I purchased this kit off marketplace for $20.00. I think it was made in the 90’s. The walnut parts and plywood are just die stamped. Sawing the parts out obviously requires another skill set.
I’m not for sure if I was supposed to sand the hull. I did sand down the bow so the keel fit better at the bow.
Planking went quick. It probably will show. I did the port side first. The starboard side I planked down so the garboard plank could reach it. I’m not sure if this is correct but it was easy.
I just started this kit so I could work on it when I get slowed down on the other build I’ve got going.
