La Belle - CAF Models 1/36 by Signet
Continuing on with making and installing the frames, there's something you need to watch out for, if you're using the pearwood 3-piece frames. The method I used to assemble the frames, as shown above, was to place the upper side portions of the frames in place, then add the bottom portion on top and aligned with these. I've been placing the "top" of all frame sheet pieces up, so that the bottom portion, which has a vertical centerline in it, can be used to center the frame in the jig, as shown below:
You will notice above that the pieces also have the lines used to bevel the edges to conform to the hull shape. The problem is, if you place the sides into the opening, then add the center/bottom piece, and glue up the assembly, when placed into the jig, the bevels will be on the wrong side (in this case, the back side), when they must be beveled on the fore side. The solution (or at least one of them) is to place the side pieces back-side-up, then the bottom atop them. Then, when placed properly into the jig (frames 1-6 have the outer side parts facing forwards, 7-15 aft:
I chose to keep the center piece facing upwards because I used the centerline to help center the frame. It won't really be visible, and the bevel lines on the center frame don't really apply, because that portion is no longer at the frame location.
This is where I am so far. Only 1 frame broken so far (#1), and that's because it stuck in the template sheet, and I was too anxious to properly un-stick it.
The last ribs go in place:
And, without the jig we have:
Now I have to making the surrounding 1.5 x 2.5mm strip into a moulding, using one of those razor-blade-type thingies I have left over from another build. One is not supplied with this kit; I guess they figure you'll use the one for the main boat. I haven't had much luck making these, in fact I've never been able to make one acceptable enough to use on a kit. Here's hoping for a first time.
I bought a set of molding blades
ArtesIana Latina Micro Moulding Blades
About $13.00
Thanks. Have you tried them out yet? I received ones with 3 different kits, 1 from Croatia, 2 from China, and they all looked nice, being photo-etched stainless, but they weren't hard, deformed easily and didn't cut well. Mine made from a thick razor blade cut really well. The AL ones look great, lots of neat profiles, but will they cut?
The ones I received from Artesiana Latina worked great and did not dull using Lime and Bass woods. I didnt.try them on any hardwoods yet but intend to use them on Pear on my next model.
Molding blades? To create moldings? Can you post what you got, because the ones included with models seem almost worthless.
Your log inspired me to take a look at the CAF catalog.
I noticed they they have a molding scraper.
I'm ordering a longboat kit and getting the scraper also. I have the AL scrapers and do not really care for them. The smaller profiles are really limited IMO.
To be honest, that's the one I tried for an hour or so, and didn't work well. My cut razor blade did more in 10 minutes.
Continuing on with the ship's boat, I've changed my color scheme, so have gone ahead and added the gunwale and stern trim:
The seats, called thwarts, are supported by clamps, as the cross-beams of a ship are supported by clamps. These are glued at specific locations on the inside, and what holds the clamps in place while drying? Clamps, of course:
The clamps are now in place, and the thwarts have been added. The mast (not included in the kit) is located so as to place the mast step:
This is not the final color, but it's what I had on hand, so went ahead and painted the gunwale and molding. I've also added the rollers or whatever the heck they're called at each end, as discussed above and on the What Is This thread:
Here I've shown the "rollers" a bit better and identified them with red arrows:
To be continued.....
Finally decided on a final paint scheme (hopefully) and have repainted the trim on the ship's boat:
Also, while researching other information, I found out what the mystery pieces are in the boat. They drawing and information is located in
The Seventy Four Gun Ship Volume 2 by Boudroit, and text prior to and at the drawing explain it:
So, they're used, mainly at least, for simply lifting the boat into and out of the water. I felt they were too low and wouldn't be stable for this operation, but the center of gravity must be low enough that it is stable. I also felt the width of the rounded area didn't make sense, but once again, I am wrong. I ought to be used to that by now, I guess. But that's good to know, as I think I will display the ship's boat being transferred to the sea, so this is important for me.
Using the hoisting-tackle beams as discussed above to lift the boat (as it currently stands) resulted in the tendency to fall one way or the other, as I expected:
The connection point is just too low for this not to happen. And I expect it to get worse, at least when oars, masts and sail are added, although planking will help a little).
To help with this and apply more weight as low as possible, I brought out my trusty lead rolls (0.5mm thick by 1/2" wide), cutting them into strips, then folding into small pieces:
It's easily cut with scissors and forms easily, as expected. I made small pieces, folded 3 times to provide 4 thicknesses, or a total of 2mm, then tested one:
The idea was to hide small pieces of lead below the floor boards to lower the center of gravity. This is when I regretted leaving the gap in the planks and adding more planks instead. But as my son has been starting to say lately: "It be what it do." Yeah, stupid, but I've started using it too. Don't know if that's a Southern or local thing or what.
So I made a bunch more of them, and super-glued them in place:
At this point the boat frame itself weighs 6.7 ounces, and the total weight of the lead pieces is 7.0 ounces, so this should lower the CG substantially. As a test:
Much better, but I have a hunch there will still be a problem when finished with oars and sailing gear. I'll probably have to make a workaround then, maybe use tan wire instead of rope, or make the rope still. I'll worry about it later.
The lead pieces are barely visible from the top, and should be less so once the hull planking is in place:
Next, I worked on the planking, starting at the top and working down:
I had previously added some small rigging cleats to locations in the hull, but of course my first run of clamps broke them all off. I've learned (again) to add detail after all structure is complete, when at all possible.
While playing with the lead, I imagined rolled sail material laying in the bottom of the boat (made of lead!)... Maybe I can think of something else I could make of lead and locate in the very bottom of the boat to help the CG further. Lead soldier (sick sailor)? Lead water barrel?
Continuing on with the planking:
Afterwards I realize the center thwart was gone. Not just broken, but disappeared. Easy enough to replace, but this just emphasized that fragile stuff should be left off until planking is complete.
Here the planking is complete.
It went fairly well (for me), the main problem being that I beveled one of the planks on the wrong side, so I then re-beveled it on the correct side, which made it narrower, resulting in a gap. I considered trying to fill the gap with a piece of wood, but think I'll use a colored caulk after it's done.
After sanding, it looks a bit better:
I don't have the wipe-on poly I intend to use, so can't put a finish coat on it now.
Since the below pic is of the ship's boat for my Ragusian Carrack (a boat kit by Pavel Nitkin):
I'm going to take this new one as a win!
That's an impressive amount of improvement! Bravo!
Yeah, although a lot of it is the kit. The Nikitin kit was in walnut and the hull planks were not long enough, so stopped short each end. But yeah, it is much better, thanks.
I should have included a photo after sanding the other boat, in which it looks a lot better:
But still....
Continuing on with the ship's boat, I've applied 2 coats of finish:
As shown previously, the rope is just temporary to check the balance of the boat when lifted.
I've added a lead strip along the keel, both to simulate the iron protection often added to French ship's boats and to help lower the center of gravity.
No perfect, but better than my previous similar attempt.
I've also made six oars for use on the boat, and have them set aside for use later:
So, I banded the oars and placed them in the boat:
All that's missing now is the sail to add to the mast and spar I made earlier, so that's next.
While waiting for my sail dye to arrive, I thought I'd add the remaining details to the ship's boat, what I would call a Jolly boat:
Obvious additions include the thole pins and mounts and four cleats (not included in the kit), rudder and the tiller. I've broken so many of these small parts, I have to be extra careful, and I'll be removing the tiller until after completion.
Every time I post a photo, I find more problems or errors or poor workmanship. I had hoped for better, but maybe my eyes are a limitation t this point, as I can't see the problems before photographing them.
The bottom hull appears much lighter than the remaining pearwood on the model. I didn't really notice a difference in the wood supplied, so I think it's more the fact that I sanded the hull planking more, and smoother. When staining, smoother wood will not stain as well as wood that is not so smooth. While the hull planking is not stained, even the final finish tends to darken and mellow the wood. No doubt this wood is lighter than what I will end up with on the mother ship, and while not intended, I kinda like the color.
BTW, I was talking about weights and center of gravity and balance when doing the model and adding items. Here's a run-down on where the weights come from:
5.0 grams - Basic frame without planking.
13.3 grams - Hull planking (surprising to me, weighing 2 1/2 times the frame weight, but structure is miniscule).
1.1 grams - Lead keel, added in part to lower the CG.
0.9 grams - Tiller, thole pins and mounts, cleats, final finish
20.3 grams - Total weight of boat, less anything mounted into it.
2.7 grams - Oar bundle of 6 oars.
1.0 grams - Current weight of mast, spar and first-try of sail, less any rigging.
As can be seen, the boat will not be balanced, when suspended from the mounts in the hull and with the oars on one side and sail with mountings on the other. I have an idea to balance it, but will get into that later, after the sail design and structure is finalized.
