Thanks Paul.Very nice, Herman.
The number of shooting holes as per a drawing of Van de Velde. The number and placement of the struts as per my own design. The profiled rail in Castello finishes it and makes it visually attractive.
Thanks Grant.Very very nice Herman![]()
Very very very nice, Herman.
That also applies to the well made pictures.
Thank you Brad for your very nice comment.Simply WOW!
The texture, finish sanding, scraping, and subtle softening of the edges, bring a look of realism to your work that few can achieve!!
Thanks for sharing!!
Thank you Roger for checking in, your interest in my build log and your nice comment. Much appreciated.Hello Herman, I've been following your build almost since the start but this will be my first comment. I just wanted to say that these close-up shots are very impressive, if I didn't know any better I would think you are building at an even larger scale than you are. Your build is a joy to follow!
Thank you @KMSvideo.Špičková práca. Tie strely z palubovky majú určité čaro.
Thank you Mirek.Witaj
Świetna praca Hermanie masz dobrą rękę do rzeźbienia. pozdrawiam Mirek
