Revell Viking Build - Once more unto the breach, dear friends, once more.
Once more unto the breach, dear friends, once more. So begins the build of the 1977 Revell Viking Longship based mainly of the 9th. century Gokstad Viking Longship found in a burial mound at Gokstad in Sandar, Sandefjord, Vestfold, Norway. It is displayed at the Viking Ship Museum in Oslo, Norway. It is the largest preserved Viking ship in Norway.
The hull basecoat is Rubber Brown, which will make detailing easier as I won't be able to get into every seam due to the clinker-built design. I can dry-brush a lighter shade progressively and weather it with an oil wash. The main deck and sub-assemblies were given a basecoat of flat black, to prep for the lighter tan shade for detailing.
I think the closest to how it could have been in reality, would be something which would look like this when you stylize it:
The-Gotland-picture-stones-show-ships-with-right-angled-square-sails-high-masts-shields.jpg
And the closest what I have found on a real ship would be this. If you make the head look downwards....687f9fb743cf4.image.jpg
But I think it is a splendid idea of yours!
Now I found this picture:
So I decided to print that:
Needs a bit of post-processing, but it will certainly work.
I haven't abandoned the post, just having to take a break and run a new wire circuit to the workshop. we had a pleasant Christmas and so far a perfect new year - just one day in though, I'm sure that will change ;).
YEAH, LIGHTS! Took a good part of the day and an extra run to Home Depot to pick up some flex conduit, but the new circuit is done. I was able to start back in the model; I detailed the main deck by sanding down the tan to let the black wood grain peek through. I still need to give it wash with water based black or brown. In the first pics, I used a #2 mechanical pencil to highlight the deck board seams. The detailing is done by 000 steel wool. #11 blade and a fingernail file.
I prepped the figureheads in flat black then burnt Iron, I'll drybrush accents. The bench seats/storage boxes that Jhoanor printed for me got their first basecoat of flat dark tan, they'll be dry brushed and washed as well.
I prepped the figureheads in flat black then burnt Iron, I'll drybrush accents. The bench seats/storage boxes that Jhoanor printed for me got theri first base of Flat dark tan, they'll be dry brushed and washes as well.
Indee d a handsome kit, with lots of potential.
I have 2 in my stash... the 'figure heads' Revell chose to model are the only 'wooden' items in the box, which in my humble opinion cry out for a better choice.
Though this is an old kit, it's still the best, faithfully rendered longship in plastic which, with careful painting, can be displayed without shame alongside much more expensive wooden kits for a bargain price.
Not much done in the last few days, finished the bow and stem carvings with a drybrush brass over burn iron and the bases were dry brushed with black first then rust. The anchors got a nice rust dry brushing for a bit of corrosion. Hopefully I can finish the hull detail this week. rainy Saturday.......
The stock of the anchor is supposed to be made of wood I think. Shouldn't it get a distinctly different colour?
I too thought of that, but I wanted to do a wood and rock anchor, but another modeler pointed out they did use iron. I'm not sure what's correct what's correct.
Got the first light color dry brushing in today after the rain, will still need to brown water wash and them dry brush some green on the lower hull for algae. I discovered that Revell carved into the mold an extra detail I didn't notice before. They could have simply left this microscopic detail off, and you'd never miss it. This detail is to indicate a leather wrapping or cladding under the top rail? Looks to be nailed on. The photo with the pin drill is to mark where I need to drill the side mast stays, the Revell rigging instruction left this off, I need to review and measure the placement of the holes before I drill. IF you have the Revell kit, take a look under the top rail for the detail.
Here's a viking anchor, looks like Revell based theirs on that. Its stock was certainly wood.
Thanks for the link, I painted the stock the darker rubber brown as if they used a preservative, the metal is black with rust dry brush, do you think they used rope of the elongated chain links, I should be able to find that style at the hobby center.
