Sovereign of the Seas - Mantua by Brian
The instructions say to now fit the deck? doesn't make sense to me. I'm going to finish the hull unless you guys know something I don't?View attachment 614319
Indeed it does NOT make sense - I'm becoming resistant to say but, I discuss that in the early pages of my log for this kit. I tossed the instruction
booklet - almost useless..
I would like you opinion on whether to run the bowsprit parallel to the keel as per the book or centeralised, I have drilled a pilot hole but nothing is final :)
The museum images of this ship model, of the ones I've seen, all angled the mast inward enough so that the spritsail yard aligned at its center with keel stem.
Hi Brian
I have some hopefully friendly advice here before proceeding with your planking any further. There are not enough bulkheads in this kit to support your planking. You can see it the way your planks are not forming a gentle curve as they are supposed to towards the bow. I would remove these planks and put some fillers in between the bulkheads. You can use balsa or better yet basswood. This way you can sand/fair everything properly to get the right lines and have some wood to support the planking between the bulkheads.
If you have to discard the planks you have already installed thats OK, its a long term project and buy some additional wood. Better to correct now than hope you can sand this out later before the second planking
Chris
It will probably not comfort you at all but I too had huge problems with the first planking. I am afraid that it the end I lost the rounded bow but did manage a more 'streamlined' version which looks ok in my humble opinion. I know the experts out there would be horrified.
