The mizzen topmast stay and preventer stay are now complete. The stay runs through a bullseye already attached near the top of the main mast and is secured to an eyebolt on the main mast fighting top. The preventer stay passes through another bullseye attached to the main mast and is then set up to an eyebolt at the base of the mast using a pair of bullseyes.
As you can see in the photo, I didn't leave enough space between the fife rail and the main mast, so the central stay connection is slightly off to the side. I'm adding this here so that other friends building this model don't encounter the same problem in the future.
