Going to be a bit of an intermission. Waiting on the arrival of a tool to help with the shaping of the bow blocks.
The new tool comes with certain conditions.
1) It goes under the Xmas tree
2) It can’t be used until after all the Holiday company goes home.
I was curious to see if there was a difference in wood fillers between the various types of paint. I’ve always used Acrylic’s on my models and the kit came with oil based paints.I have a very good result with Elmer's carpenter's wood filler. It dries fast, stainable (if needed).
For gap filling I like to sand the model on newspaper keeping all the sanding dust I then mix that with glue and fill gaps with it, if you keep it sticky enough it will even fill depressions. small gaps or cracks I just lay some glue right into the crack and sand over it the particles bind with the glue that will still be wet and fill it in nicely.
Looks very good, Jan!!
