La Belle - CAF Models 1/36 by Signet
Time to put the wind beneath my wings - oh, wrong song. The wind into my Jolly boat's sail. Which means I have to work on the sail. Let's start with the sail, mast and spar design, which I drew up:
The "mast" is wood shish kabob skewer from my wife's kitchen, and the spar will be made up of two toothpicks, glued together with a simple splice joint.
I've found that when not used, the sail was wrapped around mast, to which it's attached, and the spar. They'll just fit within the boat's length:
I then drew the sail configuration up more accurately, getting ready to make a sample sail:
Using a light box, I traced the details of the sail with a pencil. This is just a trial sail, remember, cut from an old hankerchief:
For this trial sail, I thought I'd try gluing the boltrope in place before trimming:
I purchased some cotton yard fabric to use for sails (thinking ahead), and wanted the color to be consistent. I used some Rit Beige dye, leaving small pieces of fabric in for varying times, to determine a color. The results were, uh, surprising:
Yes, the pieces are greenish-yellow. More so than it looks in the photo, in fact. I researched the problem, and it was suggested I hadn't mixed it enough, nor used enough dye. A second try ended with even stronger greenish-yellow. So much for Rit dye!
In the meantime, I tried a different sail outline approach, including tabling and reinforcements:
I decided to go the tea route for coloring the sails. My first try was a bit too light, I felt:
A second try with more tea concentration worked out okay:
The beige color in the middle of the picture is what ANCRE says the color that French sails should be. No, this isn't close, but I like it. Plus, I think the beige is not really a great color for sails.
With the tabling folded over and glued using acrylic medium:
By this time I'd made several. Practice, right?
Time to add the boltrope:
A little bit of stitching in the corners should make them sturdier:
Finally, the sail is laced to the mast:
The spar in this case simply holds up the corner of the sail:
If you look closely, you can see the scarf joint in the spar.
Next to figure out the rigging required...
Rigging now determined, it was time to hoist the sail. Here she be:
At least 3 lines are required to sail a spritsail-equipped Jolly boat like this. Sometimes more to help stabilize the mast, but I've added the minimum, since it will all be stowed away anyhow.
I've mounted 2 cleats for use with the rigging lines in the boat, 2 fore and 2 aft. I'm using 3 of them here. While I wrapped the lines around the cleats, I didn't take the time to do it "right", since I was going to remove it all anyhow. Thus, the blue tape to hold the lines snug. Some more pics:
FYI, the three lines are:
1) The Sheet line is attached to an aft cleat and to the sail's clue.
2) The Spar holds the Peak of the sail up, and in turn it is held up and tightened against the peak by what's called a snotter, which goes through the mast and is attached to a fore cleat.
3) Not always used, I've added a line to the head of the sail, which goes through a pulley in the top of the mast, which prevents the sail from falling down in low wind. This line is also attached to a fore cleat.
More pics:
A better view of the lines to the cleats:
After tearing it apart (I really hated to do it, kinda liked the boat that way), I had to roll the sail like it would have been done for storing when not in use:
The scissors aren't indicating any cutting; they're just holding the sail with a triangular portion folded over. This was often done to make the rolled sail shorter and/or neater. I will be rolling the snotter line with the sail, leaving the others outside the roll.
Here's the sail all rolled up and in place on the boat:
And finally, with both the sail and oars in place:
Despite the fact that these are stowed in the normal position, this doesn't leave much room for men. Possibly they left the sail behind if just rowing to shore, or immediately raised the sail, possibly not taking all oars with them, for sailing with the wind. I don't know, but all that stuff is required at one point or another.
Guess that's it for the ship's Jolly boat. Now I'll start working on the hull structure for La Belle.
Okay, enough of me screwing around and not working on the subject of this thread, the CAF 1/36 Scale La Belle. CAF had done a 1/48 scale version of this vessel that has been done quite often. I don't envy those modelers; even the 1/36 scale will be a challenge to me in many ways. An Italian outfit made a 1/36 scale version, which appeared to be a group build on a German modeling site, and they are darn well incredible, as it was a great kit to start with. But no longer available, so I'm happy CAF has gone with this model.
I'll start by comparing the mid-section frame of the model with Boudroit's drawings included with his La Bell monograph:
Boudroit's drawing is on top, and includes for reference the plank locations. The kit drawing is below, showing cross-lines where joints are located. The other outline is quite close, with very slight variations in a couple areas. Probably within my sanding and shaping ability. The inner outline is thicker toward the bottom, but I'm happy about that, as it makes it stronger, and if I /really/ wanted it closer to the monograph, I could sand that area more.
(BTW, I know there has been a lot of discussion and research concerning problems with Boudroit's drawings and analysis of the actual, or theorized, shape of the hull. I don't want to get into that here. The small variations between the various versions will not, IMHO, be visible in the model. I will ignore Boudroit's information where I have specific information to the contrary, and will explain why. But the niceties of the hull shape will be beyond the scope of this build. Hopefully.)
I'm going to take the process of building a couple frames tiny-step-by-step, as I think/hope there are a couple details and other information that may help others. Obviously, I won't do this for the remaining frames. I decided to start with the M section frame, the only triple frame on the ship and located at the broadest portion of the hull, and a severely beveled frame #2, to see how that works out.
Anyone who has built a Plank-On-Frame (POF) ship model is familiar with this process, but to help readers who may not have built one, I'm including this detail. The first step is, for each of the 28 built-up frames, to determine which parts are required, and where they go. The manual included with the kit includes diagrams of each laser-cut board with its part, to help in this:
The needed parts for one frame are removed from each sheet. In the past, I've marked the part numbers beside each part, but so far I'm not doing that, partly because there's little room here to do it clearly. I do quadruple-check I have the right parts for each frame - the parts from adjacent frames are extremely similar, so this can easily happen. I've seen others write numbers on each part, but I don't like to do that. At least most of the time.
While looking at the various parts of the frames, and when comparing them to the frame outlines, you will find some lines that don't make sense, and seem like they shouldn't be there, like those circled below:
It turns out that they shouldn't be there. According to Tom, they are a "legacy from a previous version". That's kind of unfortunate, if you want to see the sides of the frames in your build, so you may have some extra sanding to do.
So, next I take the pieces for my frames, and place them in the approximate location to confirm that's where they go. I broke my rule of doing one frame at a time here, as I felt I was safe with the completely different frames being worked on:
Most frame parts of laser-etched lines on one side, like the center portion below:
The "cross lines" I'll call them show the location of parts of the second frame, which overlap each other for strength a bit like a row of bricks. It's hard to tell from the photos below, but the notches are a bit narrow for the 4mm keel:
The notches are smaller than 4mm by less than 1mm, probably closer to 0.5mm. That seems a tiny amount, and it is, but 1) It's a lot more than is required to remove the char (and it's debatable if when gluing notches and parts such as this that the char needs removed at all), and 2) That 0.5mm, or whatever, is much more of a pain to remove than it appears to be (and should be).
I guess I'm not as skilled as most, and maybe a bit more impatient, but I've used about a dozen files of various styles, grits and shapes to widen this slot, while 1) Keeping the slot from being too wide, 2) Keeping the slot centered, by not removing more material to one side than the other, 3) Trying to NOT deepen the slot by more than the char, and 4) keeping the bottom slot corners sharp so the 4mm pieces fit in as far as necessarly.
Sure, that's a common task for us model ship builders, and basically a simple one, but hard to get "just right". My first notch looks like this:
Yeah, it works, the part fits, and it will glue fine. But it's not neat. One side's a bit deep, and it's, well, ugly. Perhaps others have found ways of increasing the width of these slots, but I've not found a great one. This is the best way I've found to increase the width, without increasing the depth, which can more easily be done afterwards:
OF course, it depends on the state of the grit of each side being the same, but hopefully it is.
Again, why the big deal? Well, for just this frame Section 1 of La Belle, just counting notches involving the 29 frames, I need to make 116 notches, counting those in the keel and keelson. And, IMHO, there is no reason we should have to do this. Other notches, like those on the building frame, push together with little force and clearance without the touch of a file or sandpaper. The 0.5mm or whatever is allowed for this should not be there, for this location or any area where a known thickness piece (like 4mm for the frames) is inserted. The 4mm pieces are accurate within less than 0.1mm, most much less. The "normal" 0.5mm allowance for pieces like the frame outlines themselves should /not/ be necessary on the notches.
Tom - I know you're following - please consider allowing far less, maybe close to zero, clearance in laser cut notches when known thickness boards are inserted into them. Sure, the outline of parts needs the allowance, but not the notches.
Anyhow, after filing, sanding or whatever method (I considered buying a 4mm wide file, but couldn't find one, only a round one) the notch, the 4mm thick piece hopefully fits well and is of the correct depth:
After the ends of each piece are lightly sanded, they are positioned on the paper template using Fixo-Gum rubber cement to cement the pieces to the paper, and white glue to glue them to each other. As this is a triple frame, I can place the center frame with the laser lines pointed up.
Weights hold the pieces straight while the glue dries. I've used a piece of glass to mount frame pieces on in the past, but think my work area is level enough for this purpose.
After the glue of the first layer dries, I can add the second layer. The laser lines on the center piece are somewhat useful here, but all I really need is where the pieces start. I've found that excessive sanding for end-mating parts isn't really necessary, and can sometimes result in a shorter frame than desired. I prefer all the frames as high as possible, so I can be sure of obtaining the correct height.
So now there are two layers with one to go:
At this point, the center frame can be removed from the paper to add the 3rd layer:
Any Fixo-Gum can easily be rubbed off, any paper sticking is caused by the white glue, so a light sanding eliminates those items and provides a level surface for gluing the next layer. The template can't really be used for that, but isn't necessary, as you're just matching the parts to the existing structure. I started at the top, actually.
Frame #32, and all the frames /except/ number 12, the triple frame, are double frames so the initial procedure is a bit different. Most frames, in addition to the (unnecessary) cross lines, have lines that show where bevels are to be cut/sanded. TO be sure they will be visible when the frame is done, the frame pieces have to be placed on the paper with the laser-cut side down.
My single plate weight works well here for this smaller frame:
After the glue is dry, the second layer can be glued to the first:
Above is a good photo that shows the cross lines on the pieces. I don't feel they're required because the lines on the paper show exactly where things go. IMHO those are NOT necessary, and are just something that should be removed if visible on the finished model. Of course, the contour lines have to be included, because they indicate bevel locations.
Tom - Please consider eliminating the cross lines, as the aren't really required when using the paper templates.
After the glue is dry, the frame is removed from the paper:
Next I sanded the contours in frame #2 above. (The triple frame above has no lines or contour, so that's not required there)
I also removed the char and sanded the inner and outer surfaces of the two frames. I feel the inner contour will be close enough visually and construction-wise and this will eliminate inner sanding in place, which is difficult. I've also sanded the outside of the frames. After assembly, they can be recontoured, if necessary, but if that isn't required, they'll have been sanded with the grain, and have an initial finish coat.
And after a coat of finish: - Whoops, it seems there's a limit of 25 pics, so I'll finish this post and put it in another one.
And here's the finished 2 frames with one coat of finish:
I've removed most of the extra lines (false seams, not the real ones), except for the fore/top of frame #3, because I know it won't be visible.
That's it for today. I'm studying which frames I feel confident to go ahead with (I intend to make some changes like the gun port locations), and will be holding off on the keel for now.
A quick note about the frame construction on this model. I've been surprised that the double frames did not have both halves go all the way to the keel, like in the Granado that I built. It seems to me that the area near the keel needs to be the strongest (which is why most frames taper in both width and thickness as the go from keel to rail), but that's not the way this ship was built. It seems that the La Belle was one of the first proven examples of double frame construction; the French shipbuilders simply added additional frame 2nd and 3rd futtocks to the existing single U-frame, without adding the second 1st futtock that would form a normal double frame. BY itself, this would add little to the strength of a frame, but added to the entire hull structure, it would add strength and help prevent penetration by cannon shot or accidents.
My intent is to include the appropriate bolts in the frame, and maybe treenails and such as well, so today was my first try at it. While most bolts on the La Belle were round, the bolts holding the futtocks of one layer of frame to the other were 1" square bolts with square heads, with roves (washers) at the other end, bolts peened over. I have seen square roves in use, so assumed those would be square as well. First, I drilled holes in the M (triple) frame in the required locations:
I drilled the holes from each side separately. In theory, I should have been able to drill straight through all three 4mm pieces, but I really wanted to be sure the holes were centered, so drilled from each side. Maybe I'll drill straight through the double frames.
I pressed the square head bolts in place on one side. I wanted to avoid glue, as I was afraid it would make mess around the hole,
I tried prying the bolts out with my fingernail, and "pounding" the frame on my workspace, and didn't lose any, so hopefully they'll stay. Later coats of finish should help keep them in place as well.
The other side of the frame has the bolts with roves (I assumed builders would install them all from one side. That may be a bad assumption, but I went with it.
With the naked eye, the bolts with roves just look like big bolts, a bit oversize, but that's how it should look.
Here's a close-up of the side with the square bolts:
And here's one of the side with the roves:
I'm not too sure what to do for bolts that are required to be at an angle due to frame chamfering. Technically, the bolt heads should be at an angle, but I don't think that's a possibility for me. Neither would recessing the bolt head. I'll have to figure that out.
This should slow my frame work down some!
While I don't think the bolts on frame #2 will be visible, I went ahead and added them to the aft side:
The fore side butts up against the semi-solid piece at the bow, so bolts I think would interfere with proper placement. For this frame, I experimented with having both bolts and bolts with roves on the one side. I tried to place them in a logical manner, as if it made a difference in how they could be placed. I also placed them as close to the inside as possible, to minimize the angle that the bolts would have to be at on the full size boat.
While doing this, I realized that some of these bolts may well interfere with the notches in the top of the building frame. I'm not going to build either it, or the keel assembly, at this time, but perhaps I can mock up something to see if the bolts will interfere with anything.
What do you think about all bolts on one side, bolts and roves on the other vs alternating them in some way?? ThumbsupThumbsdown ?
Did the square bolts come with the kit ?
No, I designed them in Fusion 360 and my son made them them in resin.
It’s a great effect, and that pear wood looks awesome.
Thanks, an yes, the pear wood looks great. There is some variation in color, but less noticeable in real life than in the photos (isn't everything?), and really just emphasized the fact that it is made in multiple pieces. I'm really pleased Tom decided to make this kit available in pear wood (despite the price).
Continuing on with my concern that the added bolts may interfere with the positioning jig, I first measured the location of the frame to the keel (not yet assembled):
I then overlayed the frame on the side of the jig, to see where the jig with slots for the frames is located (arrow in red):
So, at least the lower of the pair of bolts at that location interferes, as shown below with the frame in the correct locaton:
With this interference, I won't be able to put bolts in at that location, or just below it, to be able to get the frames in position, or more importantly, get the completed frame out of the jig.
Let's check frame #2 to see if it has a problem:
No problem with this particular frame, since the bolts are placed as far as practical inboard, but if there had been bolts on the fore side, they would have been placed outboard, and would definitely be a problem.
So many of this level of bolts will interfere, and can't be positioned there. The question then is to see if this matters; that is, would those bolts be visible after construction. While I placed all the bolts on frame 12, it was kind of a test. In actuality, I think it's silly to place them where I know they won't be visible (i.e. I'm not Uwek, after all). I scaled up the drawing of the side of the jig, comparing it with actual measurements, and used some advance drawings sent to me by Tom, to get this:
The jig side is shown over an outline of the La Belle, frame 12 is shaded in blue. The slots identified above is where the horizontal frame piece that locates each frame is located. Comparing the photos posted above, the bolts in question occur right at the slot level, which in this case is behind the lower wale. I will definitely be adding the wales to both sides, so anything behind them won't be visible. I'll have to see if I want to leave any strakes off above the wales, which would determine if I place bolts in this area.
The bolts just below the wales would probably be visible, if there are openings at that point, yet they can't be there because of interference. The answer, for me I think, is to add at least one strake below the lower wales, which would cover any bolt there (or supposed to be there). As long as any openings in the hull (leaving strakes and/or sections of frames off for visibility of inner structure and elements) are below that strake, I should be good. Of course, I'll have to check that as I go along, as joints and bolt locations change for each frame.
Basically, I'm trying to do something similar to what Tom did on his prototype, with the openings:
His structure visibility starts immediately below the lower wales, but per above, I'll have to add at least one more strake below that to cover the area where the bolt should be, but isn't. I may include the hole for the bolts anyhow, in case it's visible, saying that the ship is under construction (and I have information confirming that most of the holes and bolts were added after the frames were assembled in place on the keel, so that is historically correct. ;-).
Okay, I'm good to go, as long as I keep this information in mind as far as the bolts are concerned.
Continuing on with two more frames (I won't be doing this for all - just trying to show my procedure and logic), I decided to proceed with frames 10 and 11, already having done 12. These are central to the hull, straight, and easy to do. And these are all double frames, as opposed to the one triple frame #12.
Using frame 11 as an example, I've laid the aftmost frame of the double frame in place, confirming the location and shape of each piece, which should be carefully done to all frames. Since the aftmost (in the forward portion of the ship - it will be aftmost in the aft portion of the ship, with frame @12 being the divider) is the "complete" part, that is it comprises an entire frame while the second portion adds on to it, it's best to start with it first.
Yes, I laid them out more carefully to determine location and that the pieces are correct. Notice the lines on the print basically match those on the futtocks, with lines laser-engraved on each futtock where it "matches" a joint on the other frame, and of course lines at the end of each frame on the paper. I have shown the futtocks with the laser lines upward, although the intent of the manufacturer is that they face downward. More on that later.
This is how the second layer futtocks fit atop the first layer:
Many of you will be surprised, as I was, that the second layer did not proceed across the entire first layer, but rather left the center section open. The La Belle was one of the first French ships to use double frames, and this is the method they came up with initially. I would have thought the extra strength would be necessary at the keel connection, but I'm not a 17th century ship builder.
This is the way the futtocks are intended to be placed for the first layer: Laser-engraved side downward, which will be to the outside, and laser-burnt side to the inside, which will be covered between the two frames.
The above view would normally be after these pieces are glued together, meaning they precisely positioned, lining up with both the drawing and each other. I have not shown this, however. Notice that the laser-engraved lines on this piece are of no use - you can't see them. You can, however, align the pieces with the lines on the drawing, so that's fine.
Now the second layer is attached, in the intended manner, again with the laser-engraved lines also to the outside, or up in this case:
The ends of each piece can be aligned to the lines on the paper, but of course not to the lines on the first layer, as they are on the bottom side. And while you can check the in-between laser lines with the paper lines, that's really not necessary, as the ends determine the location. So, when doing things the "right" or intended way, these laser lines are of no help. They just need to be sanded away later, as they shouldn't be there.
All that said, I made my frames in reverse, so that the laser lines are to the inside. It's much easier to sand out the laser burn than it is the unnecessary laser lines, which are much deeper. So I started with the first layer oriented with the laser-lines side up, then added the second layer laser-lines-down, just the opposite of the intended procedure:
Doing it my way, upside down, the laser lines on the first layer can actually be used, in addition to the lines on paper.
Here are frames 10 and 11 completely assembled, but unsanded, using the above method:
So, am I going to make all the frames "reversed" like this, avoiding the laser lines? I'd like to, but I can't. About half to 2/3 of the frames are in areas of the hull that require beveling, usually both sides, due to the curves encountered. CAF has rightly shown laser lines to indicate where to sand those bevels, where is really great if not completely necessary. Those lines MUST be on the outer sides of the frames (or you couldn't see them, of course). Unfortunately, the locating laser lines, which I've shown above are not only unnecessary but cannot even be used, are on that same side with the bevel lines. In addition, there are added "legacy" lines that shouldn't be there. So on those frames, I'll have to assemble in the intended way, laser-burned sides to the inside, and either sand out the lines or leave them in. Tom - again, I believe all but the tapering lines should be eliminated.
By the way, while I always try to be careful when aligning the two layers, I didn't do well on one side of frame 11:
Obviously, this has to be additionally sanded to remove the offset, making both sides parallel. Luckily, the lower side was correct, while the upper overhung it, so when sanding the outer contour was unchanged, while the thickness was reduced about a half a millimeter. I felt I could get away with this, and didn't want to rip the frame apart, so left it this way. But I vow to do better in the future, and in fact searched for and found a tool that will help me.
As before, I placed square bolts and one side, and the larger square bolts with square roves on the other. I decided to drill the holes for them in all locations, and for these non-tapered frames, was able to drill a single hole straight through, rather than drilling from each side like I did with the triple frame 12.
Above Left is the forward side of Frame 10 and above Right is the aft side of Frame 11.
I have decided that my LaBelle will be completely planked and finished on the Port side, and the Starboard side will have open areas showing more of the structure and innards of the ship. This determines where I need, and don't need, the square bolts. On the Starboard side, I've included them everywhere except at the center where the jig frame locator plate is, while on the Starboard side I only include those below the locator place - on the off chance that they will be seen from inside, although most will probably be covered by the ceiling (floor - hate that term), structure and added strakes. Also, note that the square head bolts are now more-or-less recessed. I didn't think it realistic they would sit on the very surface, so recessed them with the tool below. Some went in more than others, which I suspect happened on the real ship too. I think it looks better in person than in the photo above, so I think it's fine.
I mentioned a tool to help me align frame pieces better. The problem is we're placing one part over another, and it's supposed to match all around. I've tried using a square, which was clumsy, a block of wood against the side, and in the end my "sensitive" fingers and so-so eyes. I thought I'd done well, but the photo above shows that isn't always the case, and I want to do better. So I bought these half-round/flat parallel jaw pliers. I hope to use them to move the upper futtock to be in line with the lower by pinching from above, with the half-round side to the inside of the curve, to prevent marks. I think it should work well. In the meantime, I'm using the pliers to seat and recess the bolts, for which it has worked pretty well (except I can't see what I'm recessing, so it varies a bit, like real life I hope).
That's it for now. I'll occasionally show progress photos as my bevy of frames multiplies in number. I probably won't add much detail until something changes in the frames (it will) or I work on something else worth posting.
I think I previously mentioned a tool to help keep the layers directly atop each other. This is what I got:
I'd always wondered about pliers in which the jaws stayed parallel to each other. Using regular pliers to force two pieces together, etc. never worked very well. When I had problems making the two layers of the frames exactly in line with each other, I bought the pliers and used them for this method. It actually works pretty well. I let the glue dry just a little bit (Ponal Express can be repositioned for 5 minutes, so they say), then use the pliers vertically over the drying frame, and it moves the upper layer in line with the lower much better than I'd be able to. Also, the tool works works well to seat the "bolts" into the frames.
I continued on with frames toward the bow, frames 9 and 8:
Frame 08 is to be cut out for the gun ports, either now or later. I'm not that confident in the exact location of these ports (the top and bottom are shown horizontal, for example, but should be parallel to adjacent wales and strakes), so am not cutting them now. However, I did just put a spot of glue at the top, and left glue off the port area, so it should be easier to remove cleanly.
Frame 9, like the others I'd done so far, had no bevel to the sides due to hull curvature, so like the others, I put them together backwards, so the unnecessary and wrong laser engraved lines were to the inside; the laser burn was easily sanded out. Starting with frame 8 forward the edges are beveled, inside and out, in accordance with the laser engraved lines along the periphery of the frames. So frame 8 above is assembled the "correct" way as shown in the instructions. Or at least in the manner expected.
Here are the finished frames, with the square bolts on the aft side and the square bolts with square roves on the forward side.
I've left the unnecessary laser lines on frame 8. I toyed with sanding the whole thing down to remove them, in retrospect I probably should have done that. Maybe I will on the rest. As on the other frames, I've left bolts out of the middle which ends up just below the lower wales and at the notch in the jig that locates the frame, and would therefore interfere with the frame sliding into the correct position.
In the meantime, I've taken the advance drawing that Tom sent me and made some overlays of the inner details, structure, and outer details to determine what I want to show without planking, and with portions of frames removed, to make openings for inside detail. This is what I'm currently working with:
On the above, frames 7 through 12 are in place, but I might end up removing portions of 8 through 11. I'm unsure, though, as there won't be that much detail that area that won't be shown elsewhere. We'll see - I have lots of time to decide.
I'm enjoying the model so far. I like the pearwood. and the pieces and contours match Boudroit's monograph very well.
While working on frames 13 and 14, I noticed some anomalies. The first was that the gun locations frame 14 were quite different than on frame 13, and they really shouldn't be by less than a millimeter or so due to strakes taper:
I went ahead and made up the two frames using my usual method (laser lines to the inside, since there's no taper or beveling to the frames here):
After the glued frames had dried, I noticed quite a difference in the height of the two frames:
Since the keel height is relatively the same, we wouldn't expect a step like this until much further along the hull:
As can be seen above, the top of the jig side frame represents the height of the frames up to the underside of the rail. No change is indicated at the middle gunport, although we would expect one between frames 21 and 22.
However, the frames show that there is in fact a step up of the frame heights between frames 13 and 14:
And again between frames 12 and 22:
These frames will not match the height of the jig side frame, which is the normal definition of the height of the frame elements.
I now remember questioning this with Tom months ago after seeing a 3D view of the frame, which is shown on the instructions:
I've circled the areas in question above, and also on the preliminary copy of the plan that I have:
Made this way, all the frames extend to the top of the upper rail, but I don't think it will leave the correct opening between vertical elements.
Looking at Boudroit's drawings, the frame is similar to above, but only one half of each frame extends to the upper rail' To create the structure with the frames extending that far up requires the double frames to be separated as shown below:
These extensions of one side of each frame create the decorative spacers below the top rail, as shown below:
As confirmation of how the frame is constructed, Boudroit's monograph has this photo:
So, if these frames are cut to the height of the jig sides, as normally done, these small decorative pieces will have to be added separately. If the frames are to be extended up to the top rail, as was actually done on the La Bell, it will require one half of each frame to be cut short, which (I think) would be easier done by cutting one half short before assembly of the two halves. And if this is done, then small pieces will have to be inserted between the frame extensions, finishing off that area. And we don't know what the thickness of those pieces would be, so it's hard to determine the exact height of them. Unless the lower portion is to be made to match the jig side, while the other half extends upwards.
Therefore - I am confused as to how to continue. I really don't want to have to cut those sections out, which would be difficult to do accurately and well, when I could have just cut one half short beforehand. And I certainly don't want to cut all those frames short, when they should be extended.
In short: The aft half of the frame heights do not match the side of the jig, which they do for the fore half, and usually do for models, and the frame tops should apparently have one half cut short, but where?
Tom - I think I need a clarification here.
I understand that you need to make this boat completely according to PLan, but I have to simplify some of the structures. Due to different production habits of each person, the accumulated errors in the subsequent process are not uniform, so I have made changes to the production of the upper column of the ship's hull, which can enable more people to complete this work.
The following is the production plan for this part of the structure, which has been simplified. For ordinary creators, this structure is more convenient to install and avoids the dilemma of being unable to complete the final stage of production.
Of course, with your production skills, you are fully capable of restoring the original design. If you need any assistance from me, I am always willing to serve
Good Day, Gents. Not a big deal, to me. The monograph, a usual whenever exists, is highly recommended, though. Along the waist, the faux -headtimbers solution is not bad: caprail mortises, if provided with the kit, would hardly accord with the true 2nd futtock extensions... just take a look to my Hoy here below. For the quartedeck, I see no problem with a "true head timbers solution", if the 2nd futtock of any demi-frame would be cut accordingly to the monograph. Cheers All!
Yes, it's easy to cut square holes on wooden boards, especially with a laser machine, but it's troublesome to ensure that everyone's columns and square holes can be perfectly installed I will provide a solution for the design of this part in my next work At present, I have a preliminary idea, but it still needs to be tested
All true. Although cutting a bunch of square holes to match futtocks that can be slightly different from one another can be challenging.
A question about your Hoy above, most holes don't seem to line up:
As to Tom's solution, since he appears to be providing laser-cut thin "hollow square" ornamentations for the futtock extensions and false pieces that will certainly be consistent in size, and since mine are probably not so consistent, I will be accepting his solution. I think that having all of the frames too long in the kit, without explanation or suggestion of alternate methods, is not a great idea, and probably was an error.
Hey Signet,
of course they do not. To be honest, I cant totally blame the kit (wich is great in many respects and provided me with a lot fun and experience with POF as well) as I sligtlly altered the bow assembly to have it closer to Antscherl's practicum, but the caprail would not fit the timberheads anyway, as even small erraticity in hawse pieces turns into a significant offset between mortises and heads of the frames.
I'm just not going to finish the port wale at all. Pic was intented as a mere suggestion on what can happen with pre-cut mortises. On the starboard side, I cut the true timberheads off, scratched a brand new caprail and I'll be installing faux timberheads via new simplified tenon/mortise joints ("wifeproof" round rods of carbon into round holes drilled trought both the caprail and the frame beneath).
Cheers!
