Help with a museum restoration. Can anyone identify this model?
Hello . I have volunteered to do some restoration and repair work for the museum at Bucklers Hard in the New Forest near my home in the South of England. This is the current project before I make a start on her.
Can anyone identify the ship ? It is very well made by an obvious craftsman, but is very dirty and the rigging needs a lot of repair.
There is no name on the stern or the base.
The previous repair on an HMS Swiftsure frame only model was straightforward . I had to repair some broken frames and manufacture a missing one, But this will take a bit more time.
Thanks shipmates.
There are a number of oddities on this model. A.) The wheel is mounted on the barrel instead of on the other side of the pedestal, leaving no room for the tiller rope, B.) Battens are running athwartships on some of the gratings, which was not done. C.) Mitered corners on the head ledges and coaming pieces instead of the way they were actually built. I wonder why the museum has an interest in a model with such basic mistakes.
B. Gratings on HMS Victory as example
C. Example of corner construction
Looking at the model as a whole: it is a lot more detailed than most decorator kitsch but it looks to have more in common with kitsch than it does with an accurate scale model. It may be sailor made but wouldn't its possible value to the museum be more with who made it and what his history was?
I have done very little masting and rigging, but the yards - are they over scale? Are some of the rails over scale?
When did the use of gunport lids stop being used? I think they went to only lower half lids sometime in the 19thC. for the top deck.
Perhaps this was just a generic model with no specific vessel or era in mind. Another possible anomaly--- The cannon are bronze colored. Bronze cannon were common into the 17th century and they were still found into the 18th century, HMS Victory 1737was the last major Royal Navy warship to carry a full complement of bronze cannon. On the other hand there are belaying pins on pin racks on the bulwarks. Belaying pins were first used on English ships using racks tied to the shrouds starting about 1745. Their placement on racks on the bulwarks began closer to 1775. This makes it even harder to come up with a time period and thus any specific vessel. Can you post a close up photo of the cannon? The patterns were pretty specific for given years so their pattern may help narrow things down to a specific time period.
Thanks
