- Sep 3, 2021
And at the scale Dean is building to it'll be 0,003291666666666670...Actually, it does look like that dihedral is about 0.237 degrees off, give or take - better get out the heat gun.
True. But if you're not going to try your best...why bother? (And at the scale Dean is building to it'll be 0,003291666666666670...
I will be happy to just get them finished...I have not had hobby time recently! nope, angles are the same.And at the scale Dean is building to it'll be 0,003291666666666670...
nope, angles are the same.![]()
Looking great !Update on the F-9F Panther…
Finally got the intakes, upper wings, wing pods and rear wings on. Now for putty and sanding. Then the big painting job will begin.
View attachment 569451View attachment 569452
See ya next time…
The Bridges at Toko-Ri…that’s a movie before my time. I will have to watch it.Nice, very nice, that model brings back memories of the movie "Bridges at Tokyo--ri".
Jan
How many people would even know what we are talking about, let alone register something might be off by a tenth of a degree.Even with the slightly off dihedral....
Only people that are knowledgeable about aircraft. Which is exactly what occurs on these forums with ships.How many people would even know what we are talking about, let alone register something might be off by a tenth of a degree.![]()
Yes, but…airplanes use aerodynamics and ships use hydrodynamics, although similar, they are different because one is air and the other is water, which obviously have different characteristics. Air is compressible, whereas water is almost incompressible and denser than air. Bernoulli’s principle, faster flow equals lower pressure, applies to both, but the effects are different due to fluid’s properties. Thus what works in air may not work as well in water, and visa versa.It’s still just fluid mechanics, isn’t it?
Thanks Daniel…it will get darker with more coats!That blue is awesome, my favorite color.
Still think you need a Cutlass just because of the unique shape.![]()
