Nice!
Looking good Gilbert. I totally agree with you. To rig non visible cannons would be like pushing a car uphill. Cheers GrantHello friends
I have now completed the all the 12 pounder long guns (total of 30). It went a bit faster than I expected
Next will be installing and rigging those cannons. However, since most of them will not be seen once the quarter deck is mounted, I'll only rig the visible part (probably 7 or 8 on each side)
Good for you. There are a lot of contemporary models that have cannon but little or no rigging on the cannon, so you are in good company if you do not rig all the guns.However, since most of them will not be seen once the quarter deck is mounted, I'll only rig the visible part (probably 7 or 8 on each side)
Way to go, Gilbert. A job that never seems to end...
Good for you. There are a lot of contemporary models that have cannon but little or no rigging on the cannon, so you are in good company if you do not rig all the guns.Some of the old models do have breech ropes rigged, and a few have the running out tackle but not one of them has the train tackle. Seems like the old time artisans disliked rigging cannon as much as modern builders.
Hello and thanks for your feedbackThe HMS Victory Anatomy kit does this since the entire hull on one side is open.
Gilbert I’ve just caught up on your progress and it’s coming along quite nice. My old boss used to say that’s what you get for taking a vacation. Haha. I like the cannons as well.
BonjourGilbert,
Effectivement, très beau travail, bravo ! Je pensais suivre votre journal de bord, et bien maintenant c'est chose faite.
Gilbert,Bonjour
Merci pour ton retour
Excellent français, bravo
Though I still hold a current French passport as well as the blue one
Hi AllanIt is pretty clear you have the train tackle loop set up for the tackle nicely, but what are the other eye bolts for?
Thanks
View attachment 576852View attachment 576853
