HMS Endeavour 1768 1:60 by Artesania Latina
Adelaide, South Australia
The kit had been in storage for years and this is my first timber ship modelling experience.
So it begins...
The supplied instruction booklet can be downloaded in pdf format from the Artesania Latina website homepage link to ‘Old instructions’.
The parts list details the reference number, description, quantity, size and material of each part.
The timbers are specified for each area so I sorted and grouped them by size and material to help ensure the right ones are used.
The kit included a useful full-scale schematic of the model’s longitudinal section and there are some other schematics that no doubt will be needed further down the track.
frames and hold decks
The laser cut frames fit well but, likely due to long time storage in less than ideal conditions, there was a noticeable curve in the false keel.
I kept this in mind when fitting the main decks to try to straighten things up a little.
Centre lines were marked on the hold deck pieces then the 0.6x5 Mukali strips were glued in pairs from the centre out.
The hold decks were glued into the slots but were easily dislodged so I added some reinforcing plywood pieces under them.
main decks
The main deck pieces were marked out with centre lines and frame locations then glued and nailed on.
Started planking the main decks in pairs of 0.6x5 Mukali strips from the centre line outwards.
Hey, das passt ja perfekt! Ich habe mir gerade bei einer Auktion von Artesania eine Endeavour ersteigert. Gleiche Größe, sogar eine ältere Version ohne Laserschnitt.
Da ich aber gerade mit dem Rigging für eine Victory von Corel beginne und außerdem noch meine Küche renovieren muss, wird sie wohl erst einmal auf unbestimmte Zeit im Regal verschwinden.
Ich werde also deinen Aufbau verfolgen, um mich mental vorzubereiten.
Grüße nach Australien
Übersetzt mit DeepL.com (kostenlose Version)
Hey, congratulations on winning the Endeavour kit. Good timing!
Good luck with your Corel Victory rigging and your kitchen renovation.
I hope you will find some helpful comments in the build log.
Grüße nach Deutschland
Hallo Noel,
Als ich den Victory-Bausatz bekam, war auch ein teilweise zusammengebauter Endeavour-Rumpf enthalten. Dieser sieht allerdings etwas schlecht verarbeitet aus, daher werde ich ihn nur zum Biegen der Formteile verwenden.
Ich habe bereits andere Bauberichte gelesen und dabei ein Problem festgestellt, das Sie leider auch haben. Ich dachte eigentlich, dass dies in den neueren Bausätzen behoben worden wäre.
Die Aufnahmen für die Masten sind weder im falschen Kiel noch im Deck vorgesehen, was sich von den Schiffen unterscheidet, die ich bisher gebaut habe.
Artesania plant dies tatsächlich erst viel später, was zu erheblichen Problemen führen kann.
Da dies Ihr erstes Holzbauprojekt ist, würde ich Ihnen empfehlen, dies jetzt zu tun, bevor Sie sich später ärgern.
Viele Grüße, Ralf
deck planking
The deck planking went reasonably well though some tended to curl up on the edges. Weights and clamps were used where possible.
aft counter
I realised the aft counter was placed too low to meet the underside of the deck, it was cut off and re-glued then screws were added to hold it in place.
The deck still wasn’t quite level so a shim was added for support.
Some information about fairing the frames suggested to mark the outer large edge of each frame with a felt-tip pen to make sure not to file that edge.
The other edge was to be filed to follow the curve to the next frame so that a plank would naturally bend from frame to frame.
This worked out ok until it got to the aft counter which was around 10mm narrower than the deck, it looked as though the planks would have to bend too much to reach it.
I pondered this for some time and ended up adding shims each side of the aft counter.
The transom support piece is wider than the modified counter so it will become covered up.
mast supports
The instructions show the mast support holes being drilled after all hull planking has been completed however, as Ralf recommended, it is easier to drill them at this earlier stage.
The masts are slightly raked back at the angles shown on the detail schematics as Mizzen mast 87.5°, Main mast 88° and Fore mast 89°. At first glance they appear to show angles relative to the decks but it was confirmed on the longitudinal schematic that they actually show relative to horizontal.
The angle relative to the deck for each mast was measured from the longitudinal schematic as Mizzen mast 82°, Main mast 84° and Fore mast 89°. Template blocks were cut at these angles and used to align the drill.
Brad point drill bits were used to make clean and precise holes. Drilling was first started anti-clockwise by hand to score the plank veneers and prevent tearing.
hull planking
The planking timber is 1.5x5 Samba, pale yellow colour and quite soft.
Each plank was curved to fit the frames while dampened with water and clamped, with some heat applied from a heat gun.
For lateral curves it was clamped flat and the aluminium foil was put there to protect the top of the bench from water and heat.
For lengthwise curves a jig made from scrap timber was used.
The Samba timber could be bent quite easily though it often took a few times to get enough curvature.
Several different kinds of clamps and pegs were used to hold the planks in position. They were held clamped against previous planks and also against the frames.
To prevent splitting the plank timber, nail holes were pre-drilled using one of the brass pins held in a hand drill.
The first few planks were glued and fully nailed then later I came across a build log that showed them only partly nailed to hold them in place.
These nails were removed once the glue had cured.
Planks were added in pairs alternating sides each time to prevent warping. Some medical gauze was glued on the inside of the planks for extra strength.
The wood block in the middle was put there to help straighten the false keel.
hull planking
The plank bends became more difficult as the hull curves became more complex.
It would have been better to put more stealers at the aft and start tapering the planks earlier.
plank tapering
For tapering, the gap between planks was measured around each frame using a strip of paper.
The planks are 5mm wide so the largest gap was divided by 5 to give the number of full width planks required.
The other gap measurements were divided by this number to give the ideal width of the plank at that frame.
An example from my notes:
The frames were numbered from 1 to 9 starting at the bow end.
Measured gap widths(mm) at each frame were:
Bow 1:108, 2:116, 3:117, 4:119, 5:122, 6:125, 7:122, 8:114, 9:110 Aft
Frame 6 has the largest gap (125mm) and so requires 25 full width (5mm) planks.
The gap widths were each divided by 25 to give the ideal plank width (mm) at each frame.
Bow 1:4.3, 2:4.6, 3:4.7, 4:4.8, 5:4.9, 6:5.0, 7:4.8, 8:4.6, 9:4.4 Aft
It didn’t seem necessary to try to shape each plank exactly so for this example the next few planks were tapered from 4mm at the bow end to full width at around frame 5, then from 4mm at the aft end to full width at around frame 7.
The frame gaps were measured again about every five planks.
The Samba timber tended to split when cut lengthwise with a scalpel so this jig was used to make it easier to file the planks to shape.
It is made up of three lengths of 20x1.6mm aluminium flat bar. The outer bars are aligned with the pivot bolt while the centre bar is set 5mm lower on the pivot.
The centre bar is swivelled up by the amount to be tapered and held clamped on the plank while the excess is filed off.
sanding
The fine wood dust from sanding the hull was collected to be mixed with glue and used as filler for the large gaps.
Plasterboard filler mixed with glue and water was used for the small gaps and rough areas to give a smoother surface.
For those planks that were fully nailed, the nail heads were punched below the plank surface and filled.
stem notch
I made a bit of a mess when filing the groove for the stem, trying to get the curved stem piece to sit properly.
The stem will be glued in next, and gaps patched up, so it can be used as a guide for the ends of the second planking strips.
A bit more patching and sanding required, then on to second planking.
Hello Noel,
It almost looks to me as if you started tapering at the wrong point.
I bought the kit because I already had a partially completed hull from Victory.
After reading your post, I took a closer look at it. I would taper towards the bow starting from the third frame. So far, I haven't tapered any of my ships at the stern, but rather worked with stealers, but it's up to each individual to decide what they prefer.
To be honest, I personally don't think much of measuring everything meticulously beforehand. I lay the full planks until I notice that they are standing up and then start tapering by eye and feel, which has worked so far.
I've also noticed that the middle frames 6-8 are obviously narrower than they should be. Either the builder of my hull mixed them up or AL lasered them incorrectly.
I can't imagine that this ship has a waist, but I could be wrong.
Good luck with the second coat and greetings from the snowy Palatinate.
Translated with DeepL.com (free version)
There is indeed a lot of tapering, but the taper begins at the edge of the dead flat near midships, not up near the bow. It is very easy to determine the taper if tick strips are used to mark out the hull at each bulkhead/frame. If you study some planking expansion drawings they will show the shapes of each plank. The below is of the HMS Squirrel (24) 1785. There are a lot of posts here at SoS on marking out the planking using tick strips as well as descriptions in various articles and videos on line. Some kit makers are still providing the old fashioned straight strips for planking instead of spiled planks but they can be shaped with water and heat to avoid the lifting seen on the planks as in the photo below. Properly shaped planks allow a firm seating of the plank to the bulkhead, all planks end at the rabbets fore and aft as they should and avoids a lot of sanding.
The dimensions are close but may not be exact as the drawing was in low resolution so not as precise as it could be. Still, the tapering is evident.
We've had one hull planking, yes. What about second planking?
second planking
Quite a bit of patching and sanding was required especially on those lifted planks at the aft.
As Allan pointed out, the planks should have been allowed to fall more naturally instead of forcing the bends so much.
A lesson learned and applied to the second planking.
The second layer uses 0.6x5 Sapele veneer which is reddish brown in colour and has a fine interlocked grain.
It was able to be bent using the same methods as the Samba timber and it could be tapered using a scalpel, though would tear when the blade became too dull.
The veneer planks were held in place on the cutting board with low adhesion masking tape and a steel rule held firmly to guide the scalpel blade.
I tried to minimise the amount of bending required by letting the planks lie naturally and adding more stealers in the gaps.
Drawing pins fitted with rubber pads were used to hold each piece of planking veneer in place while the glue dried.
Holes were pre-drilled to accept the pins and the rubber pads spread the holding force over a larger area.
Once all the full length planks had been laid, there were four toothpick shaped gaps remaining.
Some translucent tape was used to mark out the shape of the gaps.
I used medical tape, which was on hand, however it had some stretch to it.
There are likely better types available but it did the trick for the few pieces required.
The marked tape was used as a template to cut the shaped plank.
The shape was adjusted to fit using a small file and sanding stick with the plank held in a clamp.
The last piece ready to glue in.
The final plank in place with a delicious Tasmanian single malt whisky to celebrate.
Now things start to get more interesting....
I was pretty happy with the way the second planking turned out and was glad to have that finished.
There were a few small gaps to fill and some uneven areas to sand.
side gunwales
Using water and heat, the side gunwales were curved to fit along the decks and clamps were made to hold them in place while glued.
keel
The stern post and keel were fitted and some filing of the frame was required for proper alignment.
With the keel fitted it provided a good horizontal reference and the mast supports were checked against a board marked with the angles relative to horizontal.
The web in the bow was fitted and the instructions said to also fit the hammock nettings. The indicated two pieces described as ‘hammock nettings’ looked to be some kind of support for the bowsprit. The description given in German translates to ‘upper bulwark’ which made more sense than ‘hammock nettings’.
I decided to leave these off for now because they would need to be angled and shaped to fit over the bowsprit.
The top of the stem post was filed down to the approximate height and angle for the bowsprit.
waist rubbing strakes
The 2x2 Walnut waist rubbing strakes always felt about to snap when bending to fit the bow, extra care was taken with this. Clamps and rubber bands were used to keep them in place for gluing. From the AL photos it looks as though the rubbing strakes run around 5mm below gunwales at the bow and finish around 20mm below the stern gunwales.
transom
There is a lot of variation amongst the different kits and modellers with the placement and decoration of the transom.
Some modellers carve their own pieces to replace the supplied parts. As this is my first build I decided to do my best with the supplied parts.
The AL photos show the balustrade handrails going over the top of the transom. To allow for this, the top of the transom support was positioned about 10mm above the gunwales. This made the bottom of the transom support appear to sit too low, so a piece was cut off before gluing.
rudder
Masking tape with a 12x12 square cutout was placed over the 6mm hole for the rudder to mark where to carve out for the rudder head. The hole was filed out to allow the rudder to swivel.
anchor hawse pipes
The anchor hawse pipes were mounted up against the rubbing strake at the bow and the 4mm holes drilled.
They were angled upwards by about 10° to come out between the deck and the web
side gunwales
keel
transom
rudder
anchor hawse pipes
Good morning. Very nice indeed. Way to go. Cheers Grant
If the hull is to be coppered or painted, no need to read on.
I may have misspoken previously or at least was not clear. Straight strips that come with most kits should NOT lay naturally on the hull. It they do they will not all end in the rabbet as they should. They need to be shaped by spiling or tapered in breadth then forced around a jig while held flat for a good edge bend. Water and heat and the new shape will be permanent.
Sorry if I mislead anyone.
second planking
Very well done! that wisky plank must have been quite awkward to deal with. Regards, Albert
It's good to hear that the build log is providing some help.
Some of my methods may seem odd to the more experienced but finding a way forward is part of what makes it interesting and enjoyable for me.
transom
The waist rubbing strake had been glued and then had to be cut away again to fit the ornamental figures at the transom.
It may have been better to leave the end section of the rubbing strake unglued to allow for this.
main rubbing strakes
Leftover pieces of Samba hull planking timber were cut to 30mm lengths to get the main rubbing strakes parallel to the waist rubbing strakes.
hatch coamings
The hatch coaming pieces were notched using a small square file and then glued while held against a square edge.
The masking tape is mounted with the sticky side upwards to hold the pieces in place.
rail balusters
The rail baluster pieces (x34) were filed and sanded to provide a 2mm round mounting pin.
The block with the holes was used to check the pins fit. I settled on using a drill size of 2.38mm (3/32”) as 2mm seemed too tight and 2.5mm too loose.
mooring bitts
The mooring bitts (x34) were filed to shape then cut from 4x4 walnut.
baluster locations
The instructions say to follow the measurements in the top view diagram for placement of the mooring bitts and rail balusters however there is only a top view photo instead of a diagram. The photo doesn’t show most of them because they are hidden by the handrail. The longitudinal schematic does show most of them, some are hidden. The AL figures 25 to 28 show locations of the mooring bitts but not the balusters and they are drawn at about 3:4 scale of the model so measurements needed to be scaled up.
The baluster pieces have a vertical edge and an angled edge and it is not made clear which way around they should go.
The supplied instruction photos appear to show the vertical edge towards the mooring bitts.
The instruction photos from the newer AL kit (22520) show the opposite.
A diagram from the web also shows them angled away from the mooring bitts.
This may not be important and may just be for aesthetics but I decided to go with the newer instructions where the angled side of the baluster slopes away from the mooring bitts.
handrails
The handrail pieces were curved to fit the shape of the gunwales and held in place with weights while glued. I considered carving small hollows in the underside of the handrails to accept the tops of the balusters and so provide more strength but they held firm enough without doing this.
It may be a few weeks until there has been enough progress for the next post...
Perfekt, dein Baubericht wird mir irgendwann sehr hilfreich sein.
Ich denke, mein Bausatz wird noch etwa 3 Jahre warten müssen, bis er an der Reihe ist.
Gruß
hull pieces
The many small pieces were shaped and fitted for the culverin supports, fenders, threading blocks and side ladder.
side steps
The groove for the side steps was shaped using a file, I’ve seen where others have used a blade that has had the shape ground out to scrape the timber piece.
Tape marked out with spacings was used to align the side step pieces.
transom
The transom was finished off with the addition of the windows and strakes.
trimming channels
I was glad to see that the trimming channels had been supplied as die-cut pieces with the holes for the chain plates already marked.
The holes were drilled out to size once the pieces had been assembled.
The locations of the trimming channels were determined from the top down photo.
portholes
The instructions say to glue the trimming channels then cut out for the port frames however the cut outs were done first because it seemed the channels would get in the way and could get dislodged.
The instruction photos show the approximate locations for the portholes.
I wondered why the one on the side nearest the bow is shown located just below the waist rubbing strake whereas the other two on the side are located higher with the hinge replacing part of the rubbing strake.
My thoughts are that if the porthole near the bow was too high then it would be above the deck.
The instruction photos are not the best quality so it is difficult to tell for sure.
Some of the die-cast porthole frames were not properly formed and required filing to clean them up.
The porthole pieces in my kit were supplied as plain grey die-cast and not the dark bronze colour of other pieces so I decided to paint them so they wouldn’t appear too out of place.
side windows
The side windows were placed about 10mm above the main rubbing strakes except for the single midship one which was placed up against the side rubbing strake. Their locations are based on the AL photo with the expectation that they will accommodate fitting of the chain plates and links at the later stage. It may turn out to have been wiser to leave these off at this stage.
The next step will be to fit the rudder...
