Drafting Frames Based on Old Plans
  • Thread starter Thread starter Jerzy
  • Watchers Watchers 13
I have in mind drawing each individual frame for HMS Lenox. Based on great book by Richard Endsor - "The Restoration Warship". Great publication, which I bought years ago in Portsmouth Dockyards.
Anyway, plans included in the book are great but what I am missing are waterlines. I have station lines, side plan, but no waterlines.
Station lines show around 20 bulkheads, which is mor that enouch for POB.
I would like to draw all the frames in between, let's say 40 or 50 depending on the hull.
As I said, I do not have waterlines drawing. How can I start here? Old way with pencil and paper - no CAD.
Has anyone done that?
My first build in the 80's, I put carbon paper under the drawing and traced the frames....slow and tedious.
Now, with a home copier. Make copies and cut out the frames. They can be glued with elmers rubber glue (link below), right on your frame blanks.
Rubber Cement on Amazon ....cheaper at Walmart or a craft store.
From there, you can use a jigsaw or drum sander to shape each frame.
Good luck and have fun!
Brad, you beat me to it. :) The station lines in the body plan are usually enough for POB so copy, cut, paste and sawing them out is quick and easy I would add that while gluing works well it is a pain in the neck to get rid of the residue.. I have gone to printing onto label paper, then cut, peel and stick on the plywood. There is little if any residue to worry about on the bulkheads.
I learned how to do it 63 years ago in Naval Architecture 101 at the University of Michigan. I’ve been doing it to build models ever since, No CAD.
First, you need the spacing of the various body plan sections. From the little bit of the drawing that appears on the right hand edge of your post, you have a profile (aka sheer) view that should provide this information.
You’re going to draw a top (aka half breadth view). Begins by drawing a centerline, and a parallel line offset by the half breadth of the keel. Now construct vertical lines (perpendicular to the centerline) upward from the centerline at each body plan location shown on the sheer plan. Length is unimportant; make them plenty long.
Now select a waterline and measure the distance from the centerline as shown on the body plan. It’s helpful to use strips of paper called “tick strips” to record this information. Plot each distance measured for the waterline on it’s respective body plan section vertical line that you drew above.
Now the fun part. You need to draw a smooth (aka fair) curve through the plotted points. Naval Architects have specialized tools for doing this, but you’ll have to improvise. Buy the largest French Curve that you can find, and rip a flexible wooden strip. Spruce is ideal, and maybe 3mm x3mm. It needs to be longer than the plan view that you are drawing. Start by springing the wooden strip through the points that you have plotted. In the absence of special drafting weights you can secure it with fine nails. Draw the waterline. For sharp curves at the bow and stern you can use the French curve.
This is the basic system don’t hesitate to ask questions.
Roger
Hi Roger,
I remember the days of drafting as part of in naval architecture studies, but this seems like a lot of unnecessary work for a POB build. Is there any advantage over just copying and cutting the station lines from the body plan as described above? This is assuming the copies are to scale, which is not a big deal to check if a small known scale is attached or drawn on the plans before making the copies. Worst case is the drawings are 1:96 and the builder wants to go 1:48. In this case it is just a matter of going to a copy service store and tell them the scale you want.
That’s up to the guy who asked the question. He asked how to plot waterlines. I told him how I would do it. I agree, it would seem that there is adequate information on the body plan view to cut out the various POB bulkheads.
Roger
there are waterlines in the book
i might have the wrong book by Richard Endsor the title is not what the video shows there are 2 different books
You'd need to develop the "looking down" waterline curves if you were building a solid hull model built up of lifts. Otherwise, the body shape stations on the plan are all you'd need. One issue with using these old lines drawings is to be clear whether they are drawn to the inside or outside of the planking,. Sometimes the scale of the drawings and the scantlings are such that plank thickness can be ignored as negligible, but adjustments will then have to be made as required in the thickness of the keel and the rabbeting so everything comes together there in the ends.
i checked David Lyon Sailing Navy List
there are no drawing for the Lenox as close to what you can get is the Dublin class 3 rate 74 gun ships where the Lenox is listed.
plans are as follow lines/profile/orlop/gun deck/upper deck/quarter and forecastle
so i would suggest you order the plans at least you will have waterlines to start with
I have in mind drawing each individual frame for HMS Lenox [...] but what I am missing are waterlines [...].
Waterlines are not particularly relevant to achieving your primary goal of multiplying the frames. Diagonals are much better for this purpose, as they yield a better, more even distribution of coordination points along the length of the frame contours, and being bent only in one direction are easier to form than waterlines. In fact, waterlines normally only serve a verification function, unless you also want to calculate (manually) the volume of the hull.
In addition to the diagonals that are on the base drawing (if there are any at all), you can also add as many more diagonals as you want, based on the contours of the existing frames. Overall, this is a trivially easy and fairly reliable method without resorting to old design methods, but quite tedious for such a large number of frames.
All other things, such as the type of paper and brand of pencil, are up to you, but I would advise you to stay focused on this task, because any inaccuracy or shortcut can come back to haunt you many times over and in a painful way. Besides, by following this procedure, you also have a chance to verify the accuracy of your base plan.
Roger
Are there any examples of this process where I can see what is being described? I'm trying to visualize the steps being noted. Thanks!
I'm Rubbish with computers, but been pretty handy with pencil a paper since I was 5 y o. Producing the skeleton for a build is pretty straightforward, all tou need is a line and a sheer plan. You have the station lines on the sheer plan so the rest is pretty superfluous. You can download Greenwich drafts for free and then enhance them with a suitable AI program, plenty of free downlaods for this....But....On some plans the apparent station lines are NOT the positions for the framework/bulkheads, or to put it another way they are not stations (I have no idea what they are therefore actually for?) The station lines only become visible with a proper copy of the plan from NMM. HM cutter Diligence is an example. I'd produced plans good eough to work from and almost completed the framework assembly when I realised it wasn't going to work. So I bought a plan with the proper stations on it, these were so faint on the download they weren't noticable. So, from now on I'll buy a copy!
On this plan The actual station line corrections are drawn in red.
The Lenox that Jerzy is after is ~100 years older than Dublin.
Translation can be far from exact.
To be really technical and pedantic = western wooden warships did not have bulkheads. What POB actually uses are molds.
Most often the station lines define the shape of these molds.
It is not near as irritating when station shapes are called bulkheads as it is when the POB molds are called "frames" They are anything but frames.
I just finished plotting frame shapes using a raster drawing program. I copy - rotate 90 degrees - move each point into place on the grid . I use curve segments of the closest shape to connect the dots.
With me, a French curve on a drawing board to connect three points produced a sui generis curve. It was not a derivative.
In CAD an equation defined the curve. It was also sui generis. I just cannot freehand an acceptable curve. Snipping a previous curve segment and sliding or scaling it to get something that looks related to the known curves on either side works well enough for me. It is all just a suggestion anyway. The final actual shape of the wood comes from working the wood.
There is a classic textbook oft recommended when this subject comes up. A search here or MSW should get you the title.
listed
Lenox 1678 - 1721
no plans listed for any of the third rate two deck ships
Lenox 1701 - 1721
no plans for the Lenox only body plan for the class
Lenox 1723 - 1756
no plans for the Lenox listed in the third rate two deck class lines and profile Northumberland and the Berwick
Lenox 1758 - 1789
no plans listed for ships only for the Dublin class 74 gun ships lines and profile
depending on which Lenox if it is the Lenox 1678 - 1721 there is nothing to build a model from there are no plans for any of the ships listed.
Lenox 1701 - 1721
if this is the Lenox at least there is a body plan but this body plan is not the original Lenox in the first original ships so it might be the same or not. But it will work for the 1701 to 1721 Lenox.
At this point according to the Howard Chapelle the Lenox is one of those ship that should not be built because there are no drawings nothing to built from
but for the second Lenox what i would do is take the body plan and do what shipwrights did and build a half model then slice it up like a loaf of bread and trace the patterns.
HMS Lenox 1677, ordered by Charles II. 70 Gun third rate.
Plans based on the book "The Restoration Warship" by Richard Endsor.
I am already deep on the subject.
At this point according to the Howard Chapelle the Lenox is one of those ship that should not be built because there are no drawings nothing to built from it is all made up.
Hi Dave,
I don't think Chapelle was referring to the work of Richard Endsor as The Restoration Warship was published 34 years after Chapelle died. Richard Endsor provides a page of sources he used to prepare the plans and drawings. He explains that there are no contemporary plans of Lenox per se, but other sources are available that would yield a reasonably accurate set of plans. (See page 31-35 of The Restoration Warship.) Examples he provides include a contract for a 70 gun ship of the Samuel Pepys 30 Ship Program of which Lenox was a part. He gives a number of other sources as well. For the body plan he used the work of Thomas Fogge, The Bends of a Ship, for a third rate circa 1680 which, most likely related to the 30 Ships Program. Based on these drawings and published dimensions for the program's ships plus the many other sources he researched, saying he made it all up does not seem reasonable. There is no way to know if a model will be an exact replica of the actual Lenox, but with the use of the researched materials and drawings by Van de Velde, it has the possibility of being a reasonably accurate rendition.
