Planking : Clinker | Carvel | Deck | Waterway | PoF Plank on Frame | How to calculate, mark, build. + Jig + Nail ( nailing ), Bolt | by serikoff
I've searched for those dental cups but no luck.
OOPS! I goofed!
See Kolobok's post #24 below. There is a variation of the plain cup burr style I originally referenced in this post which is called a "twin cut cup burr" which, with a flat cutting edge around the very end of the burr, cuts a flat rim around the half ball formed by the cup, producing a faux "peened shank and rove" as illustrated in Serikoff's posts explaining his method for making very realistic scale headed rivets and roves on clinker planks. If you want a faux "peened shank and rove," like Serikoff describes, get the "double cut cup burr" as Kolobok identified!
At the risk of sending Serikoff back to yank out some 1,800 rivets again as he admirably did before, I will note in passing for those who may be inclined to represent rivets on their models that it is important to verify the direction in which rivets are placed on your particular model. Copper rivets are made from flat-headed copper cut nails over the protruding points of which a rove is set. The protruding point and shank are then cut off a bit proud and this is then peened over the rove to set the rivet. It's customary in setting planking rivets in small boat lapstrake construction to drive the nails inboard, so that the heads of the nails end up on the outboard face of the plank, while the nail shank ends peened over the roves are on the inboard side of the planking. There may be a variation in this customary practice for reasons of which I'm unaware in the case of Alert and other various vessels.
Here you go: 1774421692973.png
Ich habe ebenfalls nach dem Set geschaut, auch unter „Komet“, leider ohne Erfolg. Evt die Bestellnummer dazu posten (?)
Jetzt schon danke
Beziehen Sie auch ihre Fräser bei Temu?
use Cup Bur Twin Cut on Ebay or Google. Cut cups used in this topic, they have a cutting edge end can cut the bolt pattern as shown, working on the wire that is larger diameter than the burr itself. Regular burrs will round the edge of the wire only if burr is same or slightly larger than wire diameter .
Verwenden Sie Cup Bur Twin Cut (z. B. von eBay oder Google). Die in diesem Thema verwendeten Cup Bur Twin Cut haben eine Schneide, mit der sich das Lochmuster wie abgebildet ausschneiden lässt. Arbeiten Sie dabei an Drähten, deren Durchmesser größer als der des Fräsers ist. Herkömmliche Fräser runden die Drahtkante nur dann ab, wenn der Fräser den gleichen oder einen geringfügig größeren Durchmesser als der Drahtdurchmesser hat.
Besten Dank
Making Black Nails and Multicolored Shaped Rails.
Making nails (plugs) on the deck. (1 - tests, 2 - results)
Making Waterways and Scuppers.
Carvel planking.
Wale. Stern.
Clinker planking. Imitation and real version.
Railings and holes.
Nailing and Bolting. A few more design options. Scuppers.
Carvel planking.
Wale. Stern.
Railings and holes.
I'll tell Peter Goodwin about this next time I see him. He will appreciate this.
By way of interest Pete was negotiating with Moody's Boatyard on the Hamble to have a sailing replica built. From the timber original GRP a mould would be made so a small number of replicas could be built at reduced cost. These would make the Solent Alert class with annual regattas and charter sailing. Unfortunately this never came to fruition, old Mr Moody retired and the company under his son didn't have his level of interest.
Although Will Stirling on the Tamar river in Cornwall did build his lugger Alert from the plans in the book. It comes up for sale periodically. Peter was haggling over a price but his wife, Katie, had the final say. Personally a little disappointing because I'll never get to sail her now.
Wow! Your methods and presentation are impressive and I look forward to applying them as I continue to build my own skills. I find the process to build such fine plank on frame hulls to be a great hobby on its own. Thank you again!
Great tutorials... this is something I look back when trying to raise my building skills to new high. I'm not always successful but I have a goal in mind now.
Thank you for your feedback. I'd really like to see a replica of this cutter; I really like this model. I'm a big fan of Goodwin, as well as his biggest critic. He contributed greatly to the anatomies, but I can't ignore the errors that are present in them! This doesn't diminish the author's enormous contribution; I simply humbly try to study the information and, where possible, correct any errors in the anatomies (in my opinion, although I could be wrong).
Thank you for your feedback and high ratings. If you are interested, you can find out more about everything in detail by following the links.
Thank you very much for sharing this and so many other things with us.
Thanks Allan. ;)
