- Aug 20, 2022
Cool! The initiation has started. Which one?
Thanks. I wondered if it was something as simple as thatThere are no original plans of the Golden Hind and they didn't discover it's wreck lying on the bottom of the English Channel. All model kits as well as the full size reconstructions they made in Britain are based on pictures of what similar ships of the time looked like, or are educated guesses. So, do whatever you think looks good on your model. The Revell version is probably smaller than the original and has too few guns, but who knows?
Agreed! I will be very wary of such things having been caught with the Airfix Endeavour. The main role of that kit was to teach me!Yep, agree. No photo's either apparently. I would do a dry run of your kit parts to check the shrouds and chains don't foul the gunports and rails.
Absolutely!This one will be a lesson also, lol
I certainly agree the sentiment, but there is a yawning rabbit hole just a step ahead of you, and it is this.rivet count away because of the cast amount of references available, but the GH, not so much. I say model away to your hearts content! No one can prove you wrong!
You are absolutely rightI certainly agree the sentiment, but there is a yawning rabbit hole just a step ahead of you, and it is this.
When you go back a couple of centuries, there are no plans, no science. Shipbuilders learned what worked by seeing which ships came back from their voyages. And that means that if you look into the history and origins of the ship, you could discover more, and if you then look into other ships of the same period you could discover more about what features and shapes were fashionable. Then you create some drawings to note those features, and see what fits, and how a builder of the day might have prepared such a ship for such a voyage - bearing in mind that altering the rig, the masts, and so on wasn’t impossible.
And now you can build a model and rightly claim a level of authenticity. Change kit parts, add and modify away, and when questions may be asked, you quote sources, and justifications for the ‘angle of the foremast is more indicative of ships of that period than the kit makers represent.’
Now, my lad, you are deep in the well of shipbuilding research, and you may never be able to get back to ‘just’ assembling a kit without needing to check on ‘just a few’ details.
But the sense of achievement is way greater than mere assembly and a good paint job. It takes that an multiplies by 5, by 10…
Welcome.
Jim
