H.M.S. Enterprize 1774 1:48 - Modelship Dockyard by Corsair Build Log
Price of this wheel scared me.
It's same like a 1:1 scale 24-inch wheel from a horse-drawn carriage, on the country decor website.
;)ROTF
But admit, it looks great.
ok, I finally got the other set of hawse timbers glued in place and also the transom wing is shaped and installed. Once those dry, I'll work on the Kelson !
I'm delighted that you've already accomplished this on this large piece, Jeff. It looks very nice.:)
I'm also working on the small "kit" of the replacement ships wheel to replace the one that came with the kit
(Image stolen from ships wheel instructions)
And I'm delighted that you are also working on this small piece, Jeff. A different mindset for some time.:)
;)ROTF
Really? I didn't think the price was that bad and it looks way better than the 3D printed one that came with the kit which had way too many spokes !
Thank you Peter. :) I was having a lot of trouble with the hawse pieces with my thinking. I was just scared to install it. :) And I had some trouble getting it shaped right.
Yes, the kit of the ships wheel is a totally different animal and it has tiny pieces involved. Totally different mindset. But it looks SO much better ! I had to do something because the 3D printed one got broken while I was removing it from the supports and it wasn't accurate anyway. I'll get a picture of both of them side by side when I'm done building the wheel.
can you help - just seem to get sarcastic comments from others
At the Front of the Lower Deck there is a part Number L1d
On Sheet D4 there are two parts L1d
Totally differnt shape but does fit
Any ideas please as ive not found a mistake like this on the plans
ITS ALRIGHT - L2d for Gun Deck is similar
Be nice if the plans aid how many Pieces like L1d(3))
Price from Chuck very reasonable.
I was going to source one but ultimately when I finish airbrushing resin one it will look exactly like wood.
May revisit after I see your pics side by side.
Its obviously been changed on the WOOD but not on the plan !!!!
There is a third, center piece than fits inside curve to complete piece.
Be aware the trim lines for the tapered curve as well as notch to fit keel when formed have to be approached slowly to fit tapers on YOUR hull.
Small gaps on outside are OK as they will be covered by waterways.
This looks like a deck hook that fays to the apron. As TRS7139 points out, it may have to be beveled slightly and notched so it can rest on the deck clamp the same as the deck beams rest. It looks to be about 15 feet above the keel.
With all the hooks, a lot of fitting. Lots of bevel to the frames on lower ones, less the higher ones. Forward curvature usually needs adjustment to match interior hawse curvature. Go slow !
This is where, IMO, spindle sander comes into it’s own
GOT IT Or at least ive got to find it
THANK YOU
Will Look tomorrow
THought Id found it (them for L1d and L2d ) But not
Ive got 3rd part of L2d)
At
least i know the shape
again thanks
It was the shape that threw me out
On ward and upwards
Must be cracking Up
THe piece is under the other 2 clearly shown on MY photo
Found the piece will fit it to the other 2 later
my ask you to get one how much is it please
Did decide to build the Doors from Strip - Ive run it vertically so it shows
My build is not a good as youi guys but Next Time !!
The ships wheel kit is about $15 USD
And it's enough parts to build 2 ships wheels (other than the templates) !
so what would it cost to get to you and then to me
Can you give me the website
I know when i asked about something else from US it was silly money
Perhaps just a small letter type post
THanks
Gentlemen: I offer this as a cautionary note.
Image is only beginning to dry fit items relative to pumps and ultimately their relationship to vertical stantions for and aft.
Images with Victors prototype and directions show vertical posts in 2-3 different locations....inside well, outside well, etc.
Yet another big reason to pour through directions to get a sense of parts interplay BEFORE you glue something delicate and have to break it out.
The pump wheels have their handles passing through, extending to the verticals where they are secured and passing past, all important because several pieces have to be aligned for pump handles to be straight. Once you start fiddling with stuff it becomes obvious but, again, directions can easily lead to to mistakes.
Small notches on pump tops is where handles locate, mine are a bit too far apart but you can plainly see, forward posts locate on lower/upper beams inside the well.
Lastly, be advised, the 4 stantions with sheaves need their mortices adjusted as well as height to fit properly on lower beam and fit snugly under gun deck. Lot's of tapering/ shaping involved here as well as dabbing tops that locate beneath deck beams. Want to get this all proper since they are a substantial feature.
Far easier to get this resolved well before gun deck construction IMHO.
Hopefully this will avoid undue issues.
Tim
our problem in UK is cost from states is silly
Mine just fell apart
