Sterling American Scout WWII Cargo Ship
I've long planned to build an HO model railroad harbor scene and one of the features I want to add is a large cargo ship. I'm also interested in WWII history so I've been thinking maybe the ship should be a Liberty ship or similar.
WWII cargo ships have been part of a number of model railroads, for example Rod Stewart (the rock star) included a Liberty Ship model on his very large model railroad:
Another modeler, Howard Lloyd, built this next ship and dock scene in HO. It's modified from a Deans Marine "Melanie" kit (https://deansmarine.co.uk/shop/product_info.php/products_id/372) and is about 35" long - maybe a foot shorter than the Sterling kit. It's also 1:96 scale, and doesn't look out of place next to the 1:87 locomotive and boxcars and the HO seamen figures on board don't look too far out of scale for the ship.
I've also been following Vic Fordyce's excellent American Scout build thread: https://shipsofscale.com/sosforums/threads/american-scout-c-2-cargo-ship-by-sterling-models.17309/ and he's given me much inspiration.
I'm beginning a build of a Sterling American Scout kit as a WWII freighter, even though the Scout is alleged to be 1/96 scale which is a bit smaller than HO scale (1/87, more on that later). I've just started construction, photos to come.
With the ship models in the last post as inspiration, my original plan was to use the Sterling kit as a basis for building a Liberty ship but my research uncovered the fact that over 300 C2 cargo ships (the prototype for the Sterling kit) were built during the war years and a number of them served in the war. Here's an example (https://en.wikipedia.org/wiki/USS_Polaris_(AF-11):
Another C2, this one's the USS Whiteside and is a U.S. Navy attack cargo ship.
More on the WWII Emergency Shipbuilding Program, C2 ships are reference in here: https://en.wikipedia.org/wiki/Emergency_Shipbuilding_Program#The_emergency_ships
So I've decided to build the Sterling kit as a C2 in use by the military - I'll paint is Navy gray like the Polaris and have similar armament added to make it a plausible WWII C2. I've already sourced 3d printed armaments from https://distefano3dprint.com/
For prototype inspiration, I also plan a visit to the S.S. John W. Brown, one of two WWII Liberty Ships now serving as floating museums. It's berthed in Baltimore, which isn't very far from where I live. https://www.ssjohnwbrown.org/
I plan to build the kit as a waterline model but rather than build the complete hull and cut it at the water line, I'm going to cut the bulkheads to the correct waterline height as I'm building. I've got a bandsaw so cutting the completed hull at the waterline wouldn't be too difficult but the balsa hull may be fairly fragile so I'm thinking it might be best to build it from the start as a waterline model and avoid the stress of cutting it.
I'm assembling the bulkheads but not gluing them to the base at this point - before I glue them to the base I'll shorten them so the base, which is below the waterline if the hull were to be built according to the plans, will be the waterline.
I may also finish the exterior of the hull in fiberglass - while my model will never see actual water, I believe I can achieve a much smoother and more realistic hull with fiberglass than trying to seal the porous balsa. I've got years of experience with fiberglass, having designed and built several custom hardtops and other body parts for Jeeps over the years, so coating the hull in fiberglass is no problem.
I finished assembling the bulkheads. They're not glued to the base yet, they're just setting in the notches in the base.
According to the plans, the balsa base is roughly 1 3/8" below the waterline. Since I'm building this as a waterline model, my next step is to trim 1 1/4 off the bottom of each bulkhead before gluing it to the base. As I trim them, I'll recreate the tabs on the bottom so the bulkheads will still assemble into the slots in the base.
Once the bulkheads are trimmed and glued to the base, I'll make a sub-base out of 1/4" plywood to strengthen the assembly. I mentioned above that I'll trim 1 1/4 off the bottom of each bulkhead, the extra 1/8 or so plus the thickness of the plywood base will provide a bit of reveal below the waterline for red bottom paint.
If the ship is empty, you might want to have some extra hull showing. How deep will your resin sea be? You’ll need to add at least that much below the waterline plus perhaps another 1/8 to 1/4 inch because of the lack of cargo.
Vic,
Thanks for the input, those are good thoughts. What I posted earlier about taking 1 1/4" off the bottom of each bulkhead and then adding a 1/4" plywood base under the balsa base would result in about 3/8" reveal below the waterline, so not an empty ship. But I'll have to give it some more thought before cutting. The photos of Howard Lloyd's ship in the first post shows the holds open and cargo inside; I wasn't thinking of doing that but it does look good so I'll have to think about that too before I cut, maybe I'll cut off a little less than 1 1/4".
A few other things I plan to include in my scene... in the 50's a company called Rewal produced operating gantry crane kits in HO scale. I found two of the crane kits on eBay complete and unbuilt so those will be stationed on the dock next to the ship. The kits are motorized but I haven't decided if I'll build them as static kits, build them with the motors and controls provided with the kit, or make a bigger project out of them and power them with an Arduino microcontroller, something else I've got some experience with.
It's fairly large and a pair of them will look good on the wharf next to the ship. This is a damaged third one I picked up for parts:
Model railroad manufacturer/retailer Walthers also offers a number of harbor kits, some of which I'll use in my scene. Walthers also offers gantry cranes, but I'm going to use the Renwal cranes in my scene.
I've also got several tubgoat kits, so probably I'll include one of them in the scene as well. The Walthers tug is 1:87 scale and the Lindberg one is 1:84.
Vic,
Would you make the tug waterline as well?
Yes, definitely. The Walthers Railroad Tug Boat I pictured above is already a waterline model because it's intended to be used in a model railroad seaport scene. The Lindberg Coast Guard tug has a full hull so it would need to be cut to the waterline. Haven't thought about which one I'll use yet.
My ship in Little Creek, Va., was the USS Algol-AKA 59, ( as the one above) imagine this type would be a good choice. (AKAs were named after constellations, she now lies off the NJ coast).
I set up a mockup of a pier using the damaged crane I showed in a previous post, some piling castings I made and an HO boxcar. If I built the ship without lowering it, the waterline would be about 7.5' above the water. I don't know if that's realistic for an empty C2, maybe someone with more knowledge about C2's or similar cargo ships could chime in.
Looking back at the photos of Harold Lloyd's dock scene in the first post, the deck of the ship in the mockups below is quite a bit higher than the deck in his photos. I'm still thinking I should lower the hull a bit, but I'm looking for input to help me decide how much to lower it or now even if I build it lower.
In your first and second pictures, it appears to be ships that are not fully loaded. It looks like the waterline is 8-10’ above the water.
The “waterline” of a merchant vessel can be a nebulous issue. While the Plimsoll mark defines the minimum freeboard that must be maintained, vessels hauling General Cargo can leave post not loaded fully to the “ marks.” Why is this?
Cargo has two related characteristics; weight and volume. A very light cargo will fill up a cargo space before the ship floats at its Plimsoll mark. Conversely a heavy cargo can bring her down to her mark with a partially filled hold.
A number of years ago I was involved in shipping a cargo of rubber lined large diameter steel pipe across the Great Lakes to its eventual destination, a mine in Indonesia. While the load filled up the ship to the point where she had a deck cargo, The resulting freeboard was such that it was necessary to load water ballast so she could clear a bridge in the Detroit River.
Roger
I've decided that I don't prefer the look of the ship in the water all the way down to the waterline:
I think this looks better:
In that photo, visually it appears that the raised side by the deckhouse is the same height as the distance from the water up to the waterline, so I measured both on the plans. The rise by the deckhouse is 1":
Measuring down 1" from the waterline on the plans leaves about 1/2" to the bottom of the balsa base:
Since I plan to add a piece of 1/4" plywood to strengthen the bottom, I'll add 1/4" to that 1/2" and cut 3/4" off the bottom of each bulkhead before gluing them in place and that will result in a waterline model that looks like the photo above.
Roger
Very interesting discussion. Thank you, Roger!
You’ve done a lot of thinking on this.
Sorry if I might be boring people with detail, I can post only major milestones if people prefer. Thinking through the details is how I work, I learned long ago in my work as an automotive accessories designer that there's no substitute for thinking and planning before grabbing the tools.
Here's more detail, I lowered the bulkheads today. I used a 3/4" wide scale to mark the locations for cuts to lower the bulkheads 3/4" and once marked I cut them with a razor blade.
Work in progress, the five bulkheads in the center of the hull have been cut. The bulkheads still are just setting in place, not glued to the base yet.
All bulkheads cut:
Due to the flare of the hull, shortening the bulkheads makes them wider than the base at the bottom. I planned for this - when I cut the 1/4" plywood I'll be using as a sub-base to glue this entire assembly to I'll cut to the proper contour to match the bottoms of the bulkheads.
If I'm posting too much detail I'll be happy to post less.
You’re doing a great job.
As a past merchant mariner I love the insight into your loaded /unloaded conditions of your model.
In times past when we had to load a different cargo from what we had be carrying we would find the ship to be so far out of the water that it was difficult to walk forward from the stern as it was steep.
