Thank you Kurt! I have been shrouded, but now doing better since they were rat lined.We are no longer shrouded in mystery on how you got all this done so nice and neat.
Great work, and I will for sure copy and print your build log for review before I begin my cross section.
Mike I am using a mixture of lines. The cannon lines were all from the kit. I then bought line from Ropes of Scale and Syren model kit. The lower shrouds were from the kit but served with sewing line I picked up at Michaels. The upper set of shrouds were done with 0.5mm (0.019)" lines from Ropes of scales because I wanted something thinner for the upper shrouds. The rat lines were done from the lines included in the kit. The running rigging will be mostly from Ropes of Scale and Syren. I think the Ropes of Scale and Syren line are clearly superior to what the kit offers and probably easier to handle.Rob, is the rigging line you are using mostly supplied in the kit or are you using "after market" line also?
Hit back when you can.
Cheers
Mike
Very nice Rob.I attached the preventer sling to the main yarn wrapping line through both thimbles. I also attached the 2 triple blocks along side the preventer sling. These all wrap inside the sling cleats in the front of the yarn and the lines are wrapped under the jackstay wire. In case you are interested these blocks are from Syren models and they are really well made and, as you can see, look great.
The instructions, I believe have incorrectly labeled these. The one labeled sling should be called the preventer sling. It was there, I gather, to hold the main yarn up in case the other 2 slings (properly called Jeers) were to fail. The other two slings that do the main lifting of the yard were called Jeers.
There will still be more lines wrapped in this tight space between the cleats for the truss tackle. These are lines used to hold the yard tight to the mast. This small area is full of blocks and lines going this way and that. It is a bit difficult to figure exactly where things go, but looking at other build logs is a big help.
Grant thank you again for your kind comments and great input!Very nice Rob.
I am also working on my Santissima Trinidad cross section, and have the lower shrouds done and slowing working the upper level now, but very slowly with other holiday taskings, I need to get back to work and finish that so I can start another project, or better finish another project I have started.Thank you Kurt! I have been shrouded, but now doing better since they were rat lined.This kit has been fun! One thing I keep thinking is that I am only doing 1/3rd the rat lining that would be required on a full size ship. That alone is enough to humble one.
Thank you Rob, your build log is invaluable to me and others. Thanks for the hard work on this!Mike I am using a mixture of lines. The cannon lines were all from the kit. I then bought line from Ropes of Scale and Syren model kit. The lower shrouds were from the kit but served with sewing line I picked up at Michaels. The upper set of shrouds were done with 0.5mm (0.019)" lines from Ropes of scales because I wanted something thinner for the upper shrouds. The rat lines were done from the lines included in the kit. The running rigging will be mostly from Ropes of Scale and Syren. I think the Ropes of Scale and Syren line are clearly superior to what the kit offers and probably easier to handle.
The blocks on the cannons were from the kit, I then got Beautiful blocks from Model Expo and blocks from Syren. I think I would give the Syren blocks (which are actually 3D printed) an edge over the beautiful blocks. Both are clearly superior to what is included in the kit. If you look at post #169 I have a picture of the 3 different blocks for comparison.
Rob
Thank you Mike. Luckily I find the build log fun to do and it really helps me with the build. Happy New years to you and your family.Thank you Rob, your build log is invaluable to me and others. Thanks for the hard work on this!
Mike
And to you as well, Rob!Happy New years all!
I am also working on my Santisima Trinidad cross section, and have the lowere shrouds done and slowing working the upper level now, but very slowly with other holiday taskings, I need to get back to work and finish that so I can start another project, or better finish another project I have started.Thank you Kurt! I have been shrouded, but now doing better since they were rat lined.This kit has been fun! One thing I keep thinking is that I am only doing 1/3rd the rat lining that would be required on a full size ship. That alone is enough to humble one.
