Anyone know a good source for 2mm blocks? Syren seems to have stopped selling ropes and blocks, and Dockrard’s smallest blocks are 2.5mm.
I buy them from Zoly at Dry-Dock Models & Parts. I use their 1.5mm single and double sheave blocks for gun tackles.
My hat is off to you Nama, 2mm blocks are about the size of small birdseed. I'll have to deal with them that size too before long. Like Kurt said try Dry-Dock Models.Anyone know a good source for 2mm blocks? Syren seems to have stopped selling ropes and blocks, and Dockrard’s smallest blocks are 2.5mm.
Namabiiiru! I wish I had the skill and patience to set up a jig! I only asked because I make mine one-at-a-timeThank you, Chuck. One would think from the inconsistency of my first few hooks that I was doing it jig-less, but I am actually using a jig. It still took a while to work out a system, but now they are coming out quite consistent, with only about one in 15 going in the trash bin.
The jig is simply a short length of guitar string (very stiff, but very thin) and a 0.5mm drill bit inserted parallel to one another in a piece of acrylic, with just enough space between them to fit the brass wire I am using for the hooks.
True story. And I thought your's looked good!
I was just on Dry-Dock (ran out of 3mm ebony deadeyesAnyone know a good source for 2mm blocks? Syren seems to have stopped selling ropes and blocks, and Dockrard’s smallest blocks are 2.5mm.
The smallest I saw was 2.5mm, but I’ll take another look—maybe I wasn’t looking in the right place.I buy them from Zoly at Dry-Dock Models & Parts. I use their 1.5mm single and double sheave blocks for gun tackles.
Thanks, Daniel! It was Chuck that inspired me to give it a try, not to mention gifting me with some (I assume) surplus blocks.My hat is off to you Nama, 2mm blocks are about the size of small birdseed. I'll have to deal with them that size too before long. Like Kurt said try Dry-Dock Models.
Actually 2.5mm is the smallest I have ever worked with.
Necessity being the mother of invention, I needed jig because I had no tools small enough to attempt it by hand. As far as patience, the jig is a huge time-saver since I can knock out about 2 hooks per minute with few wasted attempts.Namabiiiru! I wish I had the skill and patience to set up a jig! I only asked because I make mine one-at-a-timeTrue story. And I thought your's looked good!
Blessings.
Chuck
I’ll take another look. Old eyes may have missed them.I was just on Dry-Dock (ran out of 3mm ebony deadeyes) and they have blocks down to 1.5 single sheave.
Blessings.
Chuck
Namabiiru! You are wasting a precious opportunity to get truly zen - I think it takes me 3 minutes to make one hook, but my tolerance for my lack of uniformity is pretty highthe jig is a huge time-saver since I can knock out about 2 hooks per minute with few wasted attempts.
I see where I went wrong: DDM only has pearwood blocks down to 2.5mm. Boxwood blocks, listed separately, get as small as 1.5mm.I buy them from Zoly at Dry-Dock Models & Parts. I use their 1.5mm single and double sheave blocks for gun tackles.
Aha! Serves you right for being so particular - think about lowering your standardsI see where I went wrong: DDM only has pearwood blocks down to 2.5mm. Boxwood blocks, listed separately, get as small as 1.5mm.
Need to think about how I want to resolve this dilemma.
Boxwood has such a tight grain that it will not take stain easily, so matching the color of the pearwood blocks may require you to paint them. If you do paint them, open the sheave holes with a micro drill bit so you can get the line to pass through the block. Harden about 12mm of the end of the line with some CA to so the line itself becomes a needle. I remove excess CA from the line by running the end between my pinched thumb and fourfinger. The line will form a thin, hard needle but them you have to get the glue off your fingers. It's worth it though, because fighting a the fraying end of a line to get it to go through a tiny block is very frustrating, and you can't use a wire threading tool on the smallest of blocks. If you try, you will split the block in twain. <-- I get to use this obsolete, fancy word for the first time, showing my age. Don't hate me.I see where I went wrong: DDM only has pearwood blocks down to 2.5mm. Boxwood blocks, listed separately, get as small as 1.5mm.
I dare you to make that suggestion to @dockattner …Aha! Serves you right for being so particular - think about lowering your standards![]()
Blessings.
Chuck
.You're so lucky! There's never a parking spot available at our local tanuki store...We decided that the garden needed a tanuki, so Saturday was consigned to a trip to the tanuki store:
We did not get the 2m tanuki lurking in the back…
Oh yea, the gnomes, the jolly buddha rubbing its belly did come to mind as well.The American version is the vast numbers of garden gnomes at the tree nursery or garden center.
