still not found those window frames for Magazinewoke up about 3 this morning and realised !!!!
THanks
got it just got to glaze it !!!!!Richard, I believe I found the lamp window frames you are looking for.
Look on wood sheet J3. You will find these below and the triangular pieces for the top and bottom to the left.
Glad I could help you find it.got it just got to glaze it !!!!!
Copied from my PostGlad I could help you find it.![]()
Richard....not Victor, but.VICTOR PLEASE
REALLY not happy
Started the Lower DEck Bulkheads
They are STEP 63 and LOWER DECK BULKHEADS
No problems but
The Parts are Lettered on 63
but not on the PLan
Anyone got a later plan that shows the Letters
Orlop desk id not good as im not sure i got in right
ALSO i have no 4 x 4mm square
Ive already purchased 6 metres
Lower deck bulkheads have no part numbers found on parts sheets.
This numbers relate to what should be on sheet #5 but missing.
Really not a big issue, if you measure up length on sheets, it's pretty obvious where they lie, allowing for slight angles on long walls with doors,all made from strip.
Again, be sure to insure height fits "your hull".
P.S. use 3x3 strips, makes no earthly difference.
got no 3x3 either 4x4 will make a difference as ive cut slots for 4 x 4
Yes now I know i have lightly fitted the beams foromm13 to stern Hoping to work out which long bulkhead is at back
The longer side one appers to be stern as it fits side of ship
Thanks. The color is actually deeper in person although going to dry brush some darker as well.Personally, I think that is too orange. You want a much deeper color. But that is my opinion (Since you asked)
Thanks Allan, yep, went back and dry brushed couple shades of dark red to mix it up.Maybe a few different colors. No two bricks were likely the exact same color or just go darker. There were likely uncountable colors across the fleet so hard to be wrong
My take using my cheap mini drill press.
I second this!! Been anxiously awaiting the rigging set before jumping in on this kitAre there any updates on the masting and rigging kit for this model?
Just curious.![]()
Seems like we may be a little bit forgotten here
