The Portuguese »patacho de guerra« 1616 — ships’ drawings are born
It is also worth noting that the amount of numbered frames on both sides of the master frame (in this case, 16 on each side), which determine the placement of both quarter frames, is fully consistent with the recommendations of Fernando Oliveira from 1580, i.e., it is equal to or slightly less than the length of the keel in rumos (in this case, 17 rumos). Of course, in order to maintain the overall consistency of this way of determining these positions, the scantlings of the floor timbers and their spacing had to be standardized.
Waldemar, do you think this segment could be interpreted in some other way?
[…] quando quizeres repartir a forma, & pera por a madeira da conta repartirao em cinco partes nas duas porao a madeira que serao dezaseis pares galivarao tres num ponto
The more literal translation for it would be something like this:
[…] when you want to divide the forma, & to set the madeira da conta you will divide into five parts in the two the madeira will be set which will be sixteen pairs three will undergo the galivar process at a point
For those reading who are not familiar with the Livro de Traças, yeah... It's that confusing ROTF
Fernandes implies quite strongly that the forma, which means mould/form, is the thing to be divided. Also, forma could not refer to the master frame, but then, what could it be? In the text, Fernandes uses the word four times, twice as 'forma of the first futtock', and for the third instance, he seems to use it to refer to the multiple components of the master frame. That's to say, forma, in the above passage, could also refer to any of the timbers that make the master frame, if not the master frame itself. He says the madeira will be sixteen pairs, could that mean, 16 rather than 32 frames? Then 'pairs' would refer to the two notches either side of the rising wood (i believe that's what it's called) to which the frames are fastened. Lastly, only three of the sixteen pairs are to undergo the galivar process at some point, which I don't have a guess as to what that means in this context, and is something you also left out.
Looking forward to reading your thoughts on it!
Many thanks, Arthur, for your comment.
First of all, it must be said that one must be very cautious, but at the same time – which is inevitable – extremely flexible when it comes to the meaning of specific terms, which in itself is somewhat contradictory and, as a result, further exacerbates the difficulties of interpretation. In any case, this rather loose and ambiguous use of these old terms is particularly evident when comparing Portuguese texts on shipbuilding from that period. In addition to Fernandes' own description, I am also referring to the works of Fernando Oliveira and João Baptista Lavanha.
For example, the term “revessado” or “reversado” can mean both a fashion piece and the lower parts of the frames in the rear of the hull, or the term “côvado” can mean both floor sweep and just sirmark on the floor sweep, or “caverna (mestra)” can mean (master) frame or (master) floor timber, or a frame could also be called “madeira” or referenced as “a pair,” and in such circumstances, attempts to rigidly adhere to only one meaning of a given term can easily lead one astray, and it is only the context of its use that proves decisive, and yet with the additional caveat that this context is not necessarily always clear at all, especially when one takes into account the almost complete lack of punctuation, the crazy, archaic syntax, or the author's mental shortcuts.
The term “forma” also fits quite well into the above scheme, and can have a whole range of diverse, more or less synonymous meanings, and here, in Fernandes' description, it can mean both a complete set of “templates” or “moulds” for the entire frame, consisting of several elements, as well as individual components of this set, such as “forma do braço,” meaning “futtock template.”
In this excerpt from Fernandes' description, which you quote above, in my opinion, the division into five does not refer to the number of components of the entire master frame template set, but to the dividing of the hull length for the allocation of numbered frames, for at least three reasons:
— first, three templates are sufficient rather than five in the geometric arrangement of the master frame of the patacho. This naturally refers to one side of the hull (it is unlikely that two sets were used separately for both sides of the hull, as this would have made it even more difficult to maintain the much-desired symmetry). So, apart from a possible template for bottom/hollowing curves applied later, these would be moulds for cavernas, braços, and hastes (floor timbers, futtocks, and toptimbers, respectively), partially overlapping each other. Admittedly, there are also aposturas (2nd futtocks), but here they are essentially of the same curvatures as braços and hastes,
— secondly, if we assume that this division into five would nevertheless refer to the number of components of the frames template entire set, and not to the division of the keel into five parts, then the next passage, i.e. “nas duas porao a madeira” (or, in English, “in the two the frames will be set”), would remain without context and meaning,
— thirdly, finally, analyzing this draught graphically, I found that the markings made by Fernades, indicating the placement of both quarter frames, are located quite precisely in accordance with the division of the hull into five parts, as shown in the graphic below:
It should come as no surprise that the term “a pair” can also be problematic. Here, it can mean either 2 x 16 frames, i.e. 16 on both sides of the master frame, but it can also mean 16 frames on one side of the master frame, because Portuguese shipbuilders used the term “a pair” to refer to a complete frame (i.e. more in the sense of the English “bend”). “A pair” because it consisted of two layers of timbers laid alternately (floors, futtocks, toptimbers), alternatively, this term could also express the arrangement which in English is expressed by the term “timber and room” or “room and space.”
The “notches” at the contours of the frames, on both sides of the keel, which you mention above, are nothing more than “côvado” in the sense of sirmarks on the bilge sweep.
It's very good that you noticed and mentioned this, because it forced me to rethink the issue, including refreshing my memory of Oliveira's O Livro da Fábrica das Naus, ca. 1580. Admittedly, I had already suspected that it might be about three central frames that are not subjected to transformation as applied to all the other frames. In effect, they rather form the so-called “deadflat”, without applying rising and narrowing for those three frames, but now I am more certain of it.
The thing is that the (base) “point” was then called the point lying on the flat of the bottom (in the design sense), and the use of “deadflat” itself is described as normal practice in Portuguese works from that period and, depending on the size of the ship, may include, for example, three or five central frames. This does not make a very notable difference to the shape of the hull, but it does occur and, naturally, must also be taken into account in this project.
As it turns out, Fernandes' patacho design seems to sport a “deadflat” three frames long, covering the master frame and two adjacent frames. In total, there were 33 numbered frames, however, the latter is literally stated in another passage of the text, not yet quoted.
Waldemar, admittedly, I can't think of an explanation where dividing the master frame into five parts to then, on, somehow, two of those, set the madeira da conta, would make sense either. The wording Fernandes chooses is, nevertheless, very weird. In order to refer to dividing the madeira da conta, instead of the forma, in portuguese you'd expect a pronoun to be used, something like "para pôr a madeira da conta, repartirão esta em cinco partes". The way he uses the present tense repartir and then uses the future tense repartirão, would also indicate that the latter use is referring to the first. But, it is very much likely that I'm commiting a linguistic anachronism. And, given how the whole text is an attack against the reader, I think your reasons are very much compelling.
That passage that gives 33 frames in total for the madeira da conta definetely confirms that pairs means 32, instead of 16, I had forgotten about it! Or, rather, without your posts in this thread, I was too lost on the whole madeira da conta issue to minimally understand it o_O. But then, could that mean six deadflat frames as opposed to three? So, three pairs. Which would actually make for seven deadflat frames, counting the master frame.
And, given how the whole text is an attack against the reader [...].
Excellent :)! That really made me laugh :)!
As for the length of the ‘deadflat’ measured by the number of frames, fortunately this feature does not require some vague interpretation, as it is made quite clear or confirmed by another, yet unquoted passage from Fernandes' text:
[...] quando quizerem embaraçar the madeira de conto no chao [...] & isto se entende na almogama de proa vir multiplicando da caverna mestra a tee a almogama [...] repartindo em partes que sao quinze pontos tirados na mea lua [...]’ (in English: ‘when one wants to join the [parts of the] numbered frames [still] on the floor […] this is to be understood in the direction of the fore quarter frame, by multiplying [i.e. rising and narrowing] from the master frame to the quarter frame […] according to the fifteen divisions obtained by the mea lua [...]’).
In other words, the shape transformation is applied to the last fifteen frames out of sixteen on this side of the master frame. As a result, it follows that three frames remain for the ‘deadflat’, i.e. the master frame and one adjacent frame on each side.
