HMS Alert [1777] 1:48 POF by serikoff. (Two hulls: skeleton and fully rigged)
According to the anatomy drawings, the hold grating has a specific number of combs. By calculating them with a pitch and a size of 1 mm (precisely the right number), my grate ended up slightly smaller. I didn't mind, since the ship is already small. I thought there would be more space on the deck, but... it wasn't the case. Once I'd finished it, both in terms of the entire deck and the size of the sailor (figurine), I realized it was still a bit small...
I had to add another comb to both the width and the length (for proportion) and redesign the grating.
All the manipulations are practically the same as before, but I changed a few things to speed things up and simplify things... In particular, I defined the shape of the arch right away and then milled around it.
Due to constant power outages (war, shelling of our power plants...), I didn't notice that the cutter was pressed against a drop of glue and accidentally turned on the router... -8 euros...
I will move the beam line a little back, and the rear support for the boat will be a little further from the mast, and will be more symmetrical, as it should have been originally.
And even though the grate will be barely visible under the boat and behind the supports, I'm still glad I redesigned it.
And the smaller one I made earlier will be used in the installation for the first skeletal hull.
The idea is this: the skeletal hull will be on a stand with frames and minimal planking. The deck will be laid out without planks. On it will be the frames without grates and windlasses, but without the gun carriages and cannons. And on the base plate of the storage box, I'll place the stove as a separate element, the gun carriage (maybe all 12, or at least one or two), and the anchors. Ropes will extend from the anchors and lead to this grate... and the ropes will dive into the rope holes. That's the idea. To show the hull as transparently as possible, but also to show what was inside it, but nearby on the plate...
Mast and bowsprit.
Since I still haven't bought a lathe and need the parts now, I decided to make them myself. To do this, I first need to mark out the trapezoid shape from a rectangular blank.
Then, using an angle grinder, I make trapezoids from the rectangles, but so that their dimensions are 2 mm larger than the finished parts and, naturally, longer.
Then I mark the axles and screw in a screw on one side to secure the bearing I'll be holding. On the other side, I make a taper to fit the screwdriver.
But before the "turning work", if you can call it that, I first make an 8-sided polygon with a plane, then a 16-sided polygon, and bring the part closer to a cylinder.
Then I do as shown in the photo below. The key is to ensure the rotations of the screwdriver and grinder counter-rotate to achieve greater friction.
The method is, to put it mildly, specific, but the main thing is that the working friction zone is as in the photo below.
Just like in the good old days, I do everything on my knee)))) But here is the result:
By the way, this is my second attempt at making a mast... Initially, I made it out of dark pear wood and miscalculated the thickness, so I had to remove a little more than half a millimeter...
... and it would seem that half a millimeter is nothing, but feel the difference in volume.
I had to redo it, but I'm glad I did, because I didn't really like the dark version. It was spotty and had a pronounced pattern. But the biggest drawback is that dark pear wood is much more flexible than light wood. The bowsprit, which is thinner than the dark mast, is much stiffer. And this is important here, because standing rigging can significantly bend soft wood.
Especially since this will be the sixth shade of pear wood (in addition to the five already available) that will be used on the model.
Next, I aligned the bowsprit horizontally in a milling machine and made a square piece measuring 10.1 x 10.1 mm, which is a 1:48 scale. By the way, the deck will be 11.1 mm thick. I will update all the dimensions and drawings in the corresponding thread about this ship's rigging.
I didn't bother with the square section of the mast, as I didn't need it for the deck. I tapered it at the bottom so it would fit into the aluminum cylindrical holder inside the hull. First, I determined the center (axis) and mounted the mast on a milling machine, securing it at three points.
This method isn't suitable for the finished version; the milling cuts are wavy, which I filled with putty. But this section will be inside the hull and won't be visible... and the most important thing for me is to maintain the alignment of the axles, and I succeeded. The mast is vertical along the side.
The bowsprit is still longer and the frames need to be reduced so that it fits evenly, but I put it there to visualize the dimensions.
Next comes the anchor mechanism... and then we can finally set up all the nail positions on the deck.
Brilliant!
Brilliant!
what a impressive method
Your skill and attention to outcomes are unmatched, Sergey. Respect.
Your work is beyond impressive and then add the adverse working conditions it’s truly fantastic.
Sorry about the broken end mill… :(
Friends, thank you so much for your very kind words! I can't wait to show you more and more new processes.
I haven't finished working with the bolts yet, but I've already started making the masts, and now I'll finally show you how to work with metal.
There are so many tricks and tips, and I'll share them all with you.
And also about the patenting and blackening... I can't wait to work with the rigging, but I'm getting ahead of myself... I'm really impatient.
Rudder feather.
I'm continuing to work on the rudder. I started it before; you can check out this link.
I made the rudder, like the stem and sternpost, using two colors of pear wood (dark and light).
Marking, contour milling, profiling... well, the photo should make it more than clear what I did.
That's pretty much it for wood; the most interesting part comes next – working with metal. That's a whole other topic.
Rudder feather.
Your work on this project continues to be world class !!!! Salute !
Not to mention that, anatomy-wise, a small boat doesn't correspond to common sense or reality (but more on that later), and there's simply no room on the hull for a cutter that's the right size for this ship.
Hello Sergey,
have a look in E.W. May "The Boats of Men of War". There is the information given, that cutters have until 1783 one boat and later 2 boats. A 18ft cutter was the boat from 1781 on.
Another tour de force in modeling excellence, Sergey!
Thanks, Paul. As always, it's great to hear your praise!
I'm glad I'm keeping up the good work; things will get much more interesting in the future.
Really wonderful result. I simply love it
Hello Sergey,
Thank you very much. Thank you for the information, this is an important topic that I will return to again and again.
Finaaaally... I finally finished securing the bolts...
I sped up the process a bit, but it still took another 6 days...
In total, I installed almost 1,850 bolts on the clinker cladding!
Yes, it doesn't seem like much, but considering that each bolt had to be fabricated, installed, hammered in, and...
...and round the top a little with a special cup burr (by hand)... that's not so little... especially time-consuming.
And here's the result:
Well, and more importantly, this is macro photography:
In the end, I'm quite satisfied with the result.
Yes, not all bolts are 100% identical, but given that these aren't bolts in the traditional sense... they're more like rivets, the repeatability under the original conditions was the same.
I was away longer than usual, and not just because of the bolts.
At the same time, I was working on another very interesting topic... I don't want to spoil it... but it has to do with working with metal. I'm currently preparing a huge thread on this topic, and if it works out, it will be a real breakthrough in optimizing and speeding up work with complex metal parts, especially those that come in large quantities.
Ship-1
Ship-1
Wow ! What a wonderful result !
By the way, it's perfect that they are not all the same. They were not manufactured like the ones of today, but each one was separately fabricated by a blacksmith so they would be different from one to the next. :)
Ship-1
You did a great job with a beautiful result, Sergey.
Majestic! A heroic effort, Sergey!
Thanks, Paul. It took longer than I expected, even without considering that I originally made the bolts out of brass, for some unknown reason. But I like the copper ones after they oxidize because they blend in with the trim and don't stand out.
Thank you. Yes, you're right. The bolts weren't factory-made, and after riveting, they had a unique shape. But I still wanted to make them as similar as possible, and I hope that worked out.
Wow, the klinker planking is looking great.
Thank you. Ahaha, when I finished the copper cladding on the Victory, I swore I'd never do that again. Now that I've finished the clinker planking, I've sworn I'd never do that again. What's next? )))))
Thank you for the highest praise, the most difficult part of this stage is behind us, now the main thing is to decorate everything beautifully in oil and bitumen, and this, in my opinion, is even more difficult, so as not to ruin everything.
Wow, wow, wow .... I sell my Alert Kit I guess :-D
Thank you))) No, no! I would really like to see your future project, Alert. They build so little of it now. And with your execution, I'm sure it will be very beautiful.
Oh my gosh, what an amazing result. Incredibly good, and the description too. Respect for such model building. Thanks for showing us.
Thank you for the high rating. I'm trying to explain things as clearly and thoroughly as I would like to be told. Before building, I reviewed everything related to the Alert online, especially on this forum. I'm glad my review helps with building this ship and others, as the key points are often similar.
