12 Gun Brig-of-War
Your figurehead and bow arrangement is looking good, nice work.
Thanks Colin. I am not totally happy with the way they have turned out. The figurehead, as well as being anachronistic, is probably a bit too big. And my scroll work is a bit rough. I have tried to clean it up but it is probably the best I can do with the tools I have and my skill level. I confess that I get a bit discouraged at times when I compare my results with the incredible standard of workmanship that so many of the model-makers are able to achieve on this site, so I very much appreciate your positive comments.
Have now installed the rudder and fitted the beakhead grating.
I have found that trying to compare my work to others’ brings only discouragement, not encouragement. I try to limit myself to comparing my work only to my work. Thus, if I’m producing something I judge better than what I managed before, then I am on the right path.
I like how you tackled that grating. Looks very nice.
I have found that trying to compare my work to others’ brings only discouragement, not encouragement. I try to limit myself to comparing my only to my work. Thus, if I’m producing something I judge better than what I managed before, then I am on the right path.
Thank you for the encouragement. This being my first scratch built model at this scale (I built a couple of miniatures at 25 feet to the inch fourty years ago, but they are completely different creatures) I don't have any previous work to compare my current work to, so am groping towards what I am capable of and how long I want to spend working on this project. Generally my ambitions far exceed my abilities, but one has to have a go to find out what they are.
I had a look at your Fair America and was drawn to the figurehead - very nicely done - which made me realise just how bad my attempt at carving my Sylph has turned out. I was quite pleased with it initially but having looked at it now for some time I am increasingly unhappy with it, it is clumsy and just way too big. I reckon at some point it is going to have to be chopped off and done again. Perhaps I will revert to the regulation lion.
Once again, I very much appreciate your interest.
My hat’s off to you for carving your own figurehead. I don’t think I could ever try carving something like that from scratch because I know I have zero artistic skills. Instead I would root around the hobby shops and second-hand stores to find something close and then go all Dr Frankenstein on it till Ihad the look I was after.
Thanks for the tip. I reckon I will follow your lead and start "rooting around" looking for something that might be the foundation for my figurehead.
I acquired some new tools recently (a Byrnes table saw, a milling machine and a mini wood lathe) which hopefully will improve some of my work. So far I have produced the steering wheel and a some cannons. Turning the cannons in timber so that they are close to the same dimensions is a bit of a challenge.
Beautifully done ship's wheel.
What brig is the model, or at least what year and nationality?
Thanks
Hi Allan, Royal Navy brig of the preiod 1840, the plans are from Harold A Underhill. The brigs were, inter alia, used for supressing piracy and the slave trade and then later as training vessels. Attached is a photo of HMS Sealark from aorund 1890 when fitted out as a training ship (photo colourised by Frank Hellston). Thank you for your interest.
Thank Sylph.
I am curious to know more about this era in general and thank you for your reply. There are a couple dozen drawings on the RMG Collections website for the brigs including ten of Sealark that may be helpful. I am guessing Mr. Underhill used these same drawings in his work, but it would be interesting to compare.
Is the cannon in your photo based on a drawing from Underhill as well? The reason I ask is that a drawing I have for Dolphin would have been appropriate for Sealark according to an annotation on the drawing and mentioned by RMG. https://www.rmg.co.uk/collections/objects/rmgc-object-85012
I look forward to your progress!!
Thank Sylph.
Hi Allan, Thanks for the drawings, much appreciated. While the photos of the Sealark show considerable similarity to Mr Underhill 's drawings, the lines plan is significantly different, in particular the amount of deadrise. Underhill notes that his drawings are of a typical brig-of-war of the period and not the more extreme "clipper" type, which perhaps Dolphin/ Sealark was an example of.
At this stage I intend to follow Underhill's plans for the cannons and carronades unless they prove to be demonstrably wrong.
Once again very much appreciate your interest and input. There is such a wealth of knowledge held within the collective of this website.
Bob
Hi Bob, looks like you have been busy. The ships wheel looks like it has turned out great. I have been considering getting myself a mini wood lathe, the metal work lathe in the workshop is a bit too large for the smaller items and is not really made for turning wood.
I have not made much progress on my build since before Christmas, just the odd bit here and there. I am now trying to get back to it and will hopefully complete the bowsprit assembly next, making the sprit yards this week. Have you found the lathe very useful and what make did you end up getting? I think you will find the mini table saw very useful, I know I have.
Kind regards
Colin.
Kind regards
Colin.
Hi Colin,
I am afraid progress on my model is going to slow down for a while as I have other priorities for the time being. (It's a hobby after all.) The mini wood lathe I bought off ebay pretty cheap - about $170 AUD. I was worried that it was going to turn out to be junk but I reckon it is actually pretty good for the price. If you want info on the specific model I bought let me know.
Your little brig is looking excellent. As mentioned previously, you have done a fantastic job on the yawl. How have you achieved the water effect in the photo? Looks good.
Regards,
Bob
Ello Bob, I hope your other priorities don’t give you to many problems. My progress has also been very slow but just now starting to get back into it again. I put a photo of the yawl hanging off the davits onto a Facebook modelling group I belong to and one of the respondents made a nice comment on it and sent back the photo with the water effect, I’m not sure how he done it but my guess was with an AI app. With that in mind I thought I would have a play and tried with a couple of photos. I still have much to learn but I can see possibilities. Here are a couple of pictures that I have produced, one of my Brig and one of the Bounty. It’s just a bit of fun to help pass the time. I would like the details of your lathe when you get time please, take care.
Colin
Hi Colin, Here is an image of the lathe (I bought it off Amazon, not eBay, but they are available from eBay as well). They obviously come from China (doesn't nearly everything these days?) so it took a couple of weeks for delivery). As mentioned so far I am pretty happy with it. It only comes with the one chisel, but I have been using the tips of my mini-files to good effect. I figured at the price I couldn't go too far wrong. I will see how it goes and if I need to I can alway replace it with a better quality machine down the track.
The AI water effects show potential for a bit of fun. Interesting. And the bowsprit etc looks like it is coming along nicely.
Oh, and thank you for your thoughtfulnees, but my 'other priorities' are of the good kind - I Iive on my boat, Sylph VI, and am going for a bit of a sail, so can only progress small bits and pieces for the time being (blog.mailasail.com/sylph).
Regards,
Bob
