Imai/Aoshima 1/60th Junk build
With the Revell Viking Model completed yesterday, I wanted to build a kit I had not done yet – a larger scale Chinese Junk. I have an old Imai Model of the Chinese Junk; the kit went under in Hurricane Katrina (like the Viking) and had to be soaked and washed to get the dried mud from all the various parts.
The kit has been re-boxed a few times and also sold by Aoshima as a Chinese War Junk. I’m removing the machine guns and aft deck guns and filling the holes; I’m building a normal version. I’ve been doing a good bit of research on this as well. I’d like to give a shout out to a few modelers in Australia - Harry Houdini (for his excellent build up for inspiration) John Lattanzio for sending me a scanned set of instructions and some very good notes for the build.
The assembly is pretty straight forward and there is little flash, but you'll still need to remove some light seems from the masts and other parts as normal. I’m going to use the stand that comes with the kit as it’s very sturdy and the name plate is part of the stand.
The deck treatment is the standard black base with tan topcoat, which will be lightly sanded to show the black deck grain. Because the model will represent a working Junk, it will have a heavy amount of ware and dirty washes.
The sail treatment will be the hardest due to the contrasting colors of the dark red sail (either Tuscan or Box Car Red) and the bamboo battens, which are very light/bleached tan color. I’m going to do my best mask and airbrush these vs. hand paining if possible. The kit provided rigging blocks but I’m not too sure they are accurate, so some more research is needed.
The junk has 3 bow anchors that seemingly are simple pitched over the bow when needed, I’ll build as instructed, but I’m not sure that correct.
The pics below are the initial stages of parts prep. Here is a link to learn the history.
Let me know what you find about the blocks.
i was planning on using the ones from the kit but I'm going to add rigging for the sheets and the lifts and so I had to get some extra (traditional) blocks. So maybe the kit blocks will look out of place. Or, if the kit blocks are correct, then the ones that I've bought will look out of place!
So I'll be interested in what you learn!
The blocks might be ok, I like the rope groove, but the eyelet is as large as the block so I'm looking at the blocks from Syrene Models and model expo. I 'll use the beautiful blocks if I need to order. The standard blocks are too rough cut. I have a sizing chart that will help for the block size and rope size.
Moving right along, because the deck has a nice wood grain finish, I was able to lightly scrape off a bit of the tan top coast to show the black undercoat. In the first pictures you can see it really makes the deck boards 'pop'. The caulk seams are also scraped and then a #2 pencil is drawn down each as well. Because this will be a worn and dirty junk, the deck will get an additional wash down with a water base black grime to accent the panels. The deck wells and stairs will get a darker brown color and a lit bit of weathering, but hatched will cover them mainly, so you really won't see the inside of them. The hull got its base colors but I'm undecided what bow and stern quarters colors I'm going to use, at first, I was going with a shade of faded blue or green but I'm leaning toward a red shade - which is widely considered a symbol of good luck, prosperity, and happiness in Chinese culture.
While the hand painting makes the model trim look sloppy, it an intended effect as the dry brushing and grimy water wash will balance it out, the Junk was a working boat, and it would never going to be ship shape. The aft section will have the round Ying and Yang painted in the traditional white/black combo as normal. The fore and aft deck hatch will be 50% covered, so I simply gave them a grimy wash down. The main hatch is fully covered, I don't know why I even bothered. I spot test 2 shades of Red to see how it would affect the colors.
The Ropes of Scale size chart is something all ship modelers should have as it will help you select the right size rigging for any models.
The photo with the different block size serves the same purpose; to help get the correct sized blocks, I will go with the Model Expo "Beautiful' walnut blocks as they are better shaped than the boxwood blocks that most modelers use. The plastic kit supplied blocks with the built-in eyelet was intended to help simplify the rigging, remember this was for mostly kids to build, NOT crazy modelers, like me.
IF any of the gurus can chime in with your thoughts. The anchors have winches on the deck to haul them up to a certain point, but they also have molded in an extra hole for what I'll 'assume' was a leader for a buoy? Of course, the instructions do not cover this, anybody have ideas on what the buoy might have looked like, was it similar to the standards at the time? if I do them they will be small and just placed on the foredeck
Working on the pieces/parts, the deck got the grimy wash down along with the bamboo hatch covers. The stern Ying/Yang got dressed up, the deck dividers dragons got trimmed out, but the dragons themselves will be dry brushed in gold. I painted the bags of rice; I guess that's what they are? and I did the preliminary paint test to the foredeck cover to see if the boxcar brown looks ok. I think the sail will be the Floquil Tuscan Red for contrast.
Not a lot done today, just fitting and gluing parts on the deck, weathering and washes. There are 2 shades of yellow, all bamboo parts are Floquil Polly Scale Depot Buff (water base), including the 7 larger bamboo stalks that mount on the outboard sides of the boat., this color is so close to real bamboo, you have a hard time see a difference. The deck trim (dragon, framing, ladders, etc. are Floquil Sp. Armor Yellow. The Dragon background is Boxcar red with drybrush gold for high lights.
OK, I couldn't sleep past 3am and I went swimming in the deep water of the net and found these references, from Ship of Scale and the net. Simply hanging the anchor off the bow like many of the pics show makes the ONLY sense. I suspect the still secured the hook from banging against the hull in heavy weather, but in normal sailing, they simply let them hang swing. I think for lack of better proof, I'll do the same BUT only use 2 anchors. I found reference to the style anchor that were used on some of the boats and the one circled is close to the simple style of the kit. I also think the hole by the hook would have been used for a BAR to keep the hook from getting stuck to the bottom, I have just enough room for drilling out a chain link for a buoy, I'm still trying to research IF they use buoy's.
With the kit supplied anchors have the 'Bar hole'.
Prepped the last of the parts tonight, Vallejo makes several shades of wash these two are my favorites. I decided to go with pale green quarter panels on the bow and stern, just could not talk myself into the pale blue or reds, the green will blend better with the tans and browns anyway.
In the first photo, you see is the spare bamboo the boat carried, the next photo is after a wash down which seeps into the crakes and seems and give a shadow effect.
I dunno which boxing yu have but I noticed today that the pic on the FRONT of the box shows the anchors hanging in the expected way:
Conversely, the picture on the side of the box is like Harry attached them:
I think you are doing a great job so far! I hope to start mne soon but have bee nbusy with work on the Golden Hind ...
That sure is a strange thing, the company model maker should have known better? I may only use 2 anchors, I wonder why they used 3?
Anybody have an idea where I might find a figure or two in 1/60th. to go with the junk?
The little things take the most time it seems..... Its not helping that everything is in Chinese....... the lifeboat finished and washed, the kit did not come with oars, so I'm trying to figure out if they used oars or if they used a 'paddle tail' to propel.
The rice bag/cargo is assembled, I'm adding some barrels that did not come with the kit, they have to keep their rice wine in something.
The hull was test fitted with the deck in place to see if there would be any fit issues, The inner bulkheads were washed down to darken, I won't wash the outside till its assembled because I need to fill and sand down the seam where the hull meats to get rid of the gap.
In case you're wondering that section above the rudder is not missing anything, it's actually open like that - strange if you have a following sea, they going to ship water quick.
While I was doing some research on the style of boats, I found a reference to Chinese Pirates, so I requested an Inter-Library Loan through the parish Library to see if they can find the book so I can read it.
OK, just spent an hour researching, general consensuses is the use of a long tiller sweep, so I think I need to make something up.
Got the hull sitting up, deck in place along with the transom. Bamboo bundles bound and the snake trimmed out along with the eye. The hull looks strange because I have not dirtied it yet, clean on the outside, dirty on the inside.
Now that the hull is together, I had to remove the seam, no matter how good the model is, you're going to have a seam. You scrape it down to level then using a Flex-I-File you sand it down to take the hard edge off. Then fill the gap with thin Tamiya modelers putty, the tape is the to keep the putty off the side, makes for an easier clean up.
The micro brush I'm using is the same ones they use in nail salons, use them once, then pitch them in the trash, you can't clean as the bristles fall out. They come in a pack of a 100 for $7.00 at Amazon.
I did the base coat trim in for the bamboo thatch roof over the rear hatch. The SP Spanish Yellow is water based and the red color will be an enamel; this is so the two colors won't blend much. I'll go back and trim in the red then dry brush and wash
This morning bench time. Test fitted the sails to see the overall size and position stepped the masts temporarily - the mainmast is not bent; it's shaped like that.
Glued in the last of the deck goodies in place.
Rigged the anchor winch.
I'll start painting the main color sails today that should be a 4/5-day process between painting the main red coloring, sealing the paint against bleed through and them trimming in the bamboo color for the sail battens. I won't start the rigging until after the 20th., after the IPMS Northshore model show. I did the base coat on the sail to let it dry several days. then I'll seal it with a flat before painting the Bamboo rattans. If I can make it look half as good as Harry Houdini's that will be good enough.
