- Mar 28, 2024
Hi, AirBoss Rib. Pics? Would be great to see them. A photo tells a thousand words. Some of us may be illiterate.I build blocks and deadeyes at 1:50 scale.
I use maple dowels for blocks and black walnut dowels for deadeyes.
For my blocks, I sand two opposite sides of the maple dowels flat (on a belt sander) to establish the general shape. Then I hand sand with 250 grit to smooth and round the edges of the flat sides. Then I tack the dowels to the honeycomb of my laser cutter. I cut thin slices (about 1/32") like cutting a salami sausage on a meat slicer. Then, one by one, I drill a 1/32" hole at the ends of each oblong slice. Then I drill another hole at dead center. I use 1/8" round maple dowels cut into 1/16" slices on my laser cutter to create the circular "pulleys", then drill a center hole in each pulley. I slip a 1/32" dowel into to the top and bottom holes. I slide a 1/16" dowel through the center hole, slide on a pulley, slide on another oblong wafer, hit it with thin CA on the outside of the wafer where the dowels are protruding through. I slip a 1" square piece of wax paper through the protruding dowels. Then slide on: oblong wafer + pulley + wafer + thin CA + wax paper. Over and over and over until the 8" long dowels are filled with complete blocks. Then I cut them apart with a razor saw, sand both sides (rounded). Voila. Blocks. Done. To make double sheath blocks, Slide on: wafer + pulley + wafer + pulley + wafer + thin CA + wax paper....
For deadeyes, I turn the black walnut (about 4" lengths) dowel on my small table lathe, you get about 24 out of a 4" long dowel. Then drill the three holes on each one with my drill press. You have to hold them with something, so I drill out consecutive holes on a 2" x 1/2" piece of cherry 12" long - I cut the holes about an 1/8" deep and 1/2" apart l using a facing bit just slightly larger than the deadeye blanks. I mark the hole locations with a triangular open stencil and a .05mm white ink pen. I insert a blank into each jig hole, light a pipe, crack open a cold beer and drill drill drill drill. Then I pop them out with a dental pick. I've made bags of them.
I must say I want to see pics because then I can decide if (like a real block) they have that engineered look about them.
So let me decide, and I am not being nasty regarding your post. Any effort is a good effort, I must add.
With dead eyes, they seem to be easy to make until you drill those 3 elusive holes. What I would like to see is whether your dead eyes for drilling the holes have a jig to get the accuracy. I saw dead eyes on Temu and to the scale I wanted, and so I got some to see how accurate the three holes were, and they were smack on. Could I do that freehand- no way? So I want to know what jig they use to achieve such accuracy
What I am saying is I can make a pulley by hand, but its authenticity would not be miniature in reality. Maybe I should sound it out loud, and that is to make these pulleys, and to be real, there has to be a jig or three made to carry out a procedure, to be exact, for each one.
Here is a Pic of the Dead eyes at 48 scale, or actually 1/4" diameter, showing the accuracy of the three drilled eyes. I gues a jig was used so the drill did not wander off the position:
Cheers
