Absolutely.Step 22 says: "Insert the eyebolt 51 in the centre of the stern deck 19 (keeping a 1.5 mm gap with
the frame 15)."
It seems like a hole needs to be drilled for that but there is no mention of that. Does a very tiny hole seem reasonable?
It took me a while to work out what should be done, the instructions and pictures are not very helpful as you say!Step 24 says: "
Cut parts 58, 59 and 60 from the 1.5 x 2 mm and 1.5 x 3 mm walnut batten and
glue them into place. Dye and varnish them. Cut and glue the edging 61A, 61B
from the 1.5 x 1.5 mm basswood batten for the bow gunwale cover 53. Mask andView attachment 557813
pain the frames with the name of the ship at the bow 62 and stern 63 and glue
them into their respective places."
#59 is to be cut from 1.5 x 3mm. The photo shows a 1mm deep x 59mm wide notch in #59. I can't see what that notch is for. In fact I can't tell from the photos just how #59 is to be placed. Should it be on its edge or on its side? Where is the notch supposed to end up?
I do find that some of the photos in the instructions are next to useless!
The only thing I can make of it:I cannot understand what this picture from step #31 is trying to tell me:
There seems to be nothing useful in the descriptive text.
Hi, it is a mooring line post used to tie on to. On the ship there are two posts either side of the ships wheel as you can see in the image. They are made from two pieces with the cross piece rebated into the upright post and then just glued onto the deck.I cannot understand what this picture from step #31 is trying to tell me:
I drill the largest hole possible, without being too big, one at each end, and then use sharp scalpel to cut horizontally between them. If its a really long slot, drill a third hole in the middle.What is the best way to drill the slotted holes for the scuppers? Is it best to just try to drill multiple holes close together? It doesn't seem to work all that well.
Hi,Step #35 states: "Fit the capstan with the parts 154-155-156-157-158 and glue it onto the
deck (having first dyed the base 158)"
It seems to show an axel going right through part #154. However there is no hole drilled right through #154. There is a partial hole so I'm assuming I have to drill a hole all the way through so that the axel can be installed. Is the partial hole likely just another flaw in the kit? Also it seems as though the axel is to be cut from the coiled brass wire. Does that seem correct?
A bit of an after thought if you are looking to improve the capstan. I pushed some black shrink tubing over the drums and shrunk it using a hair drier to give a nice rubber effect where the chains run. Another little upgrade was to drill a few holes around the perimeter of the base and push some planking nails in to make some "bolts".Thanks so much. That all makes sense now.
