- Dec 13, 2025
Since this is the lower deck, it is not visible on the model. And to support the trim strips around the port, you can do it like I showed below. Thank you!!!
I'm going to redo the deck. The planks from the kit are clearly not enough. According to the part list, they are 5 x 80. In fact, they are 4.6 x 80 (8.7" when converted to scale). I measure 2.8-3.0 (5.7") according to the drawing. I measure in Photoshop - about 3.0 (5.7"). Literary sources: the width of decking boards in the early 17th century was about 12".??? I don't understand. So, a 4mm plank will look fine in this scale?One of the effects of ship kit piracy...
Actually, scale 12 inches at 1/48 scale comes out to 6.35 mmI'm going to redo the deck. The planks from the kit are clearly not enough. According to the part list, they are 5 x 80. In fact, they are 4.6 x 80 (8.7" when converted to scale). I measure 2.8-3.0 (5.7") according to the drawing. I measure in Photoshop - about 3.0 (5.7"). Literary sources: the width of decking boards in the early 17th century was about 12".??? I don't understand. So, a 4mm plank will look fine in this scale?
A range of 4mm x 80mm up to 6.5mm x 80mm would be fine. Planking width varies based on available timber, and the plank width varies on the deck also as a result. Whatever you choose in that range is good. Remember, we know NOTHING about the design of the Mayflower other that it was a typical wine galleon, one among many.I'm going to redo the deck. The planks from the kit are clearly not enough. According to the part list, they are 5 x 80. In fact, they are 4.6 x 80 (8.7" when converted to scale). I measure 2.8-3.0 (5.7") according to the drawing. I measure in Photoshop - about 3.0 (5.7"). Literary sources: the width of decking boards in the early 17th century was about 12".??? I don't understand. So, a 4mm plank will look fine in this scale?
In real life, these planks were wood, wich is cut from trees, and these usually dont grow perfectly streight and unfinitely long or wide. The best, say longest pieces were used for the hull and spars; deck planking is somewhat secondary and could easily be made from shorter pieces. That also makes them more easy to replace when necessary. So your 80mm seem to be quite all right.While waiting for the new bars, I thought about it. Why do the Chinese propose to make deck flooring from slats 80 mm long? It's on a 1:48 scale of only 12.5 feet. It should be 30 or 40 feet though. 30 feet on a 1:48 scale is 187.5mm. Deck length 255 mm. Who thinks what?
