Axel Thorsen 1810 in scale 1/72 build by Dubz Modelling World
Axel Thorsen 1810 Dane - Norwegian Schooner 1:72 by Modelship Dockyard
Download Instruction Manual - Axel Thorsen 1810
Size:
Length: 400mm
Width: 80mm
Height: 250mm
Time for something new.
I have a special relationship with smaller, more unusual ships and kits, and I wanted to build something "simple" without having to think too much. Spoiler alert: the plan didn't work out at all :-D
In my stash, I still had this small, inexpensive 1:72 kit with a printed hull from Modelship Dockyard. The design seemed interesting and the finished hull promised easy construction...
History:
The Axel Thorsen was constructed in 1810 as a Naval gun-schooner for the Royal Danish/Norwegian Navy. Built from pine, the vessel measured approximately 56 Norwegian feet (approx. 19 meters) in length with a displacement of 74 tons. It was armed with two 24-pdr swivel guns and typically crewed by 45 sailors. This class of schooner was designed to counter the British blockade of the Norwegian coastline during the Napoleonic Wars, primarily tasked with escorting merchant ships from the White Sea to Norway. In its early service, the Axel Thorsen participated in multiple convoy missions and harbor defense operations.
Following the Napoleonic Wars, the ship continued to serve for decades in diverse roles, including coastal surveying, Arctic scientific expeditions, and marine resource harvesting. Its final chapter came in 1872 during an Arctic exploration when it was trapped by ice and abandoned in Tsjesjekaja Bay near Cape Kanin.
Axel Thorsen epitomized 19th-century maritime endeavors—from wartime defense and sovereignty assertion to Arctic exploration and resource exploitation. Its dual roles reflect the era’s complexities
The Kit:
At first glance, the kit makes a good impression. I prefer pear wood, but cherry is also a good wood. Turned brass gun barrels, high-quality blocks, photo-etched parts and some resin parts (3D printed) round off the picture. A 1:1 side view of the model is included as the only plan. The instructions can be downloaded from drydockmodelsandparts.com, for example.
Unfortunately, it becomes clear as early as step 3 of the instructions that something is seriously wrong. The instructions – as will become increasingly clear – are unfortunately a disaster. Parts are not mentioned, not named, look completely different from the laser-cut parts, are supposed to be installed in a way that is not possible, and are sometimes listed in an "unfortunate" order.
Unfortunately, this seems to be a fundamental problem with lots, not all, Chinese kits. Which is a shame. Wonderful little kits are designed, but it seems that no one is willing to go through a couple of beta build iterations to test whether, for example, the instructions are correct and what can and, above all, must be optimized. It's a great pity.
Anyway, challenge accepted.
The inner planking should be made with 1 mm cherry veneer. There's no way to get all the bends with these short parts – the wood is simply too thick! Other manufacturers rightly use 0.5 mm veneer for this. I switched to this and made the parts with 0.5 mm pear veneer.
Another issue was the waterway. According to the instructions, it should be glued to the deck, which is nonsense, if only because of the fishing that has been done. With a 3D-printed hull, you would expect everything to fit perfectly, but that is not the case. The waterway had to be laboriously adapted to the shape of the printed case.
The keels false keel is not mentioned in the instructions and no part number is shown, great (I mean I don't care ... haha).
It was a very frustrating start, and I was undecided whether to start a build log because there was a possibility that I would abandon the project. So much for simple and relaxing... :-D
Cheers Dirk
Continue with step 05 of the instructions. Here, the outer hull is to be planked. It must be ensured that that the top of the first plank is flush with the top edges of the sides of the hull. Unfortunately, there is NO mention of NOT shortening the planks at the stern, so beware or be smarter :-D According to the images it LOOKS like to cut them flush. Much better would have been to do step 07 - the stern - before. You will learn I like filler.
Cheers Dirk
Going on with step 05 - I did the whales - and step 06 the handrail ... another fail of the kit haha. First the parts would not have been fit flush when the inner planking would have been done with 1mm veneer. Second the handrail should not be flushed to the planking anyway.
Cheers Dirk
I'm curious what glue you are using to attach the planks to the hull. CA?
Yes CA is the only way to go and I hate it .... CA is fine for small spots but annoying for bigger stuff imo. Sticky Fingers for the win :-D
I was afraid of that. I happen to be allergic to CA though I only discovered that planking the Vasa a few years ago. I was using CA along with PVA and I ended up with what I thought was the worst head cold in the history of head colds that lasted for about a month. I finished the planking and recovered. The next time I opened a bottle of CA it all started again: light bulb moment.
If you end up in my situation I have learned there are versions of CA that I don't react to...
Yes, I know what you mean. I never really had any problems with CA, but now it tickles my nose and makes my lungs tingle, depending on the brand of CA. It's become similar with wood dust. Unfortunately. During longer crafting sessions, I therefore work with a mask with special dust and gas filters.
