I made the initial cuts on my scroll saw. That got me fairly close. (I really would like to find a more precise tool than this. Using a jewelry saw and doing it completely by hand is a non-starter.) I followed up with a spindle drum sander, my mini belt sander, and finished up with the recently acquired set of jeweler's files.did you use a jewelry saw and files to cutout your crosstrees?
those small pieces that need to be fabricated are really hard. For every one piece I probably waste 3. I do have a scroll saw, but I have a hard time with it. Hard to control but maybe I should use it more often and practise more.My primary tool was a crappy scroll saw. That gets me fairly close. (I really would like to find a more precise tool than this. Using a jewelry saw and doing it completely by hand is a non-starter.) I follow up with a spindle drum sander, my mini belt sander, and finish up with the recently acquired set op jeweler's files.
I have the main crosstrees left to make. I'll take pictures of the process in more detail and post those when I'm done with them. The trestle trees are cut with precision with my Proxxon mill.
are those to be painted? I may resort to my 3d printer if they are. My scroll saw skills aren't the best and I don't have the patience for scroll saw work.My primary tool was a crappy scroll saw. That gets me fairly close. (I really would like to find a more precise tool than this. Using a jewelry saw and doing it completely by hand is a non-starter.) I follow up with a spindle drum sander, my mini belt sander, and finish up with the recently acquired set op jeweler's files.
Initially I glued the patterns to boxwood blanks thusly:View attachment 636577
but when I started cutting out the trees,
I realized it would be better to have something to hold onto when shaping them. And switched to this technique:
I didn't get a picture of me trimming the inside arc on the spindle drum sander, but to shape the outer arc, the belt sander proved to be quite the time saver.
The rest was done with hand tools - primarily the set of Grobet USA files.
but yours look amazing.are those to be painted? I may resort to my 3d printer if they are. My scroll saw skills aren't the best and I don't have the patience for scroll saw work.
that's a good idea. I may have to source some as well, not sure yet what I am going to do.No, I'm not painting anything, as I'm going for a natural finish across the board. I can't hide mistakes easily, hence the attention to detail.
I've found that working with boxwood solves a lot of problems. It's hard enough not to break when working with small pieces, and it does not scratch easily.
I'm glad I loaded up on material before Joe Volpe went out of business.
The scroll saw merely gets me close. Either the machine, the blades, or my skills are inadequate, but I have to allow at least a 16th of an inch margin and make up the difference with other methods.
Except those of observation. Go back and have another look, those blocks don't belong on this particular crosstree. But thanks for the compliment.A fantastic micro-construction, Peter. You've got skills!
Looking East over Lake Michigan about 40 miles north of Chicago.amazing scenery!
