YQ Bluenose Ted R Redux
The Vendor I purchased the kit through has responded suggesting I make a list of each loose or damaged part and send it with a photo. I replied that I dont want to get involved with the jigsaw puzzle it would be to accomplish this. And then if I missed something I would have to go back and try to get them to arrange another shipment. Nevermind the months in delays.
I just want to build a ship model. They are in the business of selling and shipping model kits. They need to either take the loss or file on their insurance.
Well, that is sad.. part by part.. Now there is a chore! I agree they should take a loss, respect the customer and provide another.. it would be good for business all the way around.
Guy
Now Ebay says I have to wait 5 days for the Vendor to send me a return postage label. Either way it's just a matter of time.
I have a replacement kit that I haven't mentiones on the way. It is the correct POF pear version. Hopefully it will.be here today.
It's on now. I have the proper kit in hand and the plans that got separated will arrive today. I'm going to start removing the char from frames and get ready for glueup.
The plans arrived just now.
Yeah
Yeah
Up to a ‘2nd Ted’s Bluenose’! I am looking forward to your first steps, Ted.
I will ad you log to the BN-List.
Thank you Peter. My learning curve on the last one was pretty steep. This time I have all the documentation available and my confidence is high. No doubt that will get blown away shortly.
It's Saturday morning in Southern California and yhe weather is beautiful.
Took a trip to the dollar store for plastic buggies and a felt marker. I'm going to store the frames in indiividual bags until installed.
While doing research on the frame bolting used on the actual ship it was iron or steel bolts, not treenails. My intention is to brass wire treated with brass black for these bolts. . My calculations indicate 30 guage wire at 0.25.mm. Even if I use pbc cobalt drills they will have to be used with the dremel drill press or the breakage will be a nightmare of breakage and stuck drill bit shards. I don't know how I will do the keelson, etc. I'm thinking of using 0.5.mm bits and larger wire for.ease of construction. This would.be much smaller than the nails provided in the kit.
Do you guys think it would look noticeably out of scale?
Construction us even started and the compromises have begun.
I spent all afternoon sorting the frame blanks into seperate numbered plastic baggies. My hope is that this time around I have no confusion as to which frame is which. I don't plan on having to competely dismantle the frame twice again either. I went back and removed all the frame bits from the blanks or sprues whatever is the proper term.
Tomorrow the sanding begins.
As a final aside on the YQ POB Bluenose kit i received. What actually happened is that Ebay stepped in because the seller was non responsive. They started a refund from Ebay. The money hasn't arrived yet but ihave faith in them.
The seller still hasn't sent me a prepaid shipping label. I believe the kit is intact and buildable by someone that has the patience to sort the parts.
If I don't get a shipping label by the time the refund is credited to my account i intend to put the kit on SOS and give it away to someone that wants to build it.
Preferably somepne that isn't in position to afford the kit.
Today I got all of the keel parts sorted and the char is still in place. The fit is almost perfect. Parts 8 and 9 n look like they grew together. The of stack of parts at the aft end are mostly m perfect with maybe a fraction of a mm needing.to.be sanded.
I'm still pretty weak from my inability to exercise enough. A few hours of modeling a day will help
View attachment 644781View attachment 644782
A nice start, Ted.
When you pull the wedge I marked with a ‘X’ a bit back, then the other parts will come more together:
PS: And your new build-log is now the right area: the Bluenose Group Build Logs. It’s the 37th!
The three keel pieces I glued fit together so perfectly that I believe they are correct.
When I go to fit the deadwood and keel post it doesn't line up. When I look closely at the third (Aft) keel piece it stands a little high at the back end of the splice.
The other deadwood pieces fit pretty good but need a little sanding when assembled to the side.
When combined it's not good at all.
My question is what part should i sand
View attachment 645266View attachment 645267
Or modify to get it correct.View attachment 645290
I think i need to trim the top of the upper keel parts so it will slide into place and not leave the opening for the deadwood.too small
Hi Ted. I think you are off to a great start. I would NOT adjust the top of the keel. I would adjust HERE (my blue arrow). This will allow the deadwood to slide in further and that should resolve 90% of the issue. If you modify the top of the keel it will introduce some unintended fitting problems.
Let's see if others agree.
Do you have a disc sander? Once you have gotten the deadwood to slide in all the way it seems like you need to level-out the deadwood where it joins with the sternpost. Then everything will fit just as you have envisioned. Basically, I am suggesting that you trust the kit design and only adjust the parts most vulnerable to the vagaries of laser cutting.
