I hope that my planking will be as good as yoursThe planking is going along slowly, mostly because I do not enjoy it a lot and am taking my time. I have to say planking the Bluenose was a lot more fun with its smoother lines.
When I made my first measurements I forgot to include the deadwood in the stern to be planked. I realized that a few planks in and lessened the tapering of the stern area of the planks to account for this.
Thank you Grant!Lovely progress Rob.
Like I said the planking of the Bluenose was much more fun. The curves on the bow take a lot of careful bending of the planking. Luckily they provide a lot of planks for those of us who need more than the minimum amount!I hope that my planking will be as good as yours
Very nice Rob, I am a bit in front of you on the same model and it has its challenges.Like I said the planking of the Bluenose was much more fun. The curves on the bow take a lot of careful bending of the planking. Luckily they provide a lot of planks for those of us who need more than the minimum amount!![]()
That will indeed be a challenge. On the planking of the bow pieces I have sometimes use gel like CA cement. I would put a few dots of CA along the curve and hold it in place until it sets. You can use a CA accelerator (ZAP kicker is one brand we have here) to cause the CA to instantly set. The rest of the strip I would use PVA glue.Very nice Rob, I am a bit in front of you on the same model and it has its challenges.
I thought I might ask for advice with the next bit of my build. I have got to the part after completing the planking where I have to attach a few strips alongside the hull but below the lower gun ports. I have bent the strip to the same shape of the hull and I have to attach it to the hull. I intend putting large elastic bands along the straight sides of the hull but how do i hold the bow section in place after glueing. I have attached a photo showing it from the instruction sheet.
Thank you Allan, I am unsure why they do the planking the way they do. It strikes me as being very ugly and I doubt any similar method was used on actual ships. I think one reason they may do it is to simplify the "instructions" which makes a passing mention of tapering. Also it would be difficult to explain the tapering by the visual method they use. But it goes to show there is certainly more than one way to skin a cat.It is a joy to see that you marked out the plank breadths so the planking does not look like the instruction photos above, which are someone's fantasy. (I know this is a fantasy ship, but....) Note that the wales in the photos above stand proud of the planking at the stem which is also unrealistic. When you get to that point, remember to sand the thickness to match the adjacent planks as close as you can so the strakes of the wales fit into the rabbet the same as the other planking and does not stick up at the rabbet.
Hi Rob,With my so - so planking ability, more frequently than I want there are gaps in areas between planks.
If the spaces are large enough I take the shavings from the planks and use pieces with a little glue to fill the space.
These are sanded down to match the hull.
As a side note, I have to say the planks provided by Occre are first class. Each side has been milled flat and smooth and each plank that I have used is exactly 5mm wide. They provide way more planking than you need. Well done Occre!
