I'd be interested in seeing your ideas for the paddle wheels. The ship pretty clearly had a coppered hull. The Model Shipways Hull Copper Red looks nothing like copper to my eyes, but it does look attractive against the black upper hull! I thought about copper tape, but I haven't yet investigated if anything available is appropriate for the scale, or how to simulate the rivets. Looking forward to your build log as well.I am about to start my build of the Harriet Lane as well (same kit). I note that the paddle wheels are only half wheels (the other half is hidden in the cover so it does not exist on the model). I am not sure I like this Idea so the first thing I will try to do is to construct full paddle wheels & incorporate them in the model. I also would like to light the model (LEDs) so I may consider incorporating a motor for the paddle wheels. I note another build had copper below the water line (Maybe????).
Anyway you are off before me so I will be following your build with great attention
Tom
). On the other hand, I'm not so bad as to create an error of that size. My conclusion is, given that everyone has had the bulwark height problem, that the kit plan and the physical kit do not match. So, add back the 1/8" - 3/16" to the bulwarks so they match the plans. That also helps with adding 1/32" to the final deck height if you chose to plank the deck with 1/16" thick planks rather than using the 1/32" thick deck halves from the kit.
