• At some point from current UTC of 19:40:30 Thursday up to UTC 19:40:30 Friday, it is possible the forum might be disabled for a short period of time for updates and upgrades. Another notice will be posted for status. Note: Central Standard US time would be 14:40:30 Wednesday up to 14:40:30 Thursday
The GRACIE S - a Lift Model
Seems like I'm at one of those modeling dilemmas - do you add certain details, cover them up and feel good they are there; or take the view - if you can't see it does it really matter its not there!
To my way of thinking regarding scale details, "If you can't see it at scale viewing distance, it really matters that it's not there!" I think it's always better to omit a detail than to include one that is over-scale. As for copper sheathed bottoms, depending on the scale, at 1:48 and below certainly, it's not so much a matter of miniaturization, but rather artistry. The object is to very subtly "suggest" detail which invites the viewer's brain, rather than their eyes, to form an impression of the vision the artist intends to convey. Sometimes all it takes is a bit of color or shade mottling to do the trick. The mistake many kit modelers make is letting their brain get ahead of their eyes: "I know these things are separate plates covered with a bunch of nails so I've got to show them." Considering that so many kit builders' experience with viewing coppered hulls comes from the picture of the model on the cover of the box, it's no wonder it's downhill all the way from there. :(
The ship modeler really should try to follow the lead of fine arts painters in the way they create the impression of depth and distance on a flat canvas by varying colors and the sharpness of details. There's a lot about how to do this in fine arts painting textbooks, as well as online. When it comes to copper sheathed hulls, the modeler should ask himself, "How would an oil painter portray a copper-sheathed hull at the same scale viewing distance on a flat canvas?" (Hint: They would paint what they see at viewing distance, not what it looks like under a magnifying glass.
Since the hull will be painted, at viewing distance for this scale, the chances of seeing hull planking is slim - and of course the lower hull being coppered, covers up anything that had been done below. Seems like I'm at one of those modeling dilemmas - do you add certain details, cover them up and feel good they are there; or take the view - if you can't see it does it really matter its not there!
i pondered the same issue as i approach what to do with the deck on the Sir Edward Hawke. So do i plank it over and cover the beams, joinery and knees? after all the deck "structure" is an interesting thing to show. What i decided was in the build i show the structure and no one will ever see the actual model it will just end up on a pile with the rest of the models. I documented the structure in the building process, so everyone saw it and knows it is there. Like an ice sculpture now you see it now you don't.
If you are teaching then at least discuss the underlying structure, if it is a display model then it is up to the builder what to show or not to show. My opinion is if it will be covered up in the final model the skip it.
we just invented "modeling in the gray area" the twilight of actual scale and artistic expression. Take putting treenails in deck planking if using way over scale treenails the deck approaches a cartoon look full of little dots. But there might be a possibility of reducing the dots as small as possible, still over scale but not overwhelming. My guess the models we all build well not be viewed by experts in ship modeling or the art of ship modeling, they will be viewed by average people with little knowledge of ship building or what a model should look like.
If a viewer has no idea of what exactly they are looking at or leaving a blank for them to fill in unknown detail they are left in the dark. But using artistic expression and giving them an idea of what belongs in the blank maybe some will think hum? looks out of scale or if you have a critical artistic eye may see it as out of balance. Perhaps to some it is obvious planks are nailed in place and no need to show that. Someone else my look and say WOW look at all the tiny nails used god that must of been difficult.
Made it down to the basement today and continued the smoothing / shaping of Gracies's hull. Getting close now - see how the paint at the lift intersections are getting very thin / starting to disappear. Where the line is nearly gone, I do not want to sand much at all right now. Where the black is wider, more work is to be done; however, it continues to be important to remember that the hull surface needs to be a continuously smooth surface in all directions.
Getting even closer! (I need to spend more time in the basement and get this done!)
I did want to note that once the lift lines start to disappear - they disappear fast, maybe faster than one would expect - so a great deal of care is needed to not over-sand at this stage.
Sanding is a blunt tool.
It may be time for this?
1757_mini_scraper_set_300.jpgcarbide burnisher.jpgStewMac_Ultimate_Scraper  mini.jpg
The luthier's mini scrappers are reasonable at Peachtree in Hatlanta
The small carbide burnisher is Veritas - Lee Valley, not outrageous for them
The StewMac Ultimate Mini Scrapper is a bit dear, but it is on a whole nuther level as a scrapper
StewMac has a mini bench grinder best ignored
1) Temu sells the same model for much less. Even then - it is overkill
2) We are not mass producing string base so a small sharpening stone will probably be all that is needed to get a burr edge for our lifetime.
Found time between snow blowing to continue with the hull shaping today. Note how the lift lines are mostly gone mid-hull as I work from the middle both fore and aft. At this point I am using 220 grit sandpaper.
Yellow Poplar is a great wood to work with for larger things like the Gracie hull to scale hull planking and small details. Other woods to consider when building a solid hull are Basswood and Alaskan Cedar both woods are soft and easy to work. However, for small model work both these woods are too soft. A fingernail test if you can dent the wood with the pressure of your finger tells you the wood may not be the best choice when it comes down to small parts and planking.
Here is Basswood and it dents easy so it is not very strong when used for delicate modeling
same with Alaskan Cedar it dents easy and it too soft for finer modeling. Both woods are close to the same color so why use the more expensive Alaskan Cedar when Basswood works the same? Alaskan Cedar is not a substitute for boxwood even though it is referred to as poor man's boxwood. A suitable replacement for Boxwood is Pau Marfim
After seeing AYC in use, it has about as much character as Polystyrene. Pug ugly and boring.
In North America I see Hard Maple as being close enough to Castelo so as not to matter. A difference is that depending on the orientation of the cut, the grain pattern can be clear, flame, tiger eye. A serious curve on the outer face of a frame can show some really interesting character. I can buy actual 8x4 for $6.00 BF and 4x4 for $5.00. If you plane it yourself you do not need to lose 1/4" to get to a smooth surface.
The North American substitute for European Pear is Black Cherry and it is 8x4 for $5.00 and 4x4 for $4.25.
Even better Yellow Poplar 12x4 is $4.00.
To save on being cheated, if it ain't an actual Buxus species it is not and should not be called Boxwood.
I would like to get a supply of Lancewood for spars - Cuba, are you listening?
i had a bunch of pieces of lancewood also called lemonwood i need to search for it. it was imported by billiard cue makers.
Dogwood and firethorn (pyracantha) are used as a replacement for boxwood
Dave, If you can find the Lacewood, I understand that it is good for masts and spars. I have the equipment to cut it.
Roger
Like most wood species, there is often a variation in quality. I've seen pictures where it looks good, some where it doesn't. Actually, I have a good size billet of Alaskan Yellow Cedar that is quite firm and has a nice color - I've been holding on to it for the right project. At some point I am to make a Mackinaw boat and this may be where it gets used. Certainly, the AYC was more costly than say the poplar being used here for Gracie - so not a wood I would use for a purpose where it was going to be covered up.
