This is really a very good planking job for the basic layer
-> you will get a very smooth and accurate basis for the second and final planking
Good progress.
Do not forget to reduce the width of the rudder plate, it would make the model more accurate
I made a small sketch on your photo
I’m having a great time following your build. Learned some new techniques following your planking.
Hello Zoltan. In real the hull part below waterline of Pickle was covered with copper plates but because i don't have copper plates i will cover with 0,5 mm of mahogany veneer. Upper part of the hull will be painted.Hello Mustafa,is this the first layer or the model going to be single layer build?
