Yacht Gretel Mamoli 1:54
Hello everyone,
That means the lower part of the second layer is now finished too.
It consists of 4mm mahogany, which, like the walnut above it, came in beautifully cut strips.
These were actually a little warped, but that turned out to be an advantage in the end.
This meant that, just like with the walnut strips, I didn’t have to soak them in water and bend them.
Next, I’ll be cladding the keel before putting the finishing touches to it.
Have a lovely Sunday, everyone
Translated with DeepL.com (free version)
Hello everyone,
So, the hull and the keel are now finished and sanded down.
As you can see, I’ve also fitted the windows and the transom.
I’d actually intended to make both of these myself, just like the door. But in the end, I decided to go with the original parts from Mamoli.
I had a cycling accident last week, which means I can’t go to work at the moment. A Rottweiler thought it had to jump into my side.
That’s obviously coming in handy for the boat-building.
Next, I’ll probably fit the rudder before moving on to the deck planking.
Take care and don’t let anyone push you off your bike.
Hello everyone,
It looks beautiful.
And it is always risky to play with Rotthweilers
Hello everyone,
I’m currently fitting the interior panels with 3mm walnut.
Whilst the wood was drying, I had the idea of making a back panel for the bench with a brass edge.
To do this, I’ve combined 2mm-thick mahogany with 1.5mm round brass.
Best regards
Hello everyone,
Yesterday I planked the bow and aft deck. As you can see, the transom has come loose again.
Well, I was clever enough to varnish the bonding surface before fitting it.
But that’s just as well – I wasn’t too keen on the way it looked. The rudder didn’t quite fit properly either. So I quickly planked the back of the transom with 1mm-thick walnut and created space for it by sanding out a recess.
Cheers
As I’m still sitting at home with a swollen calf, I was able to get on with the railing.
The assembly instructions specified six 1x1mm strips of boxwood per side. You’re supposed to bend these and join them together to make a 2x3mm section.
As that sounded a bit daft, I went to the trouble of shaping a 2x3mm strip of walnut accordingly and fitting it.
I’ve also designed the cabin edge to have a slight overhang rather than being flush. I think it looks better that way.
The planking on the foredeck didn’t have a neat finish where it met the side of the hull. So I used the spare 1x1mm boxwood to fit something like a drainage channel. That isn’t actually part of the Mamoli instructions either.
Take care, everyone
Hi Pfälzer,
Sorry to hear you’re still dealing with the aftermath of playing with the Rottweiler.
But it does have the advantage that you can get on with your precision work.
Impressive how you're adapting the kit to your own liking!
Greetz, Peter
To say I’m struggling with that would probably be an exaggeration – I’ve only just been home for three weeks.
I’m back at work on Monday, and then the next holiday will be here before I know it.
Next week we’re getting our new car; the one we’re currently leasing is going back. There’s always something to do.
I enjoy making little modifications – here’s the next one.
Mamoli wanted a sheet of plywood on the cabin that was to be panelled. So why not use 2mm-thick precious wood straight away? A subtle boxwood strip as a border and that’s it.
The first rough sanding isn’t quite up to scratch yet. But once the door frame’s fitted, it’ll be finely sanded.
After that, a few cast parts will probably be replaced with wooden fittings – the cleats, for example.
Regards
Welcome to the Sunday Report
Today I focused on the cabin roof. I fitted the door cover and carefully sanded, waxed and polished the roof.
I also ended up treating the lower part of the hull with antique wax after all. The leather grease had ended up looking a bit too dull for my liking.
I’ve covered the deck hatch on the foredeck, along with the frame underneath, with 1mm walnut.
I still need to fit a ladder there. I’m not sure yet whether I’ll make a hatch – the plans don’t include one. But it would actually make sense.
Plus a bit of bling at the stern.
Back to work tomorrow, so the Gretchen will take a back seat again.
Wishing you all a lovely week
Well, this is getting a bit funny here.
I built the hatch according to the plans and used the ladder made from parts in the Mamoli construction set.
Well, what can I say? Due to the design, the average Italian isn’t exactly the tallest.
But even he can’t squeeze through that tiny hole. If you take the scale into account, at best only an underdeveloped toddler could fit through. It’s 18 mm from the deck to the floor, which works out at just 97 cm at 1:54 scale. That’s a storage space only if you’re being very generous. So I think I’ll leave out the ladder and make a hatch cover instead.
What do you think?
Good morning, everyone,
I’m up at the crack of dawn today. That’s because we’ve got a new car. These days, you end up spending the whole Sunday in it, setting everything up just the way you want it.
Funnily enough, a car like this doesn’t even have a proper key anymore, just one of those rectangular things. So yesterday I sat down and made a little holder out of scrap wood. Unfortunately, you can’t just hang it in the key box like that.
Apart from that, I was able to fit Gretchen with a few nail benches and the mounting plates with the fittings. To do that, I had to carve a small recess into the skirting board.
Best wishes to you all
Good afternoon Pfälzer,
I know what you mean… But if you just take some time to get used to it, it really pays off.
It is very nice and safe to keep your hands on the wheel and simply ask Google to turn the air conditioning, the heated steering wheel, or other functions on or off.
Best wishes.
Gretel is really looking good. The fine detail is really holding up under the close=up photography.
