12 Gun Brig-of-War
Your figurehead and bow arrangement is looking good, nice work.
Thanks Colin. I am not totally happy with the way they have turned out. The figurehead, as well as being anachronistic, is probably a bit too big. And my scroll work is a bit rough. I have tried to clean it up but it is probably the best I can do with the tools I have and my skill level. I confess that I get a bit discouraged at times when I compare my results with the incredible standard of workmanship that so many of the model-makers are able to achieve on this site, so I very much appreciate your positive comments.
Have now installed the rudder and fitted the beakhead grating.
I have found that trying to compare my work to others’ brings only discouragement, not encouragement. I try to limit myself to comparing my work only to my work. Thus, if I’m producing something I judge better than what I managed before, then I am on the right path.
I like how you tackled that grating. Looks very nice.
I have found that trying to compare my work to others’ brings only discouragement, not encouragement. I try to limit myself to comparing my only to my work. Thus, if I’m producing something I judge better than what I managed before, then I am on the right path.
Thank you for the encouragement. This being my first scratch built model at this scale (I built a couple of miniatures at 25 feet to the inch fourty years ago, but they are completely different creatures) I don't have any previous work to compare my current work to, so am groping towards what I am capable of and how long I want to spend working on this project. Generally my ambitions far exceed my abilities, but one has to have a go to find out what they are.
I had a look at your Fair America and was drawn to the figurehead - very nicely done - which made me realise just how bad my attempt at carving my Sylph has turned out. I was quite pleased with it initially but having looked at it now for some time I am increasingly unhappy with it, it is clumsy and just way too big. I reckon at some point it is going to have to be chopped off and done again. Perhaps I will revert to the regulation lion.
Once again, I very much appreciate your interest.
My hat’s off to you for carving your own figurehead. I don’t think I could ever try carving something like that from scratch because I know I have zero artistic skills. Instead I would root around the hobby shops and second-hand stores to find something close and then go all Dr Frankenstein on it till Ihad the look I was after.
