Hms Granado 1/48 POF Bomb Vessel - CAF by Signet [COMPLETED BUILD]
I build the quarterdeck bulkhead as shown in the plans, but use thinner and smaller material for the vertical pieces. The decals went on fine, but are quite glossy. A few coats of Vallejo Mecha Matt Varnish dulled them down quite a bit. The outlines are still visible in this photo, but not so much in real life:
Even though I used Micro-Sol, I couldn't get the decals to meld into the planking. The half-doors to the cabin accommodation will be added on later and left open (but not hinged).
I've done the stern decoration at the wales line differently than the instructions show. The instructions show:
My problems were 1) I have been unable to produce the complex sections using the razor scrapers supplied, and 2) I felt unable to bend the 3x4 strip in 2 dimensions and glue it in place.
I bought some 1mm x 2mm double half round brass strip that I will use for the fancy section. I then cut a 2x5mm strip to use to replace the 3x4, and tapered it all sides to fit better. The little almost-triangular platforms that go on either side would be glued to this strip to assist in locating, gluing and securing the assembly.
Since the brass strip would be added later, the triangles needed to be larger. Here one's glued to the modified 2x5 strip:
I ended up remaking these triangles to be smaller later, but the procedure is the same.
With a triangle at each end, rubber bands can pull the strip and triangles into place for gluing.
The other clamps are to hold everything vertically.
This ends up a pretty secure assembly, ready for adding other decoration:
Speaking of other decoration, I haven't decided when to add this, but it's easier to paint off of the model:
If you think it doesn't look very good (as I do as well), you're sitting too close to your computer screen.
To be continued.....
Tom at CAF said he'd have a solution for me in a bit, so I'm going to continue with the rest of the build in the meantime.
I decided to work on the Belfry. The small brass bell included is nice, but the piece included for the ringer (?), uh, isn't. It didn't really work as a ringer, or support, or anything, really, so I used a ring and nail instead:
A is the included "ringer". B are the rings and C are the nails, put together to make a ringer and bell support D.
The result is much better, and looks pretty good from the side, where you can't see the ring:
I then mounted the bell onto the bell pivot (the extension of the ring acts as a lever), and assembled it with the top:
The bell pivot actually "rings", using small nails as a pivot. I used a temporary spacer at the bottom to keep the vertical arms parallel. I also placed shims under each arm to center the top piece , which is wider, then weighted it while glue dried. BTW, the two vertical arms are different length because one side will sit on the main deck, while the other will extend through the deck structure to the beam below.
I was concerned it would be too flimsy, but ended up fairly strong, if not manhandled. I dropped it a couple times, of course, but it survived.
I then checked the fit in the required location, and found a problem:
There isn't room for the belfry to fit between the foredeck and the windlass shaft. Okay, what have I done wrong now? I knew from doing the foredeck planking that it was a bit long, compared to the plans, but it was all based on the windlass support, so still should have been okay for the belfry.
Taking the plans, I determined that they do indeed indicate an problem interference at this location:
In blue is the belfry uprights, red is the windlass shaft (rotated to its maximum width) and magenta is the interference. Same in below:
So, I checked out Goodwin's side cross section:
It appears that the windlass should have been further aft, or the foredeck further forward, creating clearance rather than interference.
I decided to fix the problem by moving the belfry forward into the foredeck by notching the uprights to clear the foredeck cross beam and deck:
This isn't realistic, of course, because this would severely weaken the uprights, and we wouldn't want to cut into the crossbeam. But it should look okay, and be far preferred to rebuilding everything.
After mounting the belfry as well as the windlass assembly, we have:
And while there is very little clearance between the windlass shaft and the belfry uprights, there is at least some:
I'll end this chapter here, and begin a new post.
Smart recovery here!
Hello ,The kit includes two fasteners for the bottom of the masts, one for the main mast and the other for the mizzen mast. If you still want to try this installation plan, I can mail you another set of these parts。
Hi Tom, its me Daniel. I just sent you a PM. I hope you got it. I will be looking for your PM answer
Cheers
DANIEL
HI Signet
Sorry about this posting.
I keep trying to communicate with Tom by PM and every time his address at the bottom of the PM has a line over it. I am not sure what that means. So I just wrote a new PM and quoted his post with the aim to check if he got my PM. My aim is to have a private personal chat with Tom, that's all.
Nevertheless, if you want, I can delet this posting.
Thanks
Daniel
While I haven't posted in a while, I have continued to work on the model. I've been skipping around, trying to think ahead, etc. so my work has been disjointed. And therefore, my posting will be too.
The next task for me was to plank the inner sides of the model above the decks. This worked out okay, so they were painted the same Red Oxide as the other red areas.
I love me my clamps.
I like the contrast of the red, light deck and darker wood.
Next is to position and glue the planksheers. I'd noticed ahead of time that the bow of my model was a bit longer and pointier than on the models. Thus, the planking and such didn't fit that well at the bow. And therefore, the pre-shaped planksheer didn't fit that well either, but I made it work.
One error I've made all along is in planking. To allow the frame to be removed from the docking template, I'd glued the top outer plank in place a long time ago. I placed it at the top of the frames. But I selected plank number 2, visible in the instruction below, to be positioned at the top of the frames.
While, in retrospect, it's obvious to me that the moulded 2x2 strip should go at the top, somehow that wasn't obvious to me at the time. I figured that the 2x2 should go on after the planksheer was installed, and go under it to the outside. I liked this idea anyhow, because my shaping skills appear to be zero. As in, I spent hours shaping and sanding this strip afterwards, only to get something that didn't look like it had been touched. So I planned to get some quarter round brass to add in this place later. This moved my planking up on the model by 2mm, which caused some solvable problems later. It did move the wales down by 2mm, reduced the gun portals height by 2mm, etc. An advantage was it left the top of the gun portals open for shaping and sanding.
Knowing that the planksheers would overhang the structure a bit, and also that due to my error I needed room for the 2x2 strip replacement mentioned above, I tried to keep the planksheers flush with the inside planking and overhanging the outer planking by about 2mm for the above mentioned strip. This was not possible in all places, but I tried.
I used craft sticks positioned from side to side with weights to keep the planksheers level. And in most places, added a 2mm strip to the outside temporarily to try to get the 2mm offset.
I mentioned above that my bow doesn't match up with the plan's bow, and therefore not with the included forecastle planksheers:
Luckily, here the 2mm piece need not be added, but the overhang of the planksheer was certainly going to vary. With sufficient extra material, tools and skill, I would make new ones, but given what I have, there it will be.
After adding all the planksheers, and the added rail at the quarterdeck, we have:
The ship is looking much more complete now.
I've also added the catheads. From the instructions, it looks like they should fit entirely under the forecastle planksheers:
but at least on my model, they did not, but rather required cutting away part of the planksheers. But according to Goodwin's book, they do cut through them:
For once I ended up with something correct.
I tried carving the faces into the ends, but ended up painting them gold and using a Sharpie. I also tried painting the rectangular trim (13 above), but ended up painting it just black. The black I am using is AK Interactive Nato Black AK11360. There's just enough gray in it to satisfy me that it's not pure black, yet doesn't look like gray. Very difficult to find, and then I only bought one bottle instead of 2.
That's enough for this episode. I'll be starting another one shortly.
Continuing on, I thought I'd work on the stern next. As posted above, I added a 2x4mm strip going across to the 2 semi-triangular extensions. But after adding the decorative portion at the stern, it's location seemed off, and the triangular parts too large, so I redid it:
Here I've added brass double-half-round molding measuring 4mm x 1.4mm to replace the carved piece that I'm unable to make:
I think it's a reasonable facsimile of the specified 3x4 moulded strip.
Time to add the 2mm brass half-round piece I mentioned above:
These clamps worked so well (and so much better than all my other dozens of clamps) that I bought 50 more to add to my 10 obtained from the dollar store. They don't slip around as much, and in this case helped keep the brass strip against both the hull planking and planksheer after gluing with CA.
On to the next chapter...
Next I thought I'd work on the swivel gun pedestals, 18 of them. I knew I'd have to drill holes into the top of them for the gun swivels, so took a look at them first:
I probably shouldn't be, but I was a bit disappointed that the swivel mounts did not have holes for the gun trunnions. I tried drilling them, but had problems. I thought about removing the trunnions and gluing them in place, but emailed Tom about that, and he suggested first drilling with an 0.8mm drill then with a 1.3mm drill. I tried that on a couple swivels, and while one side worked pretty well, the other broke out the side of the mount. They work, if glued in place, but not what I wanted. I have an idea for doing a better job on the other 16, but I'll leave that problem for later. Or maybe someone will suggest a better way.
BTW, I have found the brass castings included in the kit vary quite a bit in hardness. For example, I tried drilling out a 4-pounder's shallow bore to make it deeper and gave up. Some other parts, however, drill pretty readily, like the yokes above. I've had to anneal some parts by heating them and letting them cool slowly.
Back to the pedestals - they are all to be 4mm octagonal. CAF suggests making them this way:
taking a 4mm dowel (not sure if that was included) and cutting 8 sides into it. Huh??!! Why not instead use 4mm square material, and only cut 4 sides??
Well, it turned out I had 2 strips of 4mm square in the kit that I could use (hoping I don't need them for something else). I'd made a V-groove block to facilitate drilling the center of pieces, so used that along with some shims and such to hold the 4x4 at a 45 degree angle, while pulling it under an end mill mounted in my drill press. That seemed to work at first, but as I removed a couple sides, it became harder and harder to keep it correctly placed, and sometimes the strip would rise to high and cut too deep. Nevertheless, I ended up with 2 strips that, if you're far enough away, could be mistaken for octagon-shaped.
Then I, in my engineer's hat, measured the proper angle at each of these where it overhangs the planksheer, wanting to make 2mm slots halfway into the octagonal strips, and at the proper distance from the top of the pedestals. And cutting each end at the proper angle. And cutting also for the 2mm brass strips. While changing angles and saw cut depths for each cut. While holding the octagonal shape correctly. The results were definitely substandard. But again, at far enough away....
Oh, and also make a jig to hold each pedestal in place while drilling the holes for the yoke. Whew, what a job!
But, when I went to fit these pedestals in place, they weren't quite as accurate as I though. And I needed to change the depth and location of slots due to variations in the hull planking location and angle, brass strip and planksheer! I felt they were almost useless. And I still didn't like the pseudo octagonal shape.
So I decided to make a new octagonal shape. But guess what - I'd used all my 4x4 stock. So, I took 2 pieces of 2x5 stock included as planking, glued them together, and trimmed off one side to 4mm to match the other. This time, no fancy end mill a drill press, I jused a rotary tool in a Dremel and did it by eye. And it ended up better.
I won't show any photos of that long process, because I really screwed up and wasted a lot of time. I'm sure all of you have done much better and have a different method. In the meantime, for my next octagonal use, I just pray that someone, somewhere, will decide to produce octagonal forms for me to buy!
I started with the easy center pedestals, and then moved on to the forecastle:
I like the way the brass strip looks - certainly better than I'd have been able to do with a 2x2 strip moulded.
So I glued the brass strip on the starboard side:
Here are all the pedestals in place.
I've also touched up the black paint on the planksheers, so have gotten some on the brass. That will be cleaned up later.
Time to mount the rudder. I've been avoiding it to keep it from getting damaged in handling. But it's time.
First I mounted the rudder-side hinges in place, matching them with the hull-side hinges:
Even though I'd enlarged the cutouts into the rudder some, to allow installing the other hinge halves, I still had problems getting the rudder halves up tight against the top to provide the most room, and installing the other halves.
Holding the rudder at the proper height with my new favorite clams, In first installed the uppermost hinge:
I then installed the bottommost hinge. This holds the rudder in place fairly well, as long as the model is right-side-up.
Sorry about the hull cracks; you don't usually see them, and I haven't filled them (which I know I shouldn't have to do).
After those 2 hinges are properly located and mounted, it becomes very difficult to mount the other hinges without making a huge mess of CA glue all over the hull, as well as having them stick in the wrong place. Since I intended to fix the rudder as securely as possible, to help prevent possible breaking or dislocation, I decided to cut the hinges in half. And since I would no longer be moving the rudder, I placed a brass pin though the rudder into the stern post:
I see my dust is showing. I hope to clean it up and maybe put another coat of finish to help. The above photo also shows the rings for the rudder chains - easier to drill and locate before mounting.
Here is one of the rudder hinges cut in half as a test:
The test worked well, and I was able to easily locate each of the port side hinge halves easily and securely.
Adding the other side was a snap.
The resulting rudder mounted with hinges:
Ah, the wife has just baked a quiche, which looks great, so I've got to go:
I've been working on the mortars lately, which mostly went without problem. Well, if you don't count mounting the 13" mortar upside down, losing one of the mounting parts and breaking another. So I'll just show photos of them mounted in place, which represents the current state of the model:
I see I still have to clean the black paint off the brass. Here I've added side steps and ladders, tiller housing and tiller, kevel and other cleats, and hatch grating. I added belaying pins to the bitts around the mainmast, which I think adds a nice detail touch. The cover and structure around the 13" mortar is removable in 2 piece to ready it for combat. I have the covers done as well, but forgot to add them. I've also mounted the mast collars, which Tom kindly provided because I was unable to make the ones included work. He probably used all the included parts and turned them on a lathe, but whatever method used, they fit and work great.
Another pics showing the mortars better:
I've added bolts on the mortar beds per Goodwin, using Tichy Train Group products, but you can't see them well here. They do improve the look, though.
That's it for now. I have to decide on what to work on next. Trying to avoid small bits that will break off when handled for now. See you next time!
:cool:
It's been a week or so. I've been working, just not posting. I'm getting to the point that the small parts added are rather fragile, and get broken when holding the model on my lap to add other parts. I'm not sure how I'm going to be able to put everything on last. ;-)
I've managed to screw up all of the swivel gun pintels:
Usually one side of the casting, which is slightly depressed, stays pretty much centered and drills okay, while the other side, being somewhat convex (sticking out) is quite difficult to center and cuts though the outside. Some are usable, in that the guns can be mounted when glued, while others are pretty much scrap. I've designed new pintels that I'm having my son make with a 3D printer. We'll see how they work out.
The pintels supplied are very nice, and accurate for the most part, but I feel they should have been supplied drilled, as it is quite difficult to drill these holes. Some brass castings are soft and easily drilled, while others are quite hard and difficult to drill. Maybe if I had better tools and skills.
I've made the elm tree pumps:
They worked out okay. I drilled a larger hole in the top of each, representing the size of the inside bore and piston, and a smaller one to accommodate the wire so that the levers can be moved. I've made them movable not to add a toy-like quality to the build, but to be able to lower them to be less vulnerable when working on the model, then raise them afterwards. I had some copper tubing for the discharge ports and have ordered tape to simulate the iron bands surrounding the tops. Since they just slide in place and get glued, I'll leave them off until later, lest I break them.
Previously I used the same copper tubing to represent the scuppers (4 each side). I wish I'd have noticed them earlier, so I could have cut groves in the waterways to match them, and add a bit of detail. But I didn't. Next build, I guess.
After putting it off for a while, because the mountings and arrangement were confusing to me, I worked on the stem decoration:
The cheeks have a round decoration at the top which did not match the top of the knee at the head, which was a bit shorter with no rounded area. This resulted in a gap between the two parts, which didn't look right to me, so I took a small length of dowel and filled the space between them. The result is not a sphere, but it looks more complete to me.
Here's a side view of the pieces in place:
I realized after taking this photo the the lower cheek extensions are reversed, side-for-side, so corrected it later. Photos show up all my building flaws, and there are SO many.
It took me forever to figure out where how the head timbers (10 below) should be mounted. The shapes just didn't seem to fit, and the grooves in them made no sense.
Then, after thinking I got it right, when mounting the first one, "ping" and the part jumped from my tweezers in an unknown direction, but probably (I thought) toward the back of my desk. A search did not find it, so I figured it was behind my U-shaped, connected together, many hundreds of pounds weight desk, which extends to the ground. Lost forever. After an hours search, I went to bed disheartened. But at least I didn't have to worry about how to mount them.
The next day I looked in my desk drawer, and the piece was staring up at me, as if to say "here I am". Not possible, but there it was. Now back to mounting these things.
After installing the heads, I couldn't figure out how to install the lower head rail (6 above). I was certain they would interfere with the gammoning. So I did a bit of temporary gammoning to test that out:
You can't really see the heads in this photo, but they're there, making gammoning difficult. Speaking of difficult, it would have been a whole lot easier to cut the gammoning slot in the knee of the head before adding the structure, but I wasn't certain of the location, which is determined by the cheeks. Anyhow, this indicated to me that the gammoning might well interfere with the lower head rail, so set them aside for now.
Here I've installed the heads (not sure they're installed correctly, but they're there), corrected the cheek extensions and added the gammoning and figurehead:
Previously, I had tried and tried to figure out how to mount the lower head rail, which is supported by the head timbers. I was certain that the gammoning would interfere with it, the grooves in the head timbers didn't seem to be right, so took this photo to prove it:
Well I'll be darned - the piece just dropped into place, supported by the upper cheek and piece supporting the hawse holes! Not sure it was touching the head timbers, but it was close.
I was really shocked that it fit, and apparently didn't interfere with the gammoning (although I think it would make gammoning much more difficult).
So, I fine-tuned the ends of both lower head rails and mounted them in place. Here is the result:
(I love that the tiny cat hairs, which cover me and everything in our hose including the model, show up so well in photographs. Great detail!)
Now to figure out what is next.
Just finished the Fish Davit. I understand the Davit part of the name, not so sure about the Fish part. Maybe because they used it to Fish the anchor out?
Anyhow, nothing special here except I used light colored rope, so it would show up better, and fashioned a spanshackle (yeah, that's what it's called) to contain the end of the davit.
The fish davit in place, showing the spanshackle in use:
And without the fish davit in place (but it won't be displayed that way):
I've been going back and forth about which side to extend the fish davit from, but decided on the starboard side because the decking is available to mount the spanshackle.
Working on the anchors now...
I've continued with work on the model, but there hasn't been that much to show. I've made up the anchors, which required larger anchor rings than included, and added puddening:
These will probably be mounted last. Goodwin states there were two bower 20cwt anchors, one being a spare, an 18cwt sheet anchor, a 7.5cwt stream anchor, normally stored below deck) and a 3.5cwt kedge anchor. I couldn't find a properly sized anchor for the sheet, so substituted another 20cwt anchor, which was common. The kedge anchor I purchased matches the book drawing quite well.
I feel that, at least during bombardment, the ship would need to have mounts for multiple bombs on-deck. With the 10" bombs weighing over 100 pounds, and the 13" over 200 pounds, crew could not be expected to hold these until needed. So I added small mounts to hold the bombs in place until needed. These are the 10 bombs and mount:
And the 13" are shown here, two of them being explosive bombs while the nearer two are "carcasses", incendiary devices or cages filled with inflammable materials, basically 18the century napalm:
(I'm going to have to clean up this area a bit, but you get the idea.)
I got the 10" and 13" bombs from CAF. The carcasses I designed and had my son make 3D models of:
I've been working for some time on a better, or at least stronger, method of mounting the cabin deck port covers, but will include those later for better flow of this thread. So that's it for now.
Yikes, if exploding mortar shrapnel wasn't enough, add in exploding canisters with burning oil (napalm). :eek::eek::eek:
These ships could really ruin someone's day if their fire was accurate and rapid!! Staging them in the holders like you added would sure help speed up their rate of fire!!
Great job and thanks for sharing!
I finally got around to making the cabin deck port covers. I'd been avoiding this, because on other models I've made, these usually break off. Plus I was certain I was unable to use the hinges included with the kit; I can't even bend the photo-etched hinge parts to match the hinge pivot - they either break or don't fit, and I know they're not sturdy enough to stay in place afterwards, so I decided to do them with a different method.
I decided to use a thin brass to act as the inner portion of the port cover, as well as the mounting which would go inside the port. I didn't have the right width of brass, so soldered 2 pieces together (my first use of solder paste along with a torch):
The brass was then bent so that a little less then half would be the backing of the port cover, with the rest the support for it, which would be hidden.
The cover area of the brass was marked to match the side planking of the hull:
The proper size planks were added at the correct angle and glued to the brass:
After trimming, the resulting port woodwork were confirmed to fit the ports:
Hinges parts were then added (they are just visual and don't actually work of course), along with rings for the opening ropes:
The red outline shows how hinge assembly will mount into the outer hull.
Opening ropes were then added, and the assemblies were glued in place, with the bare brass portions entering the ports and going inside up the inner wall, in an 'L' shape, which would be glued in place. Here I used E6000 glue, as it would give a little without letting go if bumped. A pair if pliers held the assemblies in place and put pressure in the right direction while the glue dried:
I decided to add the channels next, only to the port "finished" side, not to the starboard side. Here Goodwin's information indicates channels much larger width than those included with the kit. Basically, the kit parts are less than half the correct width, as this drawing shows:
The channels are also supposed to be tapered in thickness and thicker than the material included. I searched my junk stash, and ended up using craft "Popcycle" sticks for the channels. They are a nice straight grain wood, fairly hard, and just so happened to be within a tenth of a millimeter in both width and thickness required!
After making and mounting the channels, I painted them black (seemed right to me - IO don't know if it's correct or not).
The deadeyes provided by CAF were smaller than Goodwin specifies, so I purchased new ones in 4, 5 and 6mm size ebony, to closer match the ship's 7", 9" and 11" deadeyes. Of course that meant that the deadeyes' chain strops no longer fit, so I made mine out of wire. To that, I added the included photo-etched chain plates, which of course are now too short, due to the wider channels. Maybe I should have left the channels as supplied with the kit! I took the easy way out, and just left the chain plates as-is, as I had no material to make new ones. The assembly looks like this, before trimming the wire chain strops):
After the deadeyes were in place I added the channel retaining paunches (strips), leaving them a wood finish.
In this final photo you can see the deadeyes and channels, cabin port covers as well as port covers for the bow:
This photo is purposely taken from a distance with lower resolution, due to my poor workmanship on the channels. They add to the overall appearance, I think, but I'm not proud of my work, I'm afraid. As an engineer, I think I have some good ideas for construction or improvement. As an 82-year-old who drops each part at least 3 times, my work is not at the quality of others on the forums. But here's a couple photos showing how the port covers worked out:
I think it's time I made more than the one gun I now have, so that's what's next to be worked on. See you then!
Guess what? I'm finished! I didn't take any photos of the final stages, as I don't really have anything here to offer, I think. If anything, I took a few shortcuts, not because I'm short of time, just short of talent, so not much to be proud of in the details. But I am proud of the overall model - I think it will look good on my, uh.... somewhere.
So here's some pics of the finished product. Comments are placed /after/ the photos:
Above is obviously the "finished" side of the model. The other will show the construction details. I've also shown the anchors in different positions. Here they are stowed for sailing.
Above I've decided to show the covers removed from the forward (10") mortar (mostly as there is NO room for them) an in place but partially open on the aft (13") mortar. I assume the crew would have offloaded these to the accompanying tender, as they would otherwise really get in the way. One cannon is drawn back, as if for loading, the others in firing position, but they most certainly would have been brough in an store parallel to the sides for best space in firing the mortars.
The starboard side of the vessel shows detail beneath the deck and construction details. Visible are the anchor ropes in the hold (120 scale fathoms of each).
I was unable to use the tiny PE parts for the guns. I just can't work with them. As tiny as they are, they seem to require holes of a size I cannot drill (below 0.5mm) and such, so the capslocks are tape (sorry CAF, I know they're good parts, but...). As can be seen, there is almost no room to fire and reload cannon - let's hope they never had to do it, but mostly used them to scare away attackers, as a lot of extra handling would be required.
Above is a good view of the viol cable system of hauling the anchor. This is similar to using a messenger cable, but a messenger cable is pulled directly by a mid-mounted capstan while the viol cable is pulled by a front-mounted windlass, which pulls the cable forward, around large blocks/pulleys at the main hatch, pulling the other side forward, along with the anchor cable which is connected to the viol by nippers (shown, but poorly represented). The viol cable is wrapped around the windlass, while the anchor cable simply rides over it.
Above the anchor is in the middle of being hosted and positioned for sail by using the tackle connected to the cathead, and a tackle located on the fish davit, a beam which can be manipulated to lift items over, or outside of, the deck.
Not much here. Notice the hawse holes are lined with "lead" for ease of sliding and to prevent wear of the wood structure. The "pointy-end" of the anchor rests against the anchor lining, an additional layer of replaceable wood protecting the hull planking.
Above you can barely make out two of the chairs and table in the captain's dining room. While the checkerboard floor was not common in 1742, especially in a lowly mortar vessel, the captain decided to spend his personal money on it here, which didn't take much cash, as the original, like my model, were made of cloth (canvas on the original).
BTW, I ruined all of the yokes for my swivel guns, so had my son make these up of my design. The guns kind of "snap" in place, and still give a good appearance, I think.
The captain's cabins walls were painted off white, so this is seen on the nearest port, while the Lieutenants cabin was just wood, so not painted.
A better view of the captain's bedroom, dining room and day cabin. As well as the Master's cabin with bed. Good luck to the remaining 50 or so sailors on this vessel for finding a place to curl up, let alone hang a hammock!
I didn't bother placing the main guns or swivel guns on the "construction" side, only the finished side of the model. Some of the anchor ropes can be seen to the left.
A lot of barrels were placed within the model, but it's hard to see them. Can you find a few here?
Just a straight downwards view here.
Toby, aka Tobiwan Kenobi) decided to take an interest in the model while shooting - first time ever that he's done this (thank goodness)!
I'll be building a better stand later. Have to figure out what I want - can't be too tall this time.
I'd like to thank Tom at CAF for providing an excellent model and for helping me numerous times along the way. As well as answering my numerous questions. Except for one cross-section model, this is my only Plank on Frame model, and it was a challenge. But I thoroughly enjoyed it. I know my builds can't match others here, but I hope this topic can be some help to less experienced builders and/or give others some ideas of alternative methods of construction and detailing.
I highly recommend this model to others, for an enjoyable, if not easy (for me) build. And I really like the end product. Hope you like pics of it too! :)
Whoops! I just realized I forgot to add the little statues at the aft corners! Oh, well, nothing's ever finished, is it!
Good morning. I agree you can most definitely be very proud of her. Congratulations on a fine looking ship. Cheers Grant
One last photo. I bought enough material to make the full number of 18 oars (sweeps), which the ship was equipped with, for helping to position the vessel, among other uses. I expected to mount 9 of them to one side, if I could find out how/where they were mounted. I'm certain I saw another thread which had a link showing such sweeps mounted on a metal structure outside of the quarterdeck, and felt I would do that. Many period ships had such sweeps; some ships are large enough to store them alongside or on the ship's boat, but the Granado has no room for a boat, either. A request for storing information resulted in no link or other information, just a lot of other opinions about how the sweeps could be on the main deck, in the hold, etc. While I disagree with those, I wanted to at least show one sweep on the quarterdeck to get an idea of the size of them:
As can be easily envisioned, even one of these oars on the main deck of the Granado would eliminate Mortar operation and in general cause havoc.
FYI, the oar is made of a central piece of brass rod, surrounded by 1 to 3 layers of plastic tubing. As you can see, the oar is longer than the quarterdeck of the Granado. Mounting 9 of this on each side outside of the quarterdeck rail would be possible, but certainly messy. Yet it's the best idea I've thought of. But rather than muck up my model, I'm just leaving one on the quarterdeck for viewing. I'll let the captain figure out where he's going to put the other 17. ;-)
You may notice that the swivel guns have been removed here. They kept falling off during handling, and the Captain didn't like the falling on his dining table. They'll go back on when the model gets enclosed.
