Pinta Caravel 1:65 by Amati - an End of Build Log
This a build log of my Amati Pinta. A model I began in 2019, completing the hull back then. Doing some deck fittings in 2020.
This was my first wooden ship model. I stopped work both times, when I realized I did not know enough to proceed with the rigging. For instance, all ropes were specified as "rope" in the instructions. No diameters. And there were blobs on the mast tops I had no idea what they were.
Two plan sheets, and 2 pages of instructions. Some of it untranslated.
But 3 weeks back and several ships later, I looked over the instructions and plan sheets ... and thought ... no problem.
And I added the pump, windlass, bit blocks and anchors. Painted the metal ships boat brown, dry brushing it trying to make it look like wood, added the gratings, and stained what wasn't stained, while removing unwanted blotches from 2019.
And this weekend I cut and tapered all the masts and spars. Using a bamboo skewer when I ran out of 4mm dowel. And ... I hand carved those "blobs" on the mast tops into blocks. You can see em laying on the deck, with the masts and spars I'm working on. Have to glue together some straight masts out of that stuff.
Then, I'm ready to add some deadeyes, step the masts and rig em down with the deadeyes ... and then set the spars, etc.
I ordered a sewn sail set, from HiSModel. Expecting that in a few weeks.
So, I'll begin with some pics from 2019, then quickly bring it up to date. First, a couple of pics, as it is today.
And now I'll see if I can't sort out the earlier build pics (many from 2019), into something coherent.
Just finished gluing the 3 handcarved blocks to the 3 masts. This pic shows em loosely stepped into the hull. I'll either paint the cannons next, or start on the standing rigging - and get those 3 masts set properly, or assemble the spars.
Looking for advice ... regarding tying two spars together to make one larger spar ...
  • do you just tie them together?
  • or carve out the ends a bit, for a good fit, before tying them together?
My instructions do not say, but the plans (see below) suggest this is being done. When I look at the ends of the spars, they are drawn seemingly overlapping the midsection of the spar they mate up with, as if they were hallowed out a bit ...
No need to get fancy. This is how I did mine:
You basically take two identical pieces, overlap them and sand off at the cut lines, leaving a bit of stock at the ends. You then have two flat surfaces to glue together - they go together quite nicely. After gluing, you wrap them with rope, etc. Here's mine, although it's hard to see:
Thx. I like that method. Nice lookin model, BTW.
Here's the results. I used the grinding identical flats on both spars and gluing the flats together method recommended above.
Also shown is a thicker dowel, on which I tied my first "common whipping" knot. And this is how I'll "tie" the (already glued) spars together.
The common whipping, courtesy of netknots ...
Never used this before. Dunno why, because it works ... snugs up without having to fix it with a spot of glue. Been faking my whippings up to now.
I finished the whipping on all 3 spars.
However, one of my two main spars broke near the middle while I was sanding it to shape . (Dowel rods don't normally snap.) So, I glued it back together. Basically, a butt joint (almost a clean snap). So it broke two more times, while I was adding the whipping to that set of spars.
Solution?
Here you can see the extra whipping, with thinner rope, over the break. I also soaked some Titebond into the whipping.
Perhaps I just shoulda removed the whippings, separated the unbroken spar from its broken mate, and redid it with a new spar. But I'm so lazy.
Anyway ... not THAT lazy, and, if it breaks again, you can see the new spar I already carved (from a bamboo cooking skewer - was on hand, was the right dia 4mm) ... ready to go.
I imagine that some splints woulda been helpful.
Cannons ... did the Pinta have brass cannons? Anyway, the kit provided metal cannons and mounts. Colored brownish brass. Solid, IOW no holes.
So, I drilled 1.5mm holes into them. They are not brass inside. Tried wire brushing the coating off, but they ended up with a shiny brass patina.
So I painted 2. One flat black and the other a flat grey/black. Then I painted the 4 mounts a flat red/brown color.
Here's what they look like now ...
Decisions. What did they actually look like?
I researched wiki etc. and all I got was that caravels like this woulda had smaller swivel guns. So, maybe I just go for what looks "the neatest". Perhaps the flat black. Brass is nice though, on an imaginary replica like this.
View attachment 590244View attachment 590245View attachment 590246View attachment 590247View attachment 590248View attachment 590249
Welcome back to the build Tim. I will be watching closely! Magic Mike
