170View attachment 560168
A small remark. I had to edit the translation several times, even of such a small text, and still the same Google translator translates the ship's terms disgustingly, however, he is not the only one. It often turns out to be complete gibberish. I hope that the general meaning of my messages is clear to native English speakers.)))
I am impressed. I was also thinking of gilding. It should make a nice contrast tothe oiled woodNevertheless, I decided that I would not paint the hull of the quarterdeck and stern blue. I stopped at a red tree. I have just the slats left, which I sheathed the hull with below the waterline. After I cover it with tung oil, there will be a dark red shade of natural wood, I think gilding on jewelry will look good.
I can't wait to see it.Nevertheless, I decided that I would not paint the hull of the quarterdeck and stern blue. I stopped at a red tree. I have just the slats left, which I sheathed the hull with below the waterline. After I cover it with tung oil, there will be a dark red shade of natural wood, I think gilding on jewelry will look good.
I'm happy to have Etwas in the lead so I can follow his good results. He is the picture I'm building toI can't wait to see it.
It's going to be very different from what we usually see for the San Felipe.
I'm sure it's going to be very beautiful, like the rest of your work.
