- Oct 2, 2025
Bob,There are limitations in terms of the torque forces one could apply to the vise mounted on a tee track, since the tee-track is doesn't have a lot of strength for side loads, particularly if applied to a "lever" created by the height of the vise.
I am not advocating this - just as a possible way to make it work.
Have a plywood pad under each of the two C-clamps - size and thickness TBT. Attach the C-clamp to the pad with a flat head screw/bolt that is the same diameter and TPI as the threaded rod that advances the clamping pad. Counter sunk.
Easy hold. A wide enough pad should be as resistant to torque as the C-clamps on a table edge. More than one T-track traveler - it is just a matter of drilling another 1/4" hole.
