- Jan 26, 2017
Thank you Jack!Awesome job!
Thank you.Fabulous
And I'm assuming, based also on my recollection of rigging my Bluenose, that this method is the best to avoid snagging other lines. I attached as many of the blocks to the various spars as I could off the ship. I hope this holds true for the Constitution, as well.I like how you're working from the inside out - not installing all the spars and then rigging.
Excellent workmanship, as always.
Thank you Peter. I believe this is the easiest method. I recommend the same to you.I like how you're working from the inside out - not installing all the spars and then rigging.
Thank you.It has been a while since I last visited, Mustafa, but you really have made a fine job of it!
That's a very accurate approach. That's exactly why I secure each spar in its place when its turn comes.And I'm assuming, based also on my recollection of rigging my Bluenose, that this method is the best to avoid snagging other lines.
There will be three eyebolts behind the main mast and two behind the fore mast for attaching the mizzen and main stays.Every time I look at your build, I see something I need to add to my checklist of things to do before installing the masts. Like the eyebolts by the mast in the photo below. That checklist is getting pretty long.
