Albatross by CharlesEdward – Constructo - 1/55 –
September 20, 2026
Finishing manual Page 30 of instructions: Davit’s Installation. The Davits comparison photo.
This photo comments on the installed Davits:
Manual Page 32 of instructions: Foremast and Mainmast channels installation.
Using the 1.5 x 5 mm boards, shape two each of part 40 and part 41, with part 40 being the foremast channels at a length of 30 mm and part 41 the mainmast channels at a length of 26 mm. Notch the five notches on #40 and the three notches on #41 and attach to the outboard bulwark positioned to match the plan.
Photo of the installed channels both fore and main mast.
The port side installed channels, I just used white wood glue and masking tape to set the parts onto the hull. [Photo_10]
Manual Page 40 of instructions: Cap Scuttles installation.
Using 1.5 x 4 mm stock make up parts 54, 55, 56, 57, and 58; cut seven Part #54 from 1.5 x 4 x 28 mm. strip, two Parts #55 and two Parts #56 are 1.5 x 4 x 29 mm. and 1.5 x 4 x 33 mm. Sepelli wood strips, and two Parts #57 and two Parts # 58 are from 2 x 2 x 33 mm. 2 x 2 x 37 mm. Manzonian wood strips. Follow the instructions and illustrations to complete the Cap Scuttles part.
The cap scuttles and helmsman base before the frames are installed.
Framing the cap scuttle.
Cap Scuttle drying.
Manual Page 42 of instructions: Helmsman Base and frames and the included pre-cut Capstan installation.
Very similar to Page 40 of instructions above; Cut Parts 59, 60, 61, and find 62; but this time only three Parts #59 using 1.5 x 4 x14 mm. Sepelli wood strips, then two Parts #60 and two Parts #61 from 2 x 2 x 2 x 13 mm. and 2 x 2 x 19 mm. to form a frame around the base from Manzonian
wood strips. The Helmsman base awaiting framing.
The Helmsman base frames are just 2 x 2 x 14 and 16 mm. This is An extreme closeup showing that the caliper is set to 14 mm. [Photo_08]
An extra photo of the digital caliper reading of the cap scuttle parts before gluing them to each other. [Photo_09]
Coming up next Manual Page 34 of instructions: Fore pinrails, Foremast & Mainmast pin racks.
Thanks for checking in, until next time.
September 21, 2026
The pinrails and pin racks consist of three different numbered parts; two Parts #42, four Parts #43, and two Parts #44, all made from 1.5 x 4(5) Sepelli with lengths of 11 mm, 32 mm, and 15 mm, respectively. I have the 4(5) mm. listed as such because I could only find the 5 mm wide stock, there was no 4 mm wide stock included in the kit, so I have always been using the 5 mm stock for both 4 and 5 mm parts.
Cut the parts listed above and mark where the holes are based on the plan illustration. Drill 1.5 mm. diameter holes to fit the belaying pins for future rigging of the model. Now to do this correctly I used a 1 mm drill bit to start and used math to drill the holes in the center of each part, then half the distance to mark the next center and fill in the remaining holes based on the plan. I decided to drill all of the holes before I cut each of the pieces to the required length. Finally used a 1.5 mm. bit to make the holes the correct diameter and dry fitted each and every one with a belaying pin.
This photo shows the three parts needed for all of the pin racks, the two smaller parts have four holes but the smallest one should only have three holes, per the rigging instructions.
There are only 47 belaying pins included in the kit so not all of the pin racks will be filled with belaying pins, only the ones needed for rigging.
All four of the Parts #43 showing below.
I broke one of the smallest pin racks and had to replace it.
This magnified photo shows the cut-out I had to make on this particular pin rail to fit on the bulwarks with the rough timbers. I actually did install this one where it belongs along the starboard fore mast.
Since I have installed the two fore pinrails and one of the Main / Fore mast pinrails, There are only two Parts #44, (15 mm length), and three remaining Parts #43, (32 mm in length), ready for installation along the bulwarks. The Part #43 required 11 pin holes at 1.5 mm diameter.
The fore pinrails shown installed, however the port side one broke in half when I tried to twist the belaying pins in the holes. I actually repaired it with superglue and at the same time installed the three belaying pins required for the rigging later. I had forgotten how hard these sometimes are to rig being so small.
The installed Part #43 on the Starboard Foremast, I used a drop of super glue to the ends but white wood glue to all of the between areas.
An unmarked photo of the Part #43 to be installed next time.
Next up the completion of installing all of the pinrails and pinracks along the bulwarks.
September 21, 2026 – Second Posting
Completion of Manual Page 34 of instructions:
Fore pinrails, Foremast pin racks and Mainmast.
So what I decided to do with the remaining pinrails and pinracks is to glue pieces of wood along the bulwarks where the pinrails will be installed, instead of cutting out 1 or 2 mm notches to install the part. This proved to be much easier and does the job better as it extends the pinrails out about 2 mm, which will make it easier to rig up the belaying pins when needed.
A photo of all of the pinrails / pinracks installed, (Parts 42, 43, and 44), onto fill-in wood pieces for easier and stabler installation, and ready for rigging.
A closeup of the Helmsman base installed under the tiller as well as the stern pinracks Part #44.
Installed Parts #43 along the Mainmast area of the model.
Installed Parts #43 along the Formast area of the model, as well as the fore pinrails.
Coming up next, I will show the installation of all of the deck furnishings that are required by the manual instructions.
All Deck Furnishings Installed onto the Main deck.
As promised in the last post, the installation of all of the deck furnishings that are required by the manual instructions, up to this point.
The final deck furnishing is the Logbook Cupboard, which includes a pre-cut Part #63, using several 0.5 mm Sepelli veneer board to plank all of the sides, a couple of base frames made from 2 x 2 mm boards and roof pieces made from 1 x 3 x 24 mm Manzonia board.
The Logbook Cupboard under construction, showing the base pieces and the drying glue waiting for me to place the roof assembly on the right of the picture.
The finished logbook cupboard installed in place on the main deck of the model near the Helmsman base. Also a look at the life boat davits, stern pinrails, tiller and aft grating hatch.
A view of the installed capstan, Midships grating hatch, Main pinrails, main mast deck hole and Cap Scuttles.
The installed Foremast Pinrails, anchor davits, Fore pinrails and forward grating hatch, with the foremast deck hole.
Overhead angle of the current main deck furnishings layout all installed for better or for worse.
Manual Page 46 of instructions: Mast pinrails, both Fore and Main pinracks installation.
Consists of Parts # 68, 69, 70, 71, 72, and 73; using 3 x 3 mm stock make up parts 68, Pin rack columns, (length of 10 mm – eights pieces required), 70, Bitt Uprights, (length of 16 mm – four pieces needed), 71, one Bitt Cross, (length of 29 mm), and one 73, a longer Bitt Cross, (length of 18 mm), and finishing using up the 1 x 3 mm stock left to make six Parts #69, Mast Pinrails which will need three 1.5 mm holes in each of the six parts for the belaying pins to be installed later. This time because the six parts basically use all that is left of the 1 x 3 mm boards included in the kit, I cut them all first and checked the length of 14 mm, planning to drill the holes later. Part #72, Bitt Curve, is precut and in parts pack #4.
NOTE: There is a final part #114 that will use almost all of the remaining 3 x 3 mm board as it is 16 mm in length and there are eight pieces required, (total 128 mm.), so a total use of approximately 319 mm of wood stock, which is just about the size of the last 3 x 3 mm board included in the kit.
This section has proven to be quite difficult and some of it is caused by the kit including impossible widths of wood stock to drill three 1.5 mm diameter holes into all six Parts #69. The length required in the instructions are really NOT helpful and I should have bashed the parts with a better piece of wood, after all I have loads of lumber I purchased from some online ship model lumberyard that was going out of business years ago and was having a big sale of almost all of their remaining stock. This includes 2 x 3 mm boards that I had to substitute for the Foremast Pinrails piece that I destroyed, so I have to replace it. This wood board could handle the three 1.5 mm holes much better than the original 1 x 3 mm boards that I used following instructions. I split almost all the cut boards while drilling only the starter hole of 1 mm drill bit size. Fixed most with liberal application of superglue, but the broken foremast pinrails was just not usable anymore.
It took most of the day to cut all of the necessary pieces per instructions and shown below are all the pieces cut. I should have added a tad more length to two of the Part #69 to make room for the three 1.5 mm diameter holes since those pieces are short and therefore crowding out the two outer holes making it harder to rig those belaying pins.
I was thinking about the belaying pins included in the kit only number 49 or 47 parts, not enough to put a belaying pin into every pin hole on the pinrails, so I studied the rigging plans and found out that the Mainmast Pinrails would only be using the below pins for rigging, not the entire 9 holes that I drilled. This would have been more helpful if I noticed it before I made the parts.
The Mainmast Pinrails may only use five of the holes for belaying pins for the rigging plan, however the Foremast Pinrails need to use all nine holes filled with belaying pins for rigging. Knowing this now I thought about how to make this next Pinrails part and decided that, besides substituting 2 x 3 mm boards for Part #69, (1 x 3 mm boards), that I would make one of the pieces, the piece that is at the bottom or top, (depending if you see an upside down ‘U’ or a normal ‘U’), of the U-shape piece should be a little bit longer in length. This would not IMHO cause it to look too big for the Foremast plus give me more room to drill the 1.5 mm holes in all of those parts.
Per the instructions I have to cut out recesses in Part #70 to fit both of the Bitt Crosses. I will do this by sawing the 3 mm notch and then use a series of needle files to square out the notch, I am not sure if it wants me to do the same for the Bitt Crosses, but it would make sense to do so. [Photo_09 showing notched Bitt Uprights and Bitt Crosses?]
The installed Bitts and Pinrails on the main deck of the model, the Bitts are not yet glued to the deck, I have to check the position of both of those parts before I glue.
Next up, the continuation of the instruction manual Page #46, finishing and installing the mast pinrails.
September 24, 2026
Here are some extra photos that I took while constructing the Bitts and others, just wanted to share in the spirit of full disclosure.
The two Bitt parts completed, the one on the left is the Anchor Bitt and bitt cross, while the small one to the right is the Bowsprit Bitt and cross Bitt.
The terrible looking mainmast pinrails are just not as good as the replacement part for the broken Foremast pinracks. I almost want to rip out the main mast pinrails to recreate that piece in a better-looking form. After seeing this photo, I would make the side pinrails about 2 mm longer to look much better and have more space for the pinrails columns, the rigging of those belaying pins will be much easier.
An overview shot of all of the current deck furnishings laid out onto the main deck, I used the main, foremast and bowsprit for reference to the placement of each piece.
The Foremast pinracks, anchor bitt and bowsprit bitt in position but the two bitts are not glued yet, just dry fitted for the final placement of them.
The cap scuttle mainmast pinracks, midship grating hatch, capstan, aft grating hatch, the logbook cupboard, and the Helmsman base and tiller on deck.
Starboard side view of the deck furnishings before I finished the two pinracks and Bitts.
Starboard side view of the two added pinracks using the masts and bowsprit as position reference.
The two Bitts again, just a clean photo of the two parts before gluing onto the deck.
The tow bitts accurately positioned onto the deck with the glue drying.
The full view of all of the deck furnishings sans the masts for a better view, the bowsprit is still for reference positioning.
Next up, the installation of the deadeyes onto the Main and Foremast channels.
September 25, 2026
Manual Page 48 of instructions: Deadeye installation onto the Main and Foremast channels.
This step consists of Parts #14, #74, and #75; the nails in parts pack 1, the Deadeyes in parts pack 5, (32 of them), and the rigging screws in parts pack 12, the 0.05 mm wire by 50 mm, 16 of them).
Cut part 75, Deadeye Screws, and plait them around the deadeyes, part 74. Use a 1.0 mm bit to drill corresponding holes to take the Deadeye screws and fix in place using the nails part 14. Since you have to use superglue to install the Deadeye Screws into the hull, why use Part #14, nails anyway, so I opted out to just use superglue, forget the nails. You have to drill 1 mm holes anyway so the deadeye screws work by just a dab of glue and insert with a needle nose plier.
Comparison of what the instruction manual pictures and my results that I got when I did the plaiting myself. The right one has the bends in the part, while the left one doesn’t.
A closeup of the completed deadeye and deadeye screw with the bends for the deadeye and end of screws.
The unbent Deadeye / Deadeye Screw, ready to be bent.
This is a photo of the Port side Fore and Main channels with the deadeyes glued into place.
I found a scrap wood dowel that matches the diameter of the Deadeyes I am trying to make, then start twisting with my thumb and forefinger until the wire sets into the deadeye grove. The picture below shows a 4 mm. dowel which is the same diameter of the deadeye and start a circle that matches the dowel, and then gently slip it over the deadeye like a noose, and once the plait starts I use needle pliers to hold the deadeye and another one to twists or plait the wire around the deadeyes.
Th five last deadeyes ready to be installed onto the starboard channels. Note that all of the deadeye holes are set in the correct direction of down, than I dabbed a bit of superglue to secure it for th rigging tasks coming up later, they all do look pretty good.
The deadeyes are installed on the Starboard side channels.
Closeup of the starboard main mast channels and deadeyes.
Closeup of the starboard foremast channels and deadeyes.
An overhead shot of the current model main deck with all of the furnishings finally installed.
Coming up Next will be installing the anchors Manual Page 50 of instructions.
Manual Page 50 of instructions: Assembly of the anchors.
Includes Parts #76 through #82 ,(2 Eyebolts modified to become a hook), all in parts pack #4, 5, 6, and 7. I must have broken 4 or 5 eyebolts trying to modify them to be a hook. I don’t know what I will do for this but will think of something. Another thing I was totally flummoxed that I could not hook the anchor hole with my hook blocks, frustrating to say they least, then after a good night’s sleep, I realized that since I have to connect the anchor chain to the anchor via a couple of brass rings anyway that I could also use those same brass rings to hang the anchor from the block and tackle with the hook installed. Breaking out my tackle box of rigging tools, threads and wax I started getting ready for my first rigging task on this model, hmmm I have quite a collection of great rigging tools, I had forgotten.
Parts #76 are the 2 metal pre-molded Anchors, #77 are the four pre-cut wooden anchor stocks, #78 is the Black Thread to be used to tie together the two anchor stocks, #79 are the 2 rings, #80 is the Chain pieces to be cut into two 280 mm lengths, #81 are the two 3 mm block and tackle, and #82 are the two eyebolts to be modified into a hook, (see manual instructions / photos). A comparison photo using the instruction manual for reference.
The plain un-accessorized assembled anchor and anchor stocks, I will have to trim one hole from the anchor pieces, I also painted the plain metal anchors black.
The assembled anchors with the instruction manual backdrop for comparison.
The two anchors with connected chains using the brass ring; one with the Part #78 threads installed and the other one no thread yet. I am thinking not to wrap so many threads for the second anchor for a cleaner look.
Photo_04.JPG With the completion of the two anchors linked to the chains, this completes this posting of this build log.
An additional photo of the wrapping part 78 process during that step.
Coming up next: Installation of the Anchors onto the Model.
Looking at some other posts and it looks like I reversed my anchor's stock facing the sloping end toward the anchor instead of toward the end of the anchor. Oh well live and learn, I actually struggled with this decision for hours wondering what was correct. Guess I should have done a bit more research on this web forum first.
September 28, 2026
Today I post the last few days of work on the model.
Manual Page 52 of instructions: Installation of anchors onto the model.
Includes Parts #82 through #85, all in parts pack #6, 7, and 8.
Parts #82, (2 Eyebolts to be inserted into both port / starboard anchor davits on the leeward side), 83, (Beige Thin Thread), parts #84, (2 Belaying Pins already installed into the fore pinrails as rigging pin 43, both port / starboard, finally parts #85, (four Hawse holes and Open Chocks).
The photo below shows the instruction manual illustrations for the hull installation step, note that you install the hawse holes from the outboard bulwarks side.
This next photo shows the instruction manual illustrations for the deck installation step, see the hawse holes #85 installed to accommodate the insertion of the end of the anchor chain.
I needed to drill two 4 mm. holes in the deck and two 4 mm holes in the bow bulwarks to insert four Parts #85, Hawse Hole / Open Chocks. As shown in the instruction manual, insert the Hawse Holes from the outboard bulwarks on the bow to run the chains through and insert the end of the chains into the Hawse Holes on deck, to let it hang. The photo below shows the chains laying on the deck looking toward the port side with everything seemingly looking good.
I tried to simulate extra line around the belaying pin which I believe looks fine this is the port anchor davit.
I again tried to simulate extra line around the belaying pin which I believe looks fine, this is the starboard anchor davit.
Full on prow view of the hanging anchors looking aft, I think that the uneven length of the block and tackle simulate real life a bit better, all the rum drank would cause irregularities.
The Starboard block and tackle rigging with the anchor hanging as it would.
The Port side block and tackle repaired rigging, I missed the second block and tackle hole and went straight to the belaying pin #43), with the anchor hanging as it would.
Closeup of the starboard rigging of the anchor davit.
Closeup of the port rigging of the anchor davit.
Coming up next: The assembly and installation of the guns and gun carriages onto the model.
September 29, 2026
Manual Page 54 of instructions: Assembly and Installation of the six included guns onto the model.
Includes Parts #86 through #90, all in parts pack #2, #6, and #12. Part 86 is precut Gun Carriage sides 12 count from part pack #9. Cut out the gun carriage bases , (Part #87), from 1.5 x 5 x 12 mm from the included Manzonia wood board. Part #88 is the thick 2 mm brass rod of which I cut 12 at 10 mm pieces for the wheels of the carriages. Part #89 consist of the 1 mm brass wire cut to six 10 mm pieces to use for the Gun Shafts; both of these wires were in parts pack #12. Finally Part #90 is the six brass cannon in part pack #9.
First photo are of the full-page manual illustrations for this step, the next three photos are closeups of the four different illustrations.
The gun carriage base and sides to make six of them.
The cut 2 mm wire is to simulate the carriage wheels, unfortunately with the wheels on the guns did NOT fit the model, so off went the wheels, the difference between a model kit that cost just around $100.00 and a better kit costing several hundreds of dollars.
The guns and gun shafts to be cemented onto the gun carriages for installation onto the model.
This pictures show two finished carriages and one that is waiting to be glued together.
The final three gun carriages completed ready to cement the guns and gun shafts in.
An overhead view of the six cannons installed onto the model’s deck.
A closeup of the forward main deck with Guns, chains and etc. installed.
A closeup of the after / leeward main deck with Guns, and furnishings all installed.
Coming up next, we venture boldly into assembling the Masts and Yards starting with Manual Page 56 of instructions: Assembly and Installation of the Bowsprit onto the model.
September 30, 2026
A very small update with no photos whatsoever, just boring information. It is time to Taper all of those wooden rods I cut and checked on September 15, 2026. I will use my craftsman drill as the lathe and medium to fine sandpaper with a extra heavy duty leather gloves on to protect my hand from the heat as the drill rotates the wooden dowel. However I did manually sand the Bowsprit and Jib Boom dowel, and it worked out very well indeed, must be the Anatolia wood included the kit for all of the dowels. Easy to sand, must be gentle with the Craftsman drill and hand sanding when I do that today.
I made an Excel Spread Sheet for the size specs for each mast, yard, boom and gaffs, (diameter, length and taper diameter); here is the table specs for each part. My interest is the Taper To: Column for each part. I will be checking this with the digital caliper for most of the day as I spin the dowels.
Part #What it isSizeTaper to:CommentsMeasured Cut and Marked
91Bowsprit6 x 112 mm4 mmPage 56; Bowsprit parts and assembly.Done
92Jib boom4 x 1151.5 mmPage 56; Bowsprit parts and assembly.Done
94Martingale2 x 27 mmDonePage 56; Bowsprit parts and assembly.Done
96Lower foremast6 x 180 mm4 mmPage 58; Main and foremast parts and assembly.Done
97Fore topmast4 x 165 mm2.5 mmPage 58; Main and foremast parts and assembly.Done
98Lower main mast6 x 189 mm4 mmPage 58; Main and foremast parts and assembly.Done
99Main topmast4 x 172 mm2.5 mmPage 58; Main and foremast parts and assembly.Done
106Fore yard4 x 162 mm2 mmPage 62; Fore and Topsail yards parts and assembly.Done
108Topsail yard3 x 96 mm1 mmPage 62; Fore and Topsail yards parts and assembly.Done
110Topgallant yard2 x 66 mm1 mmPage 62; Fore and Topsail yards parts and assembly.Done
111Foremast spanker boom4 x 98 mm2 - 2.5 mmPage 64; Boom and Gaffs parts and assembly.Done
112Mainmast boom4 x 168 mm2 mmPage 64; Boom and Gaffs parts and assembly.Done
113Gaffs (two of them)3 x 98 mm1.5 mmPage 64; Boom and Gaffs parts and assembly.Done
October 01, 2026
Manual Page 56 of instructions: Taper, Assembly and Installation of the Bowsprit onto the model.
I made an Excel Spread Sheet for the size, (diameter, length and taper diameter), posted here on September 30th; a summary extract for these parts follows: #91 tapered to 4 mm; part #92 tapered to 1.5 mm.
Includes Parts #91 through #95; Part #91 is the Bowsprit from 6 mm dowel x 112 mm length and tapered to 4 mm diameter, part #92 is the Jib Boom from 4 mm x 115 length, and tapered to 1.5 mm (both have been cut and tapered), #93 is pre-cut and in parts pack #3, #94 is the small Martingale made from 2 mm dowel x 27 mm length, (I used a round toothpick instead), #95 is a small block made up of 2 x 2 x 5 mm wood strip.
This marks the start of our mast and yards construction phase of the model, and I took the time a few weeks ago to ensure that all dowel wood stock was accounted for and cut to size, though not entirely tapered yet just the ends to remind me which is the top of the mast. Per the plan view there should be a single block, 105 and a double block 95 attached to the Bowsprit for standing rigging installations later which were not included in his manual page of instructions.
The photo below shows my un-tapered parts #91, #92, and #94 is a round toothpick already tapered with the included small dowel to compare which one will be better to use.
The next three photos are sections of the manual illustrations for this step:
First, The two mast pieces for assembly are shown first.
Second, the five assembled pieces to complete the Bowsprit, before installing onto the model. I added the photo of my completed part to compare the two, my part vs what the instructions show as the finished piece, my part is the second photo.
Comparing my part to the instruction photo.
Third instruction manual illustration, the assembled Bowsprit, jib boom and Martingale installed on the model.
My assembled Bowsprit with jib boom and Martingale ,(yes, it is a round toothpick cut to size), all glued together, the instructions say to varnish the part, I am not sure I want to do that or if I have any varnish that isn’t solid. I actually tapered parts #91 & #92 by hand sanding and they came out great. The dowels really sanded fast and clean, must be the Anatolia wood included in the kit for dowels.
Another photo of the Bowsprit assembly drying just a bit more before I dry fit it onto the model. I will have to be gentle with the Anatolia while using the Craftsman drill tomorrow when I complete all of the mast and yards tapering.
Bowsprit dry fitted into place, I am thinking of adding the missing blocks so that they are attached before I glue this in place in anticipation of whatever rigging assignment they are for.
I did add the two blocks to the part and here is the final Bowsprit with Martingale, Jib Boom and both blocks installed ready for standing rigging to be applied.
Bonus photo of the Bowsprit assembly dry-fitted onto the model once again but with the blocks installed.
Coming up next will be Manual Page 58 of instructions: Tapering, and Assembly of the Foremast and Mainmast. join me for that post.
October 03, 2026
On a side note before we start, I have completed tapering all of the dowel parts to the proper dimensions all waiting for the rigging details of blocks, eyebolts, etc. before installing onto their proper position on the model. Each part will be the subject of its own post on this log.
Manual Page 58 of instructions: Tapering, and Assembly of the Foremast and Mainmast. I made an Excel Spread Sheet for the size, (diameter, length and taper diameter); a summary extract for these parts follows: #96 and #98 tapered to 4 mm; part #97 and #99 tapered to 1.5 mm.
Includes Parts #93, #96 through #102; #93 is the Precut cap in parts pack #8, #96 – Lower Foremast, 97 – Fore Topmast, 98 – Lower Mainmast, and 99 – Main Topmast, 100 – four crosstree beams Precut in parts pack #8, 101 – four Crosstrees 2 x 2 x47 mm, two 102 – Crosstrees 2 x 2 x 29 mm. All Dowels have been measured, cut and fully tapered weeks before.
The photo below shows my un-tapered parts #96, 97, 98, and 102.
The four mast pieces for assembly are shown, Lower Foremast , Fore Topmast and Lower Mainmast, Main Topmast.
The five crosstree pieces that make up the two crosstrees, (Fore and Main Mast), before and after assembly are shown.
The crosstrees when assembled did not leave enough room for insertion of the lower and upper masts. I had to file some material off of the crosstrees using a circular file to allow the completion of the mast assembly. Also fitting the lower and upper masts together took patience to ensure a straight mast which took most of the day. After spending a night drying and setting, I added the cheeks to both masts and allowed them to set for a time also.
Both of the completed mast assemblies are finished awaiting the attachment of the rigging single and double blocks, eyebolts, and lower mast rings, which I had to check that the rings did not interfere with the placement of the masts being set into their proper mast openings with the correct slant towards the stern. Each mast used 10 single blocks and 1 double block, using wire #116 for all of the ‘short’ connections and thin black thread for each of the two single blocks that are ‘long’ connections.
Mainmast assembled and waiting for the rigging details to be attached.
The Foremast assembled and ready for rigging details to be attached.
I still have to add all of the rigging details before I actually install the two masts onto the model, but I dry-fitted the masts and tried to set the straight and positioned with the proper slant towards the stern, but of course they won’t be straight until I add the glue. Looking straight on toward the prow looking aft.
Port side view of the masts which does show a close proximity to the actual final angle that they are supposed to be at. [Photo_08]
The starboard view of the model, I still have not glued the bowsprit onto the model either. [Photo_09]
Looking at the stern facing forward. BTW, the kit did NOT include a life boat or any instructions on how to rig it, I did buy a couple of ships boats approximately the correct scale but if I want to rig the Constructo model with a stern life boat, I will have to model it after the OcCre model which did include a fully cast unpainted metal life boat, but I hope to use the one I purchased as a kit. [Photo_10]
Next up we continue with finishing the two masts with Manual Page 60 of instructions: Installation of all the Rigging details for both masts BEFORE installation onto the model. Hope to see you then.
October 03, 2026
Are you sure your crosstrees are the right way round? Usually, the short athwatship part is at the forward end of the mast.
I doubled and tripled check the instruction manual photo and the shorter end is toward the lower masts.
The short end is toward the lower Foremast and Mainmast, aren't they?
Comparing the two photos above, they LOOK correct to me.
Ok, you did follow the plan. But the crosstrees as mounted here would lead the topmast shrouds forward of the mainmast. Looks a bit unlikely to me.
Lower Foremast is toward the stern of the mode, while the uper foremast is toward the prow of the model. The smalles crosstree is on the after side of the mast.
The upper mainmast is forward of the lower mainmast, the smaller crosstree is on the after side of the mast.
Plan sheet of the starboard side of the model showing clearly that the Lower mainmast and foremast are to the stern or behind the upper mainmast and foremast.
Unless I totally see this wrongly, isn't my main and fore mast correct with the crosstrees?
I see what you are saying, the plan sheet does show a slight forward position from the crosstrees, doesn't it? So could the instructions / plan sheet be so wrong here that I have been mislead? The masts both have a slight angle toward the stern, mainmast is more prominent, the foremast is less so.
